best full carpet set - Page 2 - Ford Bronco Forum
 16Likes
post #21 of 38 (permalink) Old 03-06-2017, 10:16 PM
Here are some pictures I dug up of the Crystal Blue replacement full carpet set I got for my 1993 XLT if anyone is interested. This set came from OC Auto Carpets (ACC brand). I found the quality and fit to be awesome!
Here is the main shared folder if the pictures below don't show: https://drive.google.com/drive/folde...m8?usp=sharing
glassdave likes this.
Last edited by csilvestri; 03-06-2017 at 10:35 PM. Reason: Picture links possibly not working?
csilvestri is offline
post #22 of 38 (permalink) Old 03-07-2017, 04:30 PM
92FSB's Avatar
Bronco Info: '92 Cabernet Red / Gray XLT with 302 & '94 Cabernet Red / Gray XLT with 351.
Thanks Mikey350.
'92 Cabernet Red / Dark Gray XLT with 302.
'94 Cabernet Red / Opal Gray XLT with 351.
92FSB is offline
post #23 of 38 (permalink) Old 03-07-2017, 04:32 PM
92FSB's Avatar
It seems that ACC carpets might be a good choice. I've read that people have had problems with the fitting of the carpets in the front hump area. Does anyone have a solution for that?
92FSB is offline
post #24 of 38 (permalink) Old 03-08-2017, 11:45 AM
I had asked OC Carpets about the fitment and they explained that each carpet was moulded to an original floorpan. I was also told that there are slight differences between model years, for example, there is some slight difference between the 1993 and 1995 (unexplained as to exactly what), but that's what I was told. So just make sure you order the correct year. I didn't have any issues with the hump and the fit was perfect in that area, so I'm not sure what other people had problems with.
post #25 of 38 (permalink) Old 03-08-2017, 05:23 PM
92FSB's Avatar
Thanks csilvestri. I'll post how I make out when I get the carpet installed.
92FSB is offline
post #26 of 38 (permalink) Old 03-08-2017, 06:16 PM
JKossarides's Avatar
Marked for future reference:
AWESOME info guys. I'm thinking about doing my carpet/s this summer, going in this month for hip replacement surgery so I'll be down for a while. I got a few maintenance issues I'll have to deal with when I'm back on my feet.......where should I look for a new headliner?
Thanks ~
JKossarides is offline
post #27 of 38 (permalink) Old 03-09-2017, 08:52 PM
Got my ACC carpet from @RockAuto installed today. I am very pleased with the fit and it seems to be good quality heavy carpet. There are a couple small areas where it's a little loose on either side of the hump, but they're not noticeable and not a big deal. There was about 3" to spare on each side.
glassdave, csilvestri and I6-Kid like this.
SRWillis is offline
post #28 of 38 (permalink) Old 03-10-2017, 03:02 PM
Looks pretty good.
SRWillis likes this.
1990 Eddie Bauer Bronco
scparrish is offline
post #29 of 38 (permalink) Old 03-10-2017, 04:03 PM
Jimmyz's Avatar
Bronco Info: 94 Bronco 5.8L
ACC from Rockauto
1994 Bronco XLT, 5.8L, 33x12.50 Mickey Thompson MTZ's, 15x8" Raceline Rockcrusher wheels, Moog824 coil springs, Redhead steering box, (6) KYB shocks,
Jimmyz is offline
post #30 of 38 (permalink) Old 03-20-2017, 01:43 PM
Fitzy's Avatar
Bronco Info: 1996 Eddie Bauer
Anyone ever try dyeing their carpet?
Fitzy is offline
post #31 of 38 (permalink) Old 03-22-2017, 04:34 AM
Bronco Info: 1994 Bronco XLT
Dying the carpet is probably more trouble than its worth.
glassdave, Jimmyz and Fitzy like this.
Hendry Hill is offline
post #32 of 38 (permalink) Old 03-22-2017, 02:58 PM
Fitzy's Avatar
Yeah after looking into it more I agree.
Fitzy is offline
post #33 of 38 (permalink) Old 04-28-2017, 11:47 PM
92FSB's Avatar
Thanks ~
Headliner - I took mine out of my '94 and had it recovered. You could do it yourself if your handy. I had my sunvisors redone too with the same material.
92FSB is offline
post #34 of 38 (permalink) Old 04-28-2017, 11:49 PM
92FSB's Avatar
Can anyone tell me if when I replace my carpet, will I have to glue it in place? I haven't removed the old carpet yet.
92FSB is offline
post #35 of 38 (permalink) Old 04-29-2017, 09:14 AM
JohnMcD348's Avatar
Varies. If you glue it down, it's pretty permanent. Every time I've put in carpet, I just lay it in and the strips and seats hold it all down in place. I've replaced some carpets in vehicles before that were glued down though and it wasn't the easiest.
JTMcD.
JohnMcD348 is offline
post #36 of 38 (permalink) Old 05-01-2017, 09:55 AM
Br0nco91's Avatar
Bronco Info: 1995 5.8 EB
Jimmyz,
Do you have any pointers for installing around the rear wheel wells? I seem to have a lot of extra carpet there.
Also did your rear piece have the 90ish degree mold to fold down over the step up in the floor? My rear piece is all flat and seems to be a bit too wide in the very back of the truck.
Thanks!
John
Originally Posted by Jimmyz View Post
ACC from Rockauto
Br0nco91 is offline
post #37 of 38 (permalink) Old 05-01-2017, 12:14 PM
I used a slight bit of spray adhesive for the wheel well carpet pieces, nothing more than a tiny bit to hold in place. The side trim panels hold it mostly. You may need to trim a small amount near the rear seatbelt retractors if you have rear shoulder belts like in my 1993. I chose some spray adhesive because I didn't want it to move around while fitting everything.
As for the fold-over lip on the front edge of the rear floor carpet, yes it comes flat and not heat moulded on an angle. Just fold it over and it actually tucks in the corners near the lower front seat belt retractors and stays in place. after a few days, it kind of takes shape.
You mention that the rear floor carpet piece is too wide in the back? Be sure you remove your rear plastic trim plate and fit it under that, all the way backwards. The mounting screws will screw through that trim plate AND the carpet, ending in the body of the truck. For width, it is the proper size. You have to remove or move your rear side trim panels to get them out of the way. Then, fit the carpet into the back, all the way across and you'll see how it fits. Once your rear trim panels are back in place, they cover several inches of the rear carpet on the outer edges. Mine fit perfectly when installed in this manner.
FYI, the rear floor carpet goes in last, AFTER you get the wheel well carpeting on. The floor carpet is bound on the edges and lays over a certain portion of each wheel well carpet piece, which also helps hold those pieces down and in place.
Does this help?
Originally Posted by Br0nco91 View Post
Jimmyz,
Thanks!
John
post #38 of 38 (permalink) Old 05-01-2017, 12:19 PM
Br0nco91's Avatar
Yep!
I was hoping to not have to pull the rear trim pieces off on the back but looks like they need to come off too. I have rear belts so ill have to remove material for them. That all makes sense. Thanks for the pointers!!
Does this help?
csilvestri likes this.
Br0nco91 is offline
