Broncograveyard 4 point family roll cage - Ford Bronco Forum
 12Likes
post #1 of 37 (permalink) Old 04-18-2017, 12:31 PM Thread Starter
Jackson112784's Avatar
Bronco Info: 90 bronco, rebuilt 302/aod, 4inch lift, 33's, 4.10 gears trutrac front and rear
Has anyone bought this family roll cage from broncograveyard?
4pt. Family Roll Bar, Cage-Broncograveyard.com
I only drive my bronco during the warmer months and I only run a full soft top. Now that I have two young boys I am looking to add a rear roll cage for extra protection/ peace of mind when the boys are back there. I won't be off roading my bronco with them in the back. More so mall crawler roll protection.
My main question is what to expect for shipping. I see they have a pallet fee. I am looking for some feed back on someones order experience. Or recommendations of a shop in metro Detroit that can build a cage like this at a cheaper or comparable price.
Jackson112784 is offline
post #2 of 37 (permalink) Old 04-18-2017, 01:31 PM
stephen92bronco's Avatar
Bronco Info: 92 EB, 351W, Auto, Softopper with 4pt Cage, Remote Start and locks
I have it, ordered from JBG. Shipping was about $200 from what I remember. They should be able to give you a quote for shipping if you call them.
It's good quality. Just make sure they also weld in support plates and not weld it directly to the bed. The supports will slice through the bed easily in case of roll-over. Also have the shop spray liner it before install. Much easier than trying to seal it post installation.
92 EB Full-Size, 351W. Autolocking hubs for 4WD. Softtop Conversion. 4pt Rollcage. Custom painted interior.
stephen92bronco is offline
post #3 of 37 (permalink) Old 04-18-2017, 01:42 PM Thread Starter
what do you mean about the support plates? Did you have it shipped to your home? How smooth was that delivery process?
post #4 of 37 (permalink) Old 04-18-2017, 02:47 PM
dash_cam's Avatar
i think @aschessla has one.
it's fun to do bad things
my "build" thread
dash_cam is offline
post #5 of 37 (permalink) Old 04-18-2017, 02:56 PM
panabax's Avatar
I have the same cage and I also run a soft top full time. I don't remember what the shipping cost was, but JBG will provide a shipping quote. It is truck shipped. I picked mine up at the old dominion freight terminal. The guys there just put it in the back of my Bronco with the top down and I drove right off like that. I do not remember if it was cheaper than having shipped to the house or just easier since I did not have to worry about being home.
You can (or at least used to be able to) order the same cage direct from the manufacturer, Proto Fab. They are in Arizona. Proto Fab Specialty Parts For Bronco and Jeep
Baxter
My family came to this country from Texas!
panabax is offline
post #6 of 37 (permalink) Old 04-18-2017, 04:18 PM
Ford Hoarder
I had mine delivered to work with loading dock. Was only $75
Just a warning you may wait to get it threw JBG, just the way they work. Protofab is also slow to deliver sometimes too.
CrazyBRONCOguy is offline
post #7 of 37 (permalink) Old 04-18-2017, 06:39 PM
I believe the jbg cages are made in Arizona and are like 4 weeks lead time.
Shipping to the terminal or a business with forklift or dock is always cheaper than curbside delivery.
The plates referenced above sandwich the bed floor inbetween the cage mount and the "plates" under the bed. In theory and for max safety, the bottom plate should be braced and welded to the frame. The cage feet should then be bolted to these braced plates. Think of them like rigid body mounts.
6000 pounds of Bronco pounding on 4 squares of 12 sq. in. each will push through the very thin body and proceed to squish anything in the back in a rollover.
itwasFREE!!!! likes this.
BigBlue 94 is offline
post #8 of 37 (permalink) Old 04-24-2017, 02:16 PM
aschessla's Avatar
I ordered mine direct from Protofab. Shipping to a residence is not cheap... I also had seatbelt bungs welded in so that I could use the shoulder belts. So something to consider if you have a 92-96.
I had no issues working with Protofab but be sure you clarify you want the Family Cage. They sent me the wrong one but covered shipping round trip and fixed the issue. I love mine. Keep your eyes on the May FOTM for pics and some neat things I did to mine!
aschessla is offline
post #9 of 37 (permalink) Old 04-24-2017, 11:54 PM
Ewgoetz's Avatar
I have it on my old totaled bronco, still need to get around to swapping it over. But mines I had added provisions to put the stock seatbelt to it and coated it in Linex.
