High RPM shift AOD transmission? - FSB Forums
Register Home Forums Active Topics Photo Gallery All Albums Mark Forums Read Auto EscrowInsurance FSB Store
Old 05-01-2012, 12:42 PM   #1
19red87
Bronco Info: 1989 Bronco 5.0
Hello FSB, I have a 1989 5.0 with the AOD transmission this transmission was rebuilt 2 years ago by AMCO and has only had 600 miles put on it sence. The problem is it is not shifting into gear properly. The RPM goes high and then shifts, it does not slip and goes into all gears but is taking too long to shift. I bought the bronco this way and was hopping I could get some direction on some things to check out before pulling it out. Thank you for any advice you have to offer.
19red87 is offline   Reply With Quote
Old 05-01-2012, 12:47 PM   #2
Gacknar
The Anti Yam!
Gacknar's Avatar
Bronco Info: 86 Bronco XLT 357w/AOD
Does it do this on all upshifts?
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears
Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT
My SuperMotors Site - My Engine
The Greatest Thread on FSB
Gacknar is offline   Reply With Quote
Old 05-01-2012, 03:29 PM   #3
riccnick
riccnick's Avatar
Bronco Info: 1986 Ford Bronco Eddie Bauer 351W
Do you mean it shifts into gear slowly, like from P to D or from N to D (or to R)?
Or do you mean that it shifts slowly into gears 2-4 when driving?
Either way first thing to check is fluid level at operating temp. Red, no bubbles is key.
-Nick
1986 Ford Bronco Eddie Bauer 351W H.O. 4x4 C6 Auto
2012 Subaru Impreza 2.0i Premium
Dearly Missed: 2010 Toyota Tundra DC Trd Off-Road 5.7 V8 Flomaster 50-Series Dual Exhaust
riccnick is offline   Reply With Quote
Old 05-02-2012, 03:45 PM   #4
19red87
Thank you for the replies! It does it all the time while driving. For example when starting from park it will drive fine but take too long to shift into 2nd gear, the RPM's just keep climbing until she will finally shift. If I let off the gas she will shift into second gear at that time as well. There are no hard shifts or slipping at all just takes WAY to long to go into the next gear. I checked the fluid and it was clean and red, does appear to have too much fluid though.
Old 05-02-2012, 03:49 PM   #5
Gacknar
The Anti Yam!
Gacknar's Avatar
So it's not neuatralling out, it's just shifting at a high RPM.
At part throttle what RPM is it shifting at?
Old 05-02-2012, 03:50 PM   #6
19red87
I have not checked to see if the bronco does it in all gears as I have been to afraid to drive it at any high speeds in fear of damaging the transmission anymore than it is. I read a post that was recomending to install a new "TC" which is located by the throttle body I believe. it's a rubber part and the replacement is brass, I might try that this weekend. Any information and direction is much apreciated!!!!! Thank you
Old 05-02-2012, 04:00 PM   #7
Gacknar
The Anti Yam!
Gacknar's Avatar
Trucks don't have the rubber T.V. Cable bushing, that's a car thing.
It does sound like an overly adjusted T.V. cable, but with it adjusted that much it should shift rather hard.
Old 05-02-2012, 04:34 PM   #8
riccnick
riccnick's Avatar
Sounds like they put a shift kit in it. My Chevy that I use for plowing does this. It will shift at like 2500-3000 rpm under extremely light throttle. But it sure makes plowing a lot easier. You may just have to get used to it.
-Nick
Old 05-06-2012, 01:59 AM   #9
norcal_bronco
norcal_bronco's Avatar
Bronco Info: 1995 bronco 5.0 e4od warn hubs
my two cents
i tried pulling codes and taking my truck in to different transmission shops,
i finally figured out that my timing was off.
norcal_bronco is offline   Reply With Quote
Old 05-06-2012, 11:00 AM   #10
miesk5
miesk5's Avatar
Bronco Info: 96 XL 5.0 E4OD, Man Xfer/Hubs
yo,
Failures/Erratic Shift Operation; "...Failure to complete proper diagnosis and verification of repair prior to and after transmission replacement — failure may have been caused by components external to the transmission. Ensure that the transmission cooler/s, cooler lines and cooler hoses are not blocked, restricted, leaking or damaged. See the appropriate Workshop Manual. Incomplete or incorrect transmission cooler system flushing procedures followed. Failure to replace Oil-to-Air (OTA) cooler on affected applications. Vehicle wiring harness damaged or chafed — closely inspect the harness for any damaged areas, particularly on modified/fleet vehicles. Correct any concerns of damage, corrosion or routing and ensure there are no DTCs using the correct scan tool. Ensure that the harness plug has no damaged pins, cracks or corrosion — correct as necessary. Engine performance issues can adversely affect transmission operation — be sure to correct any drivability concerns and/or codes during course of repair..."
