i don't think that tying the box into the frame by way of the TTB crossmemberon is a good idea. you want to add stiffness and strength to the frame, tie the frame horns together.
I want the brace to stop the steering box from pushing the frame away from the crosmember when turning right.
This truck had the same problem.
I told them several times that the problem was the lower rivet was loose, they refused to listen claiming the frame was just weak and needed to be tied together. So they welded a 2" tube from frame horn to frame horn and then plated the frame where the crack was. I asked them to ditch the
"Xtreme" drop pitman arm and build a brace for the box that connected the snout to the crossmember, they ignored me.
Just a year or two later and it looked like this.
the crossmember that has the axle beams bolted to it has enough stress on it with the TTB drop brackets, this would only add more work for it, and i wouldn't take that chance.
It already had the job of holding the frame together, I am simply adding another connection.
that pipe doesn't look beefy enough.
What would be sufficiant?
I think it is 1.5" with a 3/16" wall, but I'm not sure. I'll measure it next time I work on it.
Remember, the only stress on it will be tension.....That's it. It's not going to see any other force, the frame takes care of all of that. It's sole purpose is the keep the snout of the steering box from moving away from the cross member to the left hand side during a right turn. There will be no rotational forces on it.
that pipe just doesn't look like it would be up to the job. remember, this isn't just holding the LF frame horn from moving, there is going to be more stress because it already does move
I plan on welding the frame back to the crossmember, this is to prevent it from happening again. (Hopefully)
Nor do i see any real triangulation.
This is where I think folks are confused about how the box moves and where the forces are at. This will "Create" a triangle where one does not exist now between the steering box/frame and the crossmember. And, all the force on the brace, with the exception of the U-bolt, will be in tension.
Then again, I could be completely wrong and be building a candidate for the scary steering page. If so, I promise to paint it a nice neon color so it stands out good.:toothless
This shot isn´t quite good, but I think´ll do. It´s a bent tube, welded to a metallic angle one of it´s and ends bolted to the engine crossmember, the other one (as you are planning to) goes to the exit of the gearbox
Hope that helps :thumbup
Does it work?