Ewgoetz is online now
post #10 of 37 (permalink) Old 04-28-2017, 06:22 PM
Trent the Bad's Avatar
Bronco Info: 1985 351 auto
how much did they cost and do they have to be wielded together when you get it?
TtB
1985 Bronco 351 auto
Trent the Bad is offline
post #11 of 37 (permalink) Old 04-28-2017, 06:40 PM
aschessla's Avatar
You can ordered it welded but it has to ship truck freight.
post #12 of 37 (permalink) Old 04-29-2017, 05:33 PM
Thanks
post #13 of 37 (permalink) Old 05-01-2017, 11:53 AM
I just received my 6-point family cage from All4funoffroad.com for my 1993. I chose the fully welded (with seat belt bungs) "6 Point Roll Cage #BR12" and had the complete cage shipped directly to my powdercoater here in Atlanta. I picked it up this Saturday and test fitted it. Fit is perfect, beautiful very well done cage and Bob at All 4 Fun Offroad was very helpful. My powdercoater also did a perfect job. I am very pleased all around. I chose this unit because it was the best option in my opinion. I liked the design better AND it was all around cheaper than the JBG/Protofab option. Also, JBG/Protofab WOULD NOT weld in the rear seat belt bungs, which would have left me with more work to get done. All 4 Fun's offering was solid, out the door, so for me, the best option.
When I have time to remove the rear interior trim and carpet to do the final fitment, etc. I'll do the install. For now, I removed the cage and put it in my basement. I need to get all the proper hardware to install and will do that soon. Attached below are a couple of pictures from this weekend for reference.
ID:	103409   Click image for larger version
ID:	103417   Click image for larger version
csilvestri is offline
post #14 of 37 (permalink) Old 05-01-2017, 04:23 PM
phobos2deimos's Avatar
I've been thinking about the Protofab cage, but the cage you got seems like a great deal. ~>$900 for a six point, fully welded. Shipping would probably be $2-300 though. Been considering welding it myself to save on shipping. Thanks for the link.
phobos2deimos is offline
post #15 of 37 (permalink) Old 05-01-2017, 05:03 PM
deathmobile2's Avatar
It looks like it is in backwards and does not look as good as the protofab one at all.
MATCHBOX likes this.
deathmobile2 is online now
post #16 of 37 (permalink) Old 05-01-2017, 05:53 PM
Pretty dang similar, although I'm admittedly uneducated in this.
What's the rub, the support bar going to the main hoop (protofab)/rear hoop (all4fun)? If so, I'm wondering if a diag tube from the top of the main hoop to intersect the rear support would be an improvement?
All4Fun
Protofab
post #17 of 37 (permalink) Old 05-01-2017, 09:04 PM
To each his own. My take on it (as well as a few friends who reviewed the styles) was that the supports on the rear of the All 4 Fun cage would better support the rear overhead hoop from collapsing in toward the rear seat. The JBG/Protofab unit looks like the rear hoop portion was an afterthought to the whole design. To me, the All 4 Fun cage should work better in conjunction with the existing body of the Bronco (*Note that the above Chevrolet comparison has no OEM rollover protection other than the windshield frame, where the Bronco has the full roofed-in cab as OEM).
post #18 of 37 (permalink) Old 05-02-2017, 06:28 AM
92bronco73's Avatar
Bronco Info: 92 XLT 5.8L 4" tuff country lift, 35" BFG
Has anyone bought the unwelded and actually welded it themselves. I want to know how difficult of install it is.
92 5.8XLT,
A work in progress
Anthem, AZ
92bronco73 is online now
post #19 of 37 (permalink) Old 05-02-2017, 08:04 AM
Ford Hoarder
If you do the front section the protofab one supports that better as the tubes line up with the rear ones. The protofab one also is welded to the plate that holds the rear most tubes, instead of the fender wells, not sure which part of the floor offers the most support. They maybe pretty equal.
Really a combo of both would be best, but you are only going to get so much protection from one that just goes to the floor anyways, so maybe does not really matter. There are things I like and dislike on each of those. The prices are pretty fair on the all4fun stuff though. Even if had to go in with some extra tube.
dash_cam likes this.
post #20 of 37 (permalink) Old 05-02-2017, 11:44 AM
aschessla's Avatar
I know the Protofab cage works well my the Softopper, which is why I went with it but I didn't know there were alternatives. Adding the seatbelt bungs cost me like $40 installed but it is nice to receive it done however...