Source: by fordparts.com
1 to 2 Upshift Troubleshooting
Source: by Jem270 at http://www.supermotors.net/registry/media/556353_1
Trouble Shooting, COMPREHENSIVE; "...from the AOD service manual..."
Source: by duanemyhre at http://www.sccoa.com/forums/showthread.php?t=30511
scroll to "Rough/Harsh/Delayed 1-2 Upshift"
Possible Source(s):
§ Improper fluid level.
Action(s) to Take:
§ Perform «fluid level check» .
Possible Source(s):
§ Poor engine performance.
Action(s) to Take:
§ Tune engine.
Possible Source(s):
§ TV linkage--misadjusted (high TV)/damaged. All shifts will be harsh/delayed.
Action(s) to Take:
§ Adjust linkage. Service as required.
Possible Source(s):
§ Main control pressure too high.
Action(s) to Take:
§ «Control pressure test» . Note results.
Possible Source(s):
§ Governor valve sticking.
Action(s) to Take:
§ Perform «governor test» . Service as required.
Possible Source(s):
§ Valve body bolts--loose/too tight.
Action(s) to Take:
§ Tighten to 9-11 N-m (80-97 lb-in)
Possible Source(s):
§ Valve body dirty/sticking valves.
Action(s) to Take:
§ Determine source of contamination. Service as required.
Parts Break-Out Diagram w/Nomenclature
Source: by tcsproducts.com http://www.tcsproducts.com/media/1/T...matic_2011.pdf
USN & DoD Planner (ret)
THANKS to ALL WHO SERVE!
my broncolinks.com was "disturbed"; but some sections are archived @ [url]http://web.archive.org/web/20121009110424/http://www.broncolinks.com/index.php
select a LINK, Right Click & Hit Properties; copy the second HTTP address; paste in a new browser window or Tab to see original page
miesk5 is offline   Reply With Quote
Old 05-29-2012, 03:43 PM   #11
19red87
UPDATE
I have an update on the high RPM shifting issue. I read so much on this site about the TV cable, I went to the local junk yard and pulled one off another bronco. When I compared it to the one on my truck I noticed the spring on my old one behind the clip on top appeared to be streched more than the new one. Took about 5 minuntes to switch them out. Took it for a drive and it shifts PERFECT!!!! I lucked out on this one but I recommend anyone with a similar issue try the same as I paid 10.00 for this part and if I took it into a shop it would have cost a fortune. Thanks FSB members for all your post's and information!
Old 05-29-2012, 04:09 PM   #12
bigbarf48
bigbarf48's Avatar
Bronco Info: 1994 XLT 5.8 351w 33 Courser A/Ts
Mine does the EXACT same thing as you were describing. Ill see if i can grab a TV cable my next JY trip. Thanks!
EDIT: Unless the e4od would require a different solution?
1994 XLT
5.8 351w
33 Courser A/ts
160k
bigbarf48 is offline   Reply With Quote
Old 05-30-2012, 01:46 AM   #13
Steve83
Troll
Steve83's Avatar
***EDIT***
The post I was referring to got deleted.
Steve83 is offline   Reply With Quote
Old 05-30-2012, 09:56 AM   #14
helirich
helirich's Avatar
I have not messed with a TV cable since I had my 88' Bronco. (ten years ago) But I remember adjusting it was eazy. Adjust it one way and it shifted lower, the other higher. I adjusted it at the throttle body. It was quick. I found that I liked it to shift at 4000 rpm with the pedal on the floor. (it would shift much lower when you didnt have it floored) I dont think it hurts anything when it shifts to high. But I have heard that if you make it shift too soon, it can cook the tranny.
helirich is offline   Reply With Quote
Old 05-30-2012, 10:20 AM   #15
Gacknar
The Anti Yam!
Gacknar's Avatar
E4OD's do not have a T.V. cable and are electronically controlled.
Completely different animal.
Old 05-30-2012, 04:28 PM   #16
bigbarf48
bigbarf48's Avatar
Well my e4od does exactly what his aod did. How would this be solved on an e4od?
1994 XLT
5.8 351w
33 Courser A/ts
160k
Old 05-30-2012, 05:31 PM   #17
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
fluid change both dropping pan changing internal filter and torque converter drain plug. atleast a 11x7 trans cooler and a remote trans filter. And to pull codes to see if there is any stored codes.
GetBent4x4 is offline   Reply With Quote
Old 05-30-2012, 05:59 PM   #18
bigbarf48
bigbarf48's Avatar
Ive changed the fluid and filter already. Ive got the towing package so i know i have the larger cooler, do i have a stock remote filter or would i need to add that?
1994 XLT
5.8 351w
33 Courser A/ts
160k
Old 05-30-2012, 08:52 PM   #19
Steve83
Troll
Steve83's Avatar
The only stock ATF filter on these trucks is in the pan. Read the last part of this caption:
  FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
