Serpentine belt squeaks at startup. Saginaw, 3G alt... Hate to do this - Page 2 - Ford Bronco Forum
 13Likes
post #21 of 35 (permalink) Old 03-17-2017, 02:07 PM
Thread Killa
jowens1126's Avatar
When I did my sag swap, i had a bad chirp. It sounded like a bearing going out. In fact I determined that it was the pulley not being on far enough. It was actually pulling on the crank making it ride on the thrust bearing. Once I corrected the depth of the pulley everything was fine.
Also as for belts, in my experience, a 5.0 can get by with the OEM length belt after a sag swap, but a 351 will need a belt that is 1/2 - 1" longer.
Heres where my pulley ended up on the shaft after it was set right.
jtetterton likes this.
jowens1126 is offline
post #22 of 35 (permalink) Old 03-17-2017, 02:09 PM
I'm OBSessed
Bronco Info: 94 XLT 5.8L/e4od, 95 XLT 5.8L/e4od
So a pulley remover is needed to adjust the depth of the ps pump pulley I assume?
1994 Bronco XLT 351w e4od
1995 Bronco XLT 351w e4od
jtetterton is offline
post #23 of 35 (permalink) Old 03-17-2017, 02:36 PM
If a new tensioner don't do it a slightly lager pulley will but it will slow down the alternator slightly.
post #24 of 35 (permalink) Old 03-17-2017, 09:41 PM
Thread Killa
jowens1126's Avatar
yea you need a pulley remover kit to adjust the pulley. every parts store has them cheap.
post #25 of 35 (permalink) Old 03-20-2017, 03:09 PM
352Ford's Avatar
Bronco Info: 1996 XL
Are you sure it's the belt slipping/squeaking and not a bearing going out in a pulley, alternator, water pump, etc.?
Shake everything down and spin them with the belt off see if anything is amiss.
I love projects, I have ruined my life with them.
352Ford is offline
post #26 of 35 (permalink) Old 03-20-2017, 03:31 PM Thread Starter
B-man's Avatar
It was the tensioner. I replaced Friday. Drove it all weekend. No squeaks. Looks like the belt I have on is a goodin too. Got power and the rig is driving well.
Shit.... Why'd I say that... lol
dash_cam and storminc like this.
B-man is offline
post #27 of 35 (permalink) Old 03-20-2017, 06:40 PM
dash_cam's Avatar
B-man and jtetterton like this.
it's fun to do bad things
my "build" thread
dash_cam is offline
post #28 of 35 (permalink) Old 03-20-2017, 07:42 PM
I'm OBSessed
I happened to notice the other that that the tensioner was bouncing a little. It's a new ford part. Does this mean the belt is too loose? I'll try and grab a video if I can.
post #29 of 35 (permalink) Old 03-21-2017, 03:50 AM
No, the spring loaded tensioner is supposed to move a bit on a serpentine drive belt system. This is what the dual pulley SuperDuty tensioner, which is even more stable, does at idle with a brand new to-spec belt, rotating pulleys, etc., just as an example.
Spktyr is online now
post #30 of 35 (permalink) Old 03-21-2017, 07:33 AM
I'm OBSessed
https://www.youtube.com/watch?v=LEdxZiz2KOQ
Ok that seems to be about what mine is doing. Mine might be slightly more exaggerated.
post #31 of 35 (permalink) Old 03-21-2017, 03:20 PM
It would be more 'active' on a single pulley tensioner like the early PowerStroke 7.3 or the Windsor motors (and the 4.6 Mod motors) have. It's a common retrofit to the 9th gen PowerStroke 7.3 trucks to modify the bracket and fit the later SuperDuty's dual pulley tensioner - the stock single pulley tensioner is problematic on those engines. Likes to pitch belts. The dual pulley system is a lot more stable and stops the belt pitching.
What you see is normal, provided you have a new specced belt and the tensioner is new or recent and showing it is in the appropriate range of travel (see markings on tensioner).
post #32 of 35 (permalink) Old 03-21-2017, 06:29 PM
I'm OBSessed
Maybe I'm crazy but I don't see any range marking on the tensioner. It's a brand new motorcraft part.
post #33 of 35 (permalink) Old 03-21-2017, 10:07 PM
It's visible in the original poster's picture. There's a pointer cast on the silver rim and a range scale stamped into the black rotating part.
Link for higher res: http://i.ebayimg.com/images/i/321909...-1/s-l1000.jpg
post #34 of 35 (permalink) Old 03-21-2017, 11:35 PM
I'm OBSessed
This is what mine looks like
post #35 of 35 (permalink) Old 03-22-2017, 12:01 AM
Can't help you there, I don't know that one - but it should still have some sort of indicator to tell you when to replace the belt if nothing else. Maybe the position of the spring in the carved out section?
