What spark plugs and wires? - Ford Bronco Forum
 2Likes
  • 1 Post By BigBlue 94
  • 1 Post By rpeters549
post #1 of 15 (permalink) Old 03-14-2017, 10:05 AM Thread Starter
Bronco Info: 1983 Bronco XLT 351W/C6
Just picked up an "83 XLT, has a mildly built 351W with a GM style HIE dist. What plugs and wires would you recommend? I don't need high dollar stuff, but not junk either :)
GAHIGHRIDER is offline
post #2 of 15 (permalink) Old 03-14-2017, 10:12 AM
Taylor thunderbolt 8.2 wires are some of the best you can buy. I have em on my 85 300. They have the lowest resistance availible at 40 ohms/foot. Also heard good things about the DUI livewires. They are specifically designed for their hei dizzys, but will work on anything. I've got msd Street fire wires on my 96 351 and they are pretty decent.
My advice is to get a set that you have to assemble. They come out looking cleaner, due to no extra lengths being jumbled up.
For plugs, autolite copper core work the BEST in our engines. In my 03 mach1, I use the e3 diamond fire plugs, and picked up about 1 mpg, but most people say not to use them in our trucks.
445 FE Bronco likes this.
BigBlue 94 is offline
post #3 of 15 (permalink) Old 03-14-2017, 10:14 AM
Is it an HEI coil in cap distributor? If so the retaining ring for the wires snaps over the plug boots. I like MSD or Delco for HEI, they last for ever and are pretty resistant to oil and heat. Plugs I go with iridium for the reason of they take a lot of juice and last forever. Stay away from resistor plugs for hotter spark, maybe put a MSD cap, rotor, retainer and Accel coil and that sucker will light you up like Christmas in Vegas.
post #4 of 15 (permalink) Old 03-14-2017, 10:18 AM
Taylor thunderbolt 8.2 wires are some of the best you can buy. I have em on my 85 300. Also heard good things about the DUI livewires. They are specifically designed for their hei dizzys, but will work on anything. I've got msd Street fire wires on my 96 351 and they are pretty decent.
I put a DUI cap on my stock For dizzy and the cap adaptor did not fit well on the base. It kinda rocks around on there but the quality is there like brass terminals and all that. Taylor is a very good choice as well, they actually make the bulk of ignition wire out on the market if it is made in USA.
post #5 of 15 (permalink) Old 03-14-2017, 10:23 AM
I wasn't aware you could put a DUI hei cap on a stock dizzy. AbandonedBronco has a full DUI setup on his 81(?) 300 and loves it
post #6 of 15 (permalink) Old 03-14-2017, 10:41 AM
No I got the 460/modified dizzy, they make caps for everything. It is way better than the Napa or Autozone junk, if you buy a good set of plugs, cap and rotor you actually get more power and mileage. It will actually pay for itself in mileage.
post #7 of 15 (permalink) Old 03-14-2017, 12:22 PM
Ah gotcha. My cap for the 85 300 (for a 76 f150 300 ds2 dizzy) was so snug, I had to sand it down a bit to slip on.
post #8 of 15 (permalink) Old 03-15-2017, 01:41 AM
carbed truck any wires will do. order a closeout set off rockauto and autolite plugs are on rebate.
GetBent4x4 is offline
post #9 of 15 (permalink) Old 03-15-2017, 10:36 AM Thread Starter
So you're saying ignition upgrades on a carb'd engine are a waste of time???
post #10 of 15 (permalink) Old 03-15-2017, 10:39 AM
Not exactly the most efficient setup, if you aren't going high dollar msd any oe wire set should work sufficiently imo.
post #11 of 15 (permalink) Old 03-15-2017, 10:51 AM Thread Starter
It has a Performer cam,carb and intake with an HEI dist. Dual exhaust, no smog equipment.
post #12 of 15 (permalink) Old 03-15-2017, 11:01 AM
Carb and efi are no different when it comes to ignition and spark requirements.
To me, msd is "cheap" and a decent option for a DD. A race engine will want a better ignition system to get full power. I tend to buy better wires so that they don't melt from my headers. Really, in your application, any 8mm wire or bigger will work just fine. A new coil would be advised too: I'm running an accel super stock coil on my 85 and am pleased with the performance.
post #13 of 15 (permalink) Old 03-17-2017, 11:43 PM
Bronco Info: 1990 XLT, 5.8L, E4OD with Punisher VB
Like they said, more or less.
I got a set of platinum plugs for mine this time because with the rebate from Autozone they were just over a buck each. A good copper core will work fine though (NGK, Motorcraft, Autolite, etc).
And most any quality wire will work great. I doubt you will feel a whole lot of difference in a street motor from wire to wire as they are not really a power 'restriction' at this level. A good 8/9 mm wire will work just dandy. I like the FMS blue ones. Purty.
GAHIGHRIDER likes this.
rpeters549 is offline
post #14 of 15 (permalink) Old 03-18-2017, 04:17 PM
The Ford racing wire are a good buy, 8mm, soft, supple and numbered.
A poox on cheap wires, never last.
kenh is online now
post #15 of 15 (permalink) Old 03-20-2017, 12:01 AM
My platinum plugs are Autolite, not sure how long the promotion goes, but after the mail in they were only a buck and change each. They should easily last 40-50k. Current basic copper cores have over 30k on them without issue.
