vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
Old 11-07-2009, 04:32 PM   #1
78brncoxlt
78brncoxlt's Avatar
Bronco Info: 78ranger xlt 400.040 edelbrock int 2" lift 33"bfg C6 dana 44 np-205 9" orig. paint & int.no rust
air fuel mixture 2150
does this sound right. I used a vacuum gauge to adjust the air fuel on my 2150.The instructions said to keep turning the screws out until highest possible vacuum is achieved.If I do this I end up 5 turns out.Then it idles at 800rpm in neutral and 650 in gear.now the idle screw has to backed off all the way and when i shut off the key it will keep running for a couple seconds.
thanks for your input.
http://www.supermotors.net/registry/17695
78brncoxlt is offline   Reply With Quote
Old 11-07-2009, 07:17 PM   #2
jopes
balls deep with my
jopes's Avatar
Bronco Info: pile of parts
they should roughly be 2 turns out.
you have something wrong with your carb, or you have a vacuum leak.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd.
Originally Posted by Ranger429 View Post
Nothing better than a piece of dark meat with some sauce on it.
Originally Posted by 95thebroncoman351 View Post
played with one of my buddies... its sick
jopes is offline   Reply With Quote
Old 11-09-2009, 07:42 PM   #3
vreference
Bronco Info: 1978 Custom, 4 Speed, 6" Deavers, James Duff Radius Arms, Shackle flip, DetroitLocker 9", Aussie D44
Mine won't even run on the idle circuit at 2.5 turns out. I think I'm closer to 5 or 6. Also, the '78 351m/400m has longer springs on the adjustment screws than other 2150s including 351w; which to my mind, seem to indicate they expected them to be farther out. Considering how well mine runs, especially at idle, I don't think there is anything wrong with it.
vreference is offline   Reply With Quote
