I have been PMed by several people of late about the specs of my engine. Instead of awnsering all 20PM’s I will make one thread and give people the link if I am asked again.
The Engine was purchased from a Junk Yard for $700.00
It is a 351w from a 92 F-250.
http://fullsizebronco.com/forum/showthread.php?t=37077&highlight=GACKNAR
http://fullsizebronco.com/forum/showthread.php?t=37317&highlight=PENZOIL
Here are the short block specs.
351w, bored 30 over
Crank polished
factory connecting rods
Speed-Pro power forged pistons (844-L2446F30)
Performance speacialtys Harmonic Balancer.
The block has been decked (dont remember how much)
And It's been balanced.
It is suposed to deliver 9.5 to 1 compresion with a 64cc head.
Total short block cost $1,500.00
Pistons can be looked up here http://www.jegs.com/webapp/wcs/stor...splay?langId=-1&storeId=10001&catalogId=10002
Long block part specs.
GT-40 ”X” heads (M-6049-X303) $1,100 my cost
Crane Cams “PowerMax” cam (cam + lifter #443902) $169.95
(443901 for cam only)
Crane Cams double roller timing chain set (44993-1) $69.88
Crane Cams valve springs (99833-16) $63.88
Ford Racing roller rockers (M-6564-B351) $299.95
Ford Racing rocker arm shim kit (M-6529-A302) $8.99
Ford Racing push rods (M-6565-M332) $44.88
Melling standard pressure/standard volume oil pump (M83) $23.95
ARP oil pump drive shaft (154-7901) $16.88
ARP head bolts (154-3603) $53.99
Total long block cost $1,852.30
The previouse part numbers can be looked up here http://www.summitracing.com/
Finishing parts (so far)
Edelbrock performer 351w lower intake. (3834) $299.95
ARP Intake bolts (154-2001) $19.88
BBK 351w truck headers (35110) $369.88
Stage 8 locking header bolts (8913A) $51.95
Performance speacialtys Harmonic Balancer. (price included in short block)
351w to AOD flex plate. (Motermite # 04352) $41.88 @ Advance Autoparts
Ford Racing Tall Valve Covers (FMS-M-6582-E302P) $94.88
Accel 300+ Ferro-Spiral Race Wire Sets $79.69 (acc-7040)
BBK 70mm Throttle Bodie $179.88 (BBK-1501)
BBK 70mm EGR Plate $59.88 (BBK-1502)
Edelbrock Performer 5.0 EFI upper Intake Manifold $249.88 (EDL-3822)
Trick Flow EFI Heat Spacer Kit $61.95 (TFS-51520014)
TransGo Performance Shift Kits $119.39 (TRG-AOD)
Total finishing parts so far $1,629.24
Total build cost so far $5,681.43
Here are links to the threads with the build pics, with questions and awnsers.
351-1
http://fullsizebronco.com/forum/showthread.php?t=39919
351-2
http://fullsizebronco.com/forum/showthread.php?t=43305
351-3
http://fullsizebronco.com/forum/showthread.php?t=43851
351-4
http://fullsizebronco.com/forum/showthread.php?t=43910
351-5
http://fullsizebronco.com/forum/showthread.php?t=44365
351-6
http://fullsizebronco.com/forum/showthread.php?t=44411
351-7
http://fullsizebronco.com/forum/showthread.php?t=54709
351-8
http://fullsizebronco.com/forum/showthread.php?t=57203
351-9
http://fullsizebronco.com/forum/showthread.php?t=65733
351-10
http://fullsizebronco.com/forum/showthread.php?t=67484
351-11
http://fullsizebronco.com/forum/showthread.php?t=67586
351-12
http://fullsizebronco.com/forum/showthread.php?p=908527#post908527
351-13
http://fullsizebronco.com/forum/showthread.php?p=958764&posted=1#post958764
351-14
http://fullsizebronco.com/forum/showthread.php?p=973974&posted=1#post973974
351-15
http://fullsizebronco.com/forum/showthread.php?t=76361
351-16
http://fullsizebronco.com/forum/showthread.php?t=79175
351-17
http://fullsizebronco.com/forum/showthread.php?t=79846
Hp/Torqe estimations by Desktop Dyno.
A sound clip of the engine running.
Any further questions can be posted here I guess.:toothless
351w, bored 30 over
Crank polished
351-1
351-2
351-3
351-4
351-5
351-6
351-7
351-8
351-9
351-10
351-11
351-12
351-13
351-14
351-15
351-16
351-17
