yo
The warning chime/buzzer module produces a repetitive chime or steady buzzing sound for the following conditions:
Key-in-ignition warning with driver's door open.
Fasten safety belt warning.
Headlamp-on warning (available on some models).
The warning chime/buzzer sounds when the headlamp switch is in PARK or HEAD and the driver's door is open, and continues to sound until the headlamp switch is moved to OFF or the door is closed. When the headlamp switch is in PARK or HEAD, power is supplied through Circuit 14 (BR) to the module. When the driver's door is open, the driver's door lamp switch (13713) is closed and power is supplied to the module through Circuit 159 (R/PK)
See attached 96 Warning Chime/Buzzer System Wiring Diagram
should be = to your years
Headlamp Switch Connector
Pin Number Circuit Circuit Function
B1 38 (BK/O) Headlamp Switch Feed from Fuse Panel
B2 195 (T/W) Headlamp Switch Feed
I 294 (W/LB) Fused Accy Feed No. 3
IGN 137 (Y/BK) Radio Switch Feed
R 14 (BR)
Headlamps ON Signal to Chime/Buzzer
H 15 (R/Y) Headlamp Dimmer Switch Feed
DN 484 (O/BK) Audio Liquid Crystal Display
D1 54 (LG/Y) Interior Lamp Switch Feed
D2 55 (BK/PK)
706 (GY)a Cargo Lamp Switch to Cargo Lamp
Battery Saver Feed
a Remote keyless entry only.
Warning Chime/Buzzer Module Connector
K20261-C below
1 14 (BR) Headlamps ON Signal to Chime/Buzzer
2 159 (R/PK) Driver Door Courtesy Lamp Switch to Chime/Buzzer
3 85 (BR/LB) Safety Belt Switch to Chime/Buzzer
4 158 (BK/PK) Key-in-Ignition Switch to Chime/Buzzer
5 57 (BK) Ground Circuit
6 450 (DG/LG) Safety Belt Warning Indicator Lamp Feed
7 640 (R/Y) Warning Lamps Feed
