No Heat after Radiator Replacement with Two Core - Ford Bronco Forum
 10Likes
  • 2 Post By SRWillis
  • 1 Post By miesk5
  • 2 Post By biggum
  • 1 Post By 445 FE Bronco
  • 1 Post By Njbronco74
  • 3 Post By biggum
post #1 of 14 (permalink) Old 03-05-2017, 06:10 PM Thread Starter
biggum's Avatar
85 302 EFI
Replaced single core with double core.
Everything working fine before swap other that radiator leaking.
After swap I have no heat and little if any pressure in system when hot.
Engine not overheating.
I've been burping and filling but only able to add a cup of coolant or so at a time.
I think I still have air in the system or the two core is providing too much cooling.
Ideas? Thanks!
biggum is online now
post #2 of 14 (permalink) Old 03-05-2017, 07:03 PM
It sounds like your thermostat is not opening. I just started mine today after draining my coolant enough to hook up my heater core. I also didn't have heat until I let it run for several minutes, shut it off for a few minutes, then repeating a couple times. I did open the cap and relieve the pressure once, which wasn't much, during the process. The thermostat then opened, I had heat and then was able to add more coolant.
huck2080 and joedirt216 like this.
SRWillis is offline
post #3 of 14 (permalink) Old 03-05-2017, 07:16 PM
Yo Big,
After running engine to normal operating temperature; BEWARE OF FAN, BELTS, PULLEYS, HOT HOSES, IGNITION HIGH TENSION WIRES, AND ENGINE COMPONENTS;
FEEL heater water hoses. If the heater water hoses are too hot to hold, the thermostat is OK. If the heater water hoses do not get too hot to hold, REPLACE the thermostat. If only one heater water hose gets hot while the other remains cool, a plugged heater water hose or heater core is indicated.
Heater water hoses.
CHECK condition and routing of hoses . Visually inspect condition of heater water hoses for pinched or collapsed conditions
CHECK COOLANT FLOW THROUGH HEATER CORE
Start vehicle and allow to reach normal operating temperature.
Place temperature control knob in the full warm position.
Grasp inlet and outlet heater water hoses. Both heater water hoses should be warm to the touch due to coolant flowing through them.
Burp
Fill the radiator with a 50/50 mixture of the specified engine coolant concentrate and water. Allow several minutes for trapped air to escape (bubble out) and for engine coolant to flow through the radiator.
2. Replace the radiator cap to its fully installed position, then back off to the first stop. This will prevent high pressure from building up in the cooling system during this part of the fill procedure.
3. Start and idle the engine until the thermostat opens and the radiator upper hose becomes warm.
4. Shut off the engine and allow the engine to cool. Cover the radiator cap with a thick cloth and cautiously remove it. Step back while the pressure releases.
5. Finally, check the radiator and add more engine coolant if needed, following the procedures noted above. Reinstall the radiator cap securely, when finished.
6. If more engine coolant is necessary, fill the overflow reservoir to the appropriate level marked on the bottle..."
joedirt216 likes this.
post #4 of 14 (permalink) Old 03-06-2017, 05:35 PM Thread Starter
biggum's Avatar
Thanks guys. Again, everything worked before the swap so I'm leaning air trapped. However, the single core may have been able to heat even with a stuck open thermostat so I'm going to try a new 195 and see what happens.
post #5 of 14 (permalink) Old 03-09-2017, 07:50 AM
Marty in Md's Avatar
Bronco Info: 1993 XLT, 302, 1979 Ranger XLT,351M
Sounds to me thermostat is stuck wide open. Not regulating the water temp.
Marty
Marty in Md is offline
post #6 of 14 (permalink) Old 03-09-2017, 08:25 AM
Ford Hoarder
Also agree with the above.
I have replaced a bunch of radiators in these trucks and they seem not prone to getting air stuck in them. I have never had to do anything other then just fill them up, and check the level once its ran a cycle and top off. Not saying that you do not have that problem, only that I have not seen it happen very often.
CrazyBRONCOguy is online now
post #7 of 14 (permalink) Old 03-09-2017, 09:03 AM
My first inclination is when the radiator was changed a bunch of crud was broken loose and plugged the heater core. In this case I would disconnect the hoses to the heater core after recovering the antifreeze. Use a garden hose fitting on the return side of the core to backflush the core and throughly flush the engine also to remove setement in the water jackets.
post #8 of 14 (permalink) Old 03-09-2017, 04:08 PM
Njbronco74's Avatar
Bronco Info: 1974 bronco sport and 1996 bronco xlt
I did a three core in mine. When burping mine I let it get up to operating temp and gave the upper rad hose a good squeeze and I could hear quite the burp. Been working great ever since.
Njbronco74 is offline
post #9 of 14 (permalink) Old 03-10-2017, 12:58 AM
JKossarides's Avatar
Make sure the "inline and return" line heater hoses are hooked up correctly at the firewall, on my 86 XLT EFI 5.0 the inline goes underneath the FI plenum to a tube which goes into a HEX riser threaded into the intake manifold and the return line goes to the water pump.......just saying!
Thermostat could an issue so get a new one if need be and a "STAT" radiator cap....
Good Luck ~
JKossarides is offline
post #10 of 14 (permalink) Old 03-10-2017, 03:03 PM
I second the votes for thermostat or heater core.
1990 Eddie Bauer Bronco
scparrish is offline
post #11 of 14 (permalink) Old 03-10-2017, 10:19 PM
My heater core was stopped up. I had no real heat. I replaced the heater core (a very easy job in these vehicles by the way) and voila, great heat again.
hth
tim
TS 90F150 is offline
post #12 of 14 (permalink) Old 03-14-2017, 12:44 PM
joedirt216's Avatar
Bronco Info: 1990 Full Size Eddie Bauer 302ci Auto
So, biggum, did you get the Bronco throwing heat again?? And what was the cause?
joedirt216 is offline
post #13 of 14 (permalink) Old 03-15-2017, 01:36 AM
It's not the radiator either heater core or tstat or both. FYI get a premium stant t-stat off rockauto (better than mc imo). that or a motorcraft. The cheap ones are like a paperclip. junk.
GetBent4x4 is offline
post #14 of 14 (permalink) Old 03-20-2017, 05:47 PM Thread Starter
biggum's Avatar
The thermostat was in fact stuck open. With the single core radiator it still ran hot enough to generate heat in the cab but with the two it could not. Put in a new stant therm and it's doing great. Thanks for the help folks.
joedirt216, dash_cam and SkyMaster like this.
