Official Seat Thread: Let's talk seats & seat covers --> - Page 4 - Ford Bronco Forum
 23Likes
post #61 of 308 (permalink) Old 01-26-2007, 08:50 PM
Originally Posted by Torvald View Post
Anyone know what seat have the pull out leg support thingy? I could really use a set of those :)
Lincon Mark VII's had them in the LSC models.
Poolboy-'88 LSC is offline
post #62 of 308 (permalink) Old 02-27-2007, 06:11 PM
csa900's Avatar
Bronco Info: 1991 Bronco 5.8 EFI E4OD 56mm BBK TB, Flowtech headers, bassani y pipe, Flowmaster, Punisher vb
Explorer Seats
I found some Explorer seats in the junk yard. I think from a '95. Re drilled the holes in the front of the brackets and reused the original studs, then drilled new holes in the back brackets and used new bolts. I ran power to both seats so all functions. The color matches perfectly with the factory console and trim.
Name:	1991 Ford Bronco Porkchop 014 resize.jpg
csa900 is offline
post #63 of 308 (permalink) Old 02-27-2007, 07:15 PM
itfliesitdies870's Avatar
Bronco Info: 1993 Eddie Bauer 351W 4" superlift & 35s. Flowmaster 40 series, Bassani Y pipe and stuff
Does anyone have any seat covers they could refer to me that will protect my leather from getting muddy and wet? I figured I'd want to cover my seats up before fishing season starts in april or duck season next fall for when I get in the truck and dont feel like taking my waders off?
itfliesitdies870 is offline
post #64 of 308 (permalink) Old 02-27-2007, 07:20 PM
All I got for X-Mas was a
Joes93Bronco's Avatar
Neoprene from Wet Okole or another manufacturer. Try sportsmansguide.com too they may have something a little cheaper.
Neoprene is the way to go for true waterproofing. Cabela's sells some stuff too I think.
Baby Girl
My SuperCrap Site
-Plato
Joes93Bronco is offline
post #65 of 308 (permalink) Old 02-27-2007, 07:22 PM
Here's a link to cabelas:
Cabela's Seatcovers
Link to Sportsmansguide:
Sportsmansguide Seatcovers
Baby Girl
My SuperCrap Site
-Plato
post #66 of 308 (permalink) Old 02-27-2007, 07:43 PM
SnowTom's Avatar
Bronco Info: 90 EB 5.8 e4od
Rear entry with Explorer seats
A question for those who have installed Explorer power seats. Were the seats from a four door explorer or and explorer sport? If they were from a four door explorer, do the seats slide forward far enough to make entry to the rear seat area easy? Do any of the explorer seats tilt forward.
SnowTom is offline
post #67 of 308 (permalink) Old 02-27-2007, 08:17 PM
Bronco Info: 1989 Eddie Bauer
Originally Posted by Sixlitre View Post
I rebuilt the foam in my 86' Eddie Bauer seats... It gets rid of the toilet feel they get as they age (your @$$ touches the sides, but not the middle). for next to nuthin' and they feel great now. All it cost me was a box full of hog rings and a pair of hog ring pliers, some 1" foam and the special non-melting spray can of foam rubber adhesive. Cut the hog rings and remove the seat bottom covers. Cut the center piece for foam, then the side bolsters, spray them and the original seat foam, wait 4 minutes and stick em on. After that pull the covers back over and install the new hog rings. While you're in there, tighten all bolts, especially the floor and track to seat bolts.
I did this not just cause' Iz cheap, but also because precious few other seats out there are as large or have armrests.
Dirt cheap, damned easy and darned effective. Sixlitre
Pics?
I know my limitations, I just don't know when to quit.
- HED P.E.
FordBroncoLover is offline
post #68 of 308 (permalink) Old 02-27-2007, 08:26 PM
I never even thought of looking at the sportsmans guide site. Thanks a lot Joe
post #69 of 308 (permalink) Old 02-27-2007, 08:47 PM
hmthesing's Avatar
Bronco Info: '89 EB 302 C6
Not sure what model mine were from, but tilting the seat forward and scooting it up all the way allows fairly easy access to the back from the passenger side. My driver's seat tilt lever is broke, so I haven't been able to test that side, but my old seats didn't tilt far enough either, so I never had anyone getting in on that side.
