| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
where to get dual exhaust kit?
Thread Tools | Display Modes |
#1 |
iTrader: (1) Bronco Info: '96 Ford Bronco 5.0L 302
does anyone know where i could get a dual exhaust kit cheap?? I mainly just want the tailpipes.. and where can i find a bassani y-pipe? I heard they were discontinued..
| Sponsored Links | |
Advertisement |
#2 | |
Shotgun, Rifle, and a 4WD
![]() Join Date: May 2005
iTrader: (2) Bronco Info: 96 XLT 302/E4OD & 90 EB 302/AOD
bassani- autoanything.com Sign up for their email offers and you can find coupon codes. Also google "autoanything coupon codes". Only the aluminimized y pipes were discontinued. They still sell stainless steel.
#4 |
iTrader: (0) Bronco Info: 1992 F350 4x4 5.8L
It has been the general consensus around here a dual exhaust is not the best setup if you do any offroading. If you are looking to save some $$ go with the proven single exhaust setup. You will not sacrifice any potential power gain with the single exhaust many have used here on this forum. As noted before the cheaper aluminized Bassani pipe is no longer produced, the stainless version is still available with and without a converter. Toss on a high flow cat if needed, a muffler of your choice and then a Maremont or Dynomax mandrel-bent 3" aluminized tailpipe. Looks through some of the threads for the details and sound clips.
FWIW I purchased most of my exhaust component from Wundercarparts.com, Summit and Magnaflow Planet. All three vendors provided excellent service and pricing. |
#5 |
Sway's jealous of my
I'd find an exhaust shop close by that will work with you. I'd make sure its a fairly clean place, check out the owners ride and what it's exhaust is like, go over what type of bending they do, etc.
I'm a fan of keeping it local. I'm also a fan of dual exhaust. ![]() |
#7 |
iTrader: (0) Bronco Info: 1996 Bronco XLT 5.0, Warn Hubs,Custom RedNeck Sticker, Custom Catback, K&N Cold Air
Depending on where you live keep your eyes open for the small local shop. They have the best prices and do the best work. I had a high flow cat put in with a single in dual out Full Boar muffler and all 3" pipe with 3.5" tips all done for $250. Thats with the cost of the cat and muffler and tips. All is fully welded.
#10 |
![]() Join Date: May 2007
iTrader: (2) Bronco Info: 1994 fsb. 5.8 e40d 2inch susp 33" MT'S with cepek wheel. Custom bumbers.
I run a 3 in magnaflow with dual 2.5's out. all stainless and I'm getting ready to switch to a single 3 inch in and out.
#11 |
Trying to snake a true dual exhaust around the transfer case and everything else underneath the truck can leave the pipes/muffler hanging too low for comfort when offroading. A good quality single 3" exhaust has been found to offer as much (if not more) performance gain as a dual. On a stock truck the biggest gain will be found from a high flow converter. Why spend more money for two of everything, figure out a good routing path when a single 3" is cheaper and easier.
Plenty of exhaust threads here on this very subject. |
#12 |
Moderator
![]() ![]() Join Date: Oct 2004
iTrader: (3) Bronco Info: 1996 EB Bronco, 5.0, E40D, Dana 44 SAS, 4.88 gears. 35" SuperSwampers
Same reason we don't run fart mufflers
-Steve My SAS Build http://fullsizebronco.com/forum/showthread.php?t=69270 3" Exhaust http://www.4x4preservation.com/forum...read.php?t=201 My SuperMotors http://www.supermotors.net/15991 4x4 Preservation 4x4preservation.com |
#16 |
Slow Noob
![]() Join Date: May 2003
iTrader: (5) Bronco Info: 1987 Ford Bronco XLT, 5.0L v8, 31" tires, stock rims, pioneer speakers, jvc stereo, etc, etc.
i have 2.5" duals on my bronco, got ran down the passenger's side then around the fuel tank and angles out behind the rear tires.
rebuilt 302 v8, c6 transmission, b-w 1356 t-case dana 44 ttb front axle with 3.55 stock gear ratio 8.8 rear with 3.55 stock gear ratio heddman headers, dual exhaust 31x10.5x15 bfg all-terrain t/a tires on stock rims, etc, etc, etc http://www.superford.org/registry/ve...x.php?vID=2947 |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
