Anyone replace their distributor with aftermarket? - Ford Bronco Forum
 11Likes
post #1 of 28 (permalink) Old 02-27-2017, 12:05 AM Thread Starter
SuperDuty6.0's Avatar
Bronco Info: 1990 302/5 speed with 56k km's! Been in garage for over 15 years!
Wondering if anyone has replaced their EFI (mine's a 1990 302) distributor with an aftermarket one. I kinda fubared mine, rendering it useless, and am looking at replacing it. I could by a ford one, or something else. I looked around and see Summit has their own branded one and MSD also has one...but the reviews don't look so good.
Looking for others experience...
Andy
1990 Ford Bronco...under current restomod
2005 F-350 4x4 Dually...towing rig...and then some (Lol)
2011 Ford Escape...wife's Ford
SuperDuty6.0 is online now
post #2 of 28 (permalink) Old 02-27-2017, 12:14 AM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
as for reliability it is going to be hard to beat a OEM. They are designed to last years.
Seems MSD is a crap shot with some lasting a long time and some barely making it past a year.
BikerPepe` likes this.
Let's Go Fishing.
jopes is offline
post #3 of 28 (permalink) Old 02-27-2017, 12:21 AM Thread Starter
That's what I'm seeing. Kinda shitty, they have been around a long time.
post #4 of 28 (permalink) Old 02-27-2017, 12:27 AM
gone fish'n
jopes's Avatar
People want the name, don't care about how expensive it is. Only real benefit is at the track where you might shave off .05 of a second on your time.
Let's Go Fishing.
jopes is offline
post #5 of 28 (permalink) Old 02-27-2017, 12:33 AM
Bronco Info: 1988 Bronco XLT 351W 69K original
Stay with motorcraft, oem
Sent from my XT1585 using Tapatalk
bratcop is offline
post #6 of 28 (permalink) Old 02-27-2017, 12:35 AM Thread Starter
Ya, do need reliability for sure. Was thinking of bling, but want longevity first. Besides, I can always polish up a factory one.
post #7 of 28 (permalink) Old 02-27-2017, 12:45 AM
I bought a distributor from NPD for my '94 a couple of years ago. The core was twice the cost of the distributor. It has been working fine. Make sure you get the correct drive gear (cast or steel). (IIRC it was a rebuilt unit.)
SuperDuty6.0 likes this.
Mikey350 is online now
post #8 of 28 (permalink) Old 02-27-2017, 09:27 AM
fordbronco1995's Avatar
Bronco Info: 95 FSB Ox Wht. Blue Int. 5.8 33" nittos 18" fuel wheels.
The parts stores sell new factory style units as well. I have had pretty good luck with mine from Orielly's
fordbronco1995 is offline
post #9 of 28 (permalink) Old 02-27-2017, 09:54 AM
It is the electronics in ALL but Motorcraft, that suck. Since I could not find a decent OEM, I shelled out for the MSD. I then replaced the electronics with new Motorcraft. I think it is called PIP sensor. It is a pain to remove and install the electronics, but worth it. I am very pleased with the results. I have had a NAPA reman last for 3 minutes, literally, before the electronics failed.
wyatt earp is online now
post #10 of 28 (permalink) Old 02-27-2017, 10:03 AM
Exactly. I have read that the machining tolerances on the factory dizzy are far superior to aftermarket. I did the same, MSD outsides, motorcraft internals. Looks great, runs great
bratcop is offline
post #11 of 28 (permalink) Old 02-27-2017, 10:43 AM
All the motorcraft units are reman with aftermarket internals. Good luck finding a new oem one
post #12 of 28 (permalink) Old 02-27-2017, 02:52 PM
JScatt's Avatar
Saw this on Ebay
NEW OEM Motorcraft Distributor Assembly DA-1921 Ford E-150 F-150 302 V8 5.0L | eBay
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
JScatt is offline
post #13 of 28 (permalink) Old 02-27-2017, 02:58 PM Thread Starter
Doesn't fit mine...too bad...need efi one. Seen some stock Mustang ones on ebay...not sure if they are the same as the trucks/broncos...more research. lol
post #14 of 28 (permalink) Old 02-27-2017, 03:11 PM
Retiring Soon
guess I got lucky with the MSD. Had read of the problems but mine lasted well, longer than I had that Bronco ('90 302).
BikerPepe` is online now
post #15 of 28 (permalink) Old 02-27-2017, 03:15 PM
JScatt's Avatar
Oh yeah! Sorry bout that! You need a Motorcraft DA-1989. $562.00...LOL
http://www.fordparts.com/Commerce/Ca...=Bronco#Search
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
JScatt is offline
post #16 of 28 (permalink) Old 02-27-2017, 04:48 PM Thread Starter
Buy 1990 Ford Bronco Parts | FordParts.com
Wow! Thanks for info. So I look and see, that's for an auto trans. The one for manual trans (DA-1991) is $240.72...which is much better. Sure didn't think the distributor would be different because of trans...so, I learn! That should make it even harder to find one that matches...time...
http://www.fordparts.com/Commerce/Pa...d&model=Bronco
JScatt likes this.
post #17 of 28 (permalink) Old 02-27-2017, 11:08 PM
Prozon's Avatar
I've had good luck with O'Reillys. You'll probably never have an issue.. but hey, if you do, that's what lifetime warranties are for. Can't say I've ever had an issue with any of mine though.
Prozon is online now
post #18 of 28 (permalink) Old 03-19-2017, 08:35 PM
devildog93's Avatar
I bought a aftermarket unit for my setup. I was doing a swap and needed a unit with a steel gear for the roller motor i was dropping in and this was the best i could come up with. It didn't break the bank and still worked with my carbed setup. I have been running it daily for a little over a month now with zero issues, but that hardly speaks for the longevity of it. I think it is a good part and it will hold up, but that is just my best guess. I know the support was pretty stellar.
JEGS Performance Products 40055: SSR Pro Series Billet Distributor Small Block Ford 221-302 (Except 5.0L) | JEGS
That isn't exactly the unit i got, but close. I bought the 351w version.
devildog93 is offline
post #19 of 28 (permalink) Old 03-19-2017, 10:07 PM
mrnewland1's Avatar
What exactly is wrong with the original distributor?
"Oh man, lodged where??"
mrnewland1 is offline
post #20 of 28 (permalink) Old 03-19-2017, 10:37 PM
Nothing beets a Fullsize
Kingfish999's Avatar
i usually try and get a Motorcraft online. otherwise i use new Carquest that Advance Auto sells since theres soo many of them Advance Autos around and lifetime warrenty.
on my friends 87, i had to replace a Richporter Technologies (now called Spectra Premium i think) from Oreillys cause a bad ICM. i replaced it with a reman Cardone. a couple months later had to replace it again because it had a bad bearing. it shows that aftermarket does suck for quality
Kingfish999 is online now