Also, I removed my center console, so it's really easy to just climb over the front seat and crawl through the middle.
hmthesing is offline
post #70 of 308 (permalink) Old 02-27-2007, 08:51 PM
No prob
My F250 seats had a small limiting strap on each seat bracket. Once I removed it both seats slid all the way to the dash and steering wheel respectively. I don't know if I got any pics or not. Look on your brackets and see if there is one. I havent had any probs since takin it off, so I don't really know its purpose
Baby Girl
My SuperCrap Site
-Plato
post #71 of 308 (permalink) Old 02-27-2007, 08:58 PM
ffmike's Avatar
Bronco Info: 95 bronco 351, 33"BFG's allterrain, 4" stage two Superlift, K & N filter, Ignition upgrade
Does anyone know where you can buy Replacment foam and OEM fabric. I would like to replace the foam and the fabric on my drivers seat. I spent the last hour searching on the internet and came up empty.
ffmike is offline
post #72 of 308 (permalink) Old 02-27-2007, 09:23 PM
csa900's Avatar
My seats are from a 4 door. they do go forward enough (along with pulling the recline forward) to make entry/exit work. I'll post a pic if you want. However, my kids are impatient because it takes about 5-6 seconds to power slide them forward, so they just climb in and cut through the middle.
csa900 is offline
post #73 of 308 (permalink) Old 02-27-2007, 09:25 PM
I've noticed that everyone with factory seats, only has armrests on the inner side of the seat. What years had them on both sides of the seat? My '80 had em...they were sooooo comfy!
Will
wsigo is offline
post #74 of 308 (permalink) Old 04-05-2007, 06:13 PM
Bryce's Avatar
Bronco Info: '90 302cid XLT
seat recline
Can't get either of the seats to stay upright. Mine has a very slight recline but the passenger seat goes almost all the way back when someone is sitting there. Can't figure out the spring on either side of it. Chilton's doesn't have anything to say. Anything I can do without getting new seats?
Bryce is offline
post #75 of 308 (permalink) Old 04-05-2007, 06:28 PM
Ford Hoarder
I put a set of Subaru WRX seats in mine. Got the pair at a end of the year swap meet for $170
Thosehave been in there for about a year and a half and no wear yet. I think the first thing to go will be the driverside butt boulster from getting in and out.
CrazyBRONCOguy is online now
post #76 of 308 (permalink) Old 04-05-2007, 06:37 PM
Weld em up solid in the most comfy position for you and wait for em to break and buy different seats anyway. It's what I did. Of course you lose some access to the backseat that way.
Baby Girl
My SuperCrap Site
-Plato
post #77 of 308 (permalink) Old 04-05-2007, 11:34 PM
Practicing Infidel
Sixlitre's Avatar
Originally Posted by FordBroncoLover View Post
Pics?
Nope
I didn't own a digital back then, but that ought to tell you how long it lasts. I did those seats 5 years ago and they're still comfy and supportive.
Sixlitre
My Superford site
Sixlitre is offline
post #78 of 308 (permalink) Old 04-06-2007, 07:14 AM
Bronco Info: 1987 BKO Eddie Bauer
http://www.shearcomfort.com
I am getting the neoprene/camo combo. Found this site in my search.
Emil J. Meadors
1987 Eddie Bauer, 302 EFI, Stock gears, AOD, MSD Superconductor wires, Accel 48k coil, Hedman Shorties, 31" tires...she's a comin' along
Mods in progress - 3G upgrade(done), PMGR starter upgrade(done), Headlight lens restoration (the hard way), final part of the ignition upgrade...blah, blah, blah
moemeadors is offline
post #79 of 308 (permalink) Old 04-06-2007, 08:28 AM
Designated Tranny Killer
JD_Bronco's Avatar
Bronco Info: Sold--'89 FSB, 2" lift, lots 'o' lights, custom bumpers, exhaust, intake, stereo, other stuff
those are alot cheaper than the Wet Okole ones i was gonna get
~Dave~
1998 Jeep Wrangler, 5.5" lift, wheels, tires and all the other cool stuff.
1997 Dodge Ram 5" lift, 35"s, 396 stroker, stereo, and some random things
JD_Bronco is offline
post #80 of 308 (permalink) Old 04-06-2007, 08:30 AM
Lots of selection and all seats are covered for all years...can't ask for much more.
Emil J. Meadors
