tranny not engauging
816 views 3 replies 3 participants last post by  Kingfish999
truck has a C6 transmission
truck fires up i put it in drive no movement then after it sits in drive for about 30 seconds it finally engauges after its engauged the first time will go back into drive no problem til motor cools down again tranny is not slipping or showing any other issues also yes i checked my fluids. also it will go into reverse no problem
#2 ·
Sounds like it cold be a valve body issue, possible loose filter/filter port (snout).
Ever suck through a straw with a hole? Takes a while to get the fluids through past the air hole, but once its does and if there's constant draw, it will always provide pending on fluid level.
tranny filter might be clogged. mine would do weird stuff when it was clogged. when i replaced it i was amazed by the crap in it. it might be good to do the valvebody while your down there tho. sucks to waist all that money on tranny fluid. good time to get a shiftkit also for the truck, it helps ALOT
