vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > Technical Write Ups
Old 10-03-2008, 12:13 AM   #41
Fireguy50
can I go to bed yet?
Fireguy50's Avatar
Bronco Info: faster than your's
what does it mean "Top Ball Joint Nut 100ft/lbs (Mininum)"
My Craftsman Digitork® Torque Wrench goes up to 250ftlbs, so how far should I go?
Ryan McCormick
RJM Injection Tech
My Bronco
Ford Fuel Injection.com Technical Library
Parts replacement is not auto repair, if you can’t diagnose, don’t open the hood!
Fireguy50 is offline   Reply With Quote
Old 10-03-2008, 12:16 AM   #42
stangmata
The Stang-o-matic Baby
stangmata's Avatar
Bronco Info: 1995 Bronco 302 E4OD XLT
More than 100ft-lbs. Crank it down to 100ft lbs and then turn it a bit more to get the cotter pin in. As long as everything is tight and seated properly, I see no issue.
stangmata is offline   Reply With Quote
Old 10-03-2008, 06:51 PM   #43
Steve83
Perspicuously Pernickety
Steve83's Avatar
Bronco Info: '83 Custom w/'95 4.9L & EB paint
It adjusts both caster AND camber, but it's mainly there for camber.
Steve83 is offline   Reply With Quote
Old 10-03-2008, 10:05 PM   #44
phycon
phycon's Avatar
Bronco Info: 96 XLT FIRE RIG
I recently did this on my '96 and you do not have to remove the abs sensor...
If you follow the wire up a little into the engine compartment there is a disconnect. worked for both sides.
"A penny for my thoughts? ... It ain't worth it!"
Originally Posted by SigEpBlue View Post
phycon just won this thread.
phycon is offline   Reply With Quote
Old 10-03-2008, 11:17 PM   #45
Fireguy50
Fireguy50's Avatar
torque Spindle Nuts to 50-60 ftlbs
Old 01-12-2009, 06:33 PM   #46
Iolaus
Seeking Tanelorn
Iolaus's Avatar
Bronco Info: Black '90 351 Bronco XLT, 6" Pro Comp stage II, 35" BFG ATs, K&N filter, Warn Premium Hubs
Quick basic question here, Should I put the jack stands on the ttb arms? The frame is going to be at or above the reach of my stands, and it looks to me like Stang is using the ttb.
Jeff
I've tried soul-searching, but in doing so I've found some really dark places.
If I've offended you, click here
When all else fails... mutiny.
No matter how fast light travels, darkness got there first and waited for it.
Iolaus is online now   Reply With Quote
Old 01-12-2009, 07:25 PM   #47
Iolaus
Seeking Tanelorn
Iolaus's Avatar
Never mind. I see now how he put jack stands on top of cinder blocks. Alright, frame it is.
Old 01-12-2009, 07:30 PM   #48
stangmata
stangmata's Avatar
You could use the TTB but the frame is a much better choice.
The only reason the jack and jack stand were under the TTB arm was to keep the suspension compressed so the axle was at a better height for me to work.
Old 11-09-2009, 01:16 PM   #49
Bro43
Skank Tank
Bro43's Avatar
Bronco Info: 93 bronco XLT
Originally Posted by KyleQ View Post
Jack the truck up until the tire comes off the ground. Grab the tire at 9 & 3 and try to twist. If you have any play, BJ's may be needed. You can also grab the tire at 12 & 6 to see how your wheel bearing or spindle nuts are doing.
In the countless times of tearing my truck apart, my truck has the notched spindle nuts that require the spanner wrench on the right side; looks like a castle. My truck is a 95.
Originally Posted by sewiv View Post
Lift the front, put it on jackstands. Grab a front wheel top and bottom, and try to rock it. If you have much play at all top to bottom, your ball joints are suspect. Get someone else to rock the wheel top to bottom while you look at your ball joints. Any motion you can see is almost too much.
Ok, which is correct? Top to bottom are ball joints or side to side? My drivers side I grab top to bottom and there is play. Side to side is fine. So ball joints right? Not bearings?
Bro43 is offline   Reply With Quote
Old 11-09-2009, 02:50 PM   #50
Late Model Man
Needs VTEC
Late Model Man's Avatar
Bronco Info: 95 EB, 351, E4OD, 6" lift/ 35"XT, 4.10s, custom bumper w/ winch, e-locker
You need to grab it at 6 and 12. If you grab it at 9 and 3 the steering will move (obviously giving you a false reading). If the there is play at 6/12 you need to find out where it's coming from. Either bearings or the balljoints. It will be visible what is moving but you might need a second pair of eyes to see it from the back.
SuperFord 95 Bronco-6" lift, shackle flip, 4.10s, E-locker, homemade y-pipe, bumper, winch, more.....
Late Model Man is offline   Reply With Quote
Old 11-09-2009, 06:08 PM   #51
Bro43
Skank Tank
Bro43's Avatar
I only had one wheel off the ground. Steering wasnt going anywhere. Movement was 100% at 6 and 12. Ill take a closer look.
