Will procomp leaf springs 4.5" front lift - Ford Bronco Forum
post #1 of 2 (permalink) Old 03-20-2017, 08:21 AM Thread Starter
Njbronco74's Avatar
Bronco Info: 1974 bronco sport and 1996 bronco xlt
I'm looking at a set of 4" procomp leafs 23211. I think they will fit with a rough country 4.5" front. I'm looking to duke the lift blocks. I see in the eBay listing the springs have some sort of little wedge included so does that replace the factory block or just add some degrees because of th height.
Njbronco74 is online now
post #2 of 2 (permalink) Old 03-20-2017, 10:34 AM
Foolsize Member
92BroncoXLT's Avatar
To my knowledge Rough Country does not make a 4.5 inch lift, its most likely a 4" up front. But to answer your question yes those springs should work just fine. Im not 100% sure about the wedge that comes with them, but its most likely just a replacement for the factory one. You could use either
1992 XLT 300/M5OD
1978 Custom 351M/C6
1991 XLT 351W/Blown Up E4OD
1988 Custom 302/AOD
92BroncoXLT is online now
