Hydraulic Assist Steering - Ford Bronco Forum
 8Likes
  • 2 Post By helirich
  • 1 Post By Quader1
  • 2 Post By BoulderBronco
  • 1 Post By helirich
  • 1 Post By 445 FE Bronco
post #1 of 11 (permalink) Old 05-17-2017, 11:31 PM Thread Starter
MidlifeCrisisUndrWay
CDA 455's Avatar
Question Hydraulic Assist Steering
Anyone do a hydraulic assist steering ram set up before?
PSC has a kit for our rig (PSC Motorsports 80'-96' Ford w/gas engine cylinder assist kit - PSC-SK400x) :
Where would the stationary mount for the hydraulic ram go?
I had one one my '99 F-350 and it was sweet!
μολὼν λαβέ
CDA 455 is offline
post #2 of 11 (permalink) Old 05-18-2017, 09:21 AM
helirich's Avatar
I would think you would have to mount it to the pax side frame rail. The moving end would have to be ne'er the Pittman connection. I don't like that much because all your force still goes through all the joints. (Except the Pittman)
If your not getting enough power, how about a saganough swap?
In any case, if you do it, (or the sag swap) I would also change to the HD tie rods. There's a thread on that.
445 FE Bronco and CDA 455 like this.
helirich is online now
post #3 of 11 (permalink) Old 05-18-2017, 10:13 AM
JAN. '17 F.O.T.M.
Quader1's Avatar
Bronco Info: 78 W/400
I have it and love it , but I have a solid front axle. One end of the cylinder is on the axle itself and the other on the tie rod.
I can put the front tire up against a curb in a parking lot , turn the wheel against it and it will move the truck over turning the wheel with 1 finger.
JGR likes this.
Quader1 is offline
post #4 of 11 (permalink) Old 05-18-2017, 10:15 AM Thread Starter
CDA 455's Avatar
My current PS unit is dying; whining really bad that even I can hear it (I'm 70% deaf).
I thought of upgrading to a Saginaw PS pump with the possible hydraulic assist ram set up.
Would a Saginaw PS pump give a big enough boost over an OEM PS pump?
Regarding TRE:
I'm in the process of doing the TRE flip. I'm using Kingfish999's thread for reference and info.
The Moog part #s he posted are for F-250/350 and E-350s . Huge; compared to the stock Bronco TREs.
μολὼν λαβέ
CDA 455 is offline
post #5 of 11 (permalink) Old 05-18-2017, 04:17 PM
BoulderBronco's Avatar
Hydraulic assist is an awesome upgrade for trail/street trucks running big rubber. We are working on a kit right now. Hope to have it available in a month or so. We already offer a ported RedHead steering box. That will be an option with the kit. We are designing it for use on the Saginaw pump, not the stock pump. So you would have to do the Sag swap to make it work. The stock PS pump is difficult to make work due to the reservoir restrictions. Not to mention it's a crappy pump. The Sag pump is a great upgrade either way and allows for a well designed kit.
It is also for straight axle setups at this point. We may try to make it work on the TTB but there are numerous issues with that.
Green Turd and CDA 455 like this.
BoulderBronco is offline
post #6 of 11 (permalink) Old 05-18-2017, 10:42 PM
helirich's Avatar
Could do it like this.
http://www.pirate4x4.com/forum/attac...s-swingset.jpg
CDA 455 likes this.
post #7 of 11 (permalink) Old 05-18-2017, 10:54 PM Thread Starter
CDA 455's Avatar
THAT is a simple yet stupendously awesome set up !
Thanks for sharing .
μολὼν λαβέ
CDA 455 is offline
post #8 of 11 (permalink) Old 05-19-2017, 09:39 AM
helirich's Avatar
Looking at that pic, makes you wonder why they made I "high steer". The bars could have been straight if they went to the bottom of the knuckle arm. (Stronger)
CDA 455 likes this.
post #9 of 11 (permalink) Old 05-19-2017, 01:34 PM
The old Ford 68-72 ram kits were problematic, that series never came with PS. I also have monkeyed around with the rams on 60S Fords like Failanes and such, steering racks are the accepted go to to fix those. As stated a ram puts a whole lot of stress on components, most hardcore setups mount to the axle much like a steering stabilizer.
CDA 455 likes this.
post #10 of 11 (permalink) Old 05-19-2017, 04:11 PM Thread Starter
CDA 455's Avatar
After studying the pic, I noticed something.
How would I mate the ram to the pitman arm and factory replacement TRE?
Can a AM heim joint thread into the pass. side TR?
μολὼν λαβέ
CDA 455 is offline
post #11 of 11 (permalink) Old 05-20-2017, 07:26 PM
Mounting the ram to the pitman arm would be tricky/custom but it could be done, just not with the standard TRE's. You would want a through hole, high angle TRE. The TRE would mount under the pitman arm, the hydraulic ram rod end would mount on top, and you would secure it all with a 3/4" high grade bolt. There are probably other obstacles to this but in general this should work. I would definitely get a heavy duty pitman arm if your drilling it out 3/4". The bigger problem, which someone else eluded to, is the fact that your ram is pushing against your fame and not the axle. I wouldn't run a hydraulic assist like that if you can avoid it.
That steering setup is pretty sweet from the looks of it. A few things I would change but overall it looks good.
I'm not crazy about the bent arms as Helrich mentioned. If they used a better/higher angle joint they could have probably avoided that. But due to the geometry (and the budget looking joints) I don't think there is another option, for that design anyway. If the arms came into the knuckle at a steeper angle, the rod ends wouldn't have the deflection needed when the suspension droops. You would get very bad binding.
TTB setups are a bitch to get a good steering system on. Throw hydraulic assist in and it's a major endeavor to get it to work right and not screw your frame up.
