Go Back   FSB Forums > Other Forums > General Discussion/Builds - Bronco and Wheeling related.
Thread Tools Display Modes
Old 03-23-2009, 01:33 PM   #81
crawler
Custom Fabricator
crawler's Avatar
Bronco Info: 1978 Bronco 351m, full cage SOLD!!!!!! now 73 CJ 5
reassembly
Heads done. I had them hot tanked and milled .020 then I lapped the valves in
New rings
New bumpstick (Comp Cams 268h grind)
All finished and buttoned up. Lots of work but very happy
There was a lot of sandblasting involved i that intake manifold. (it had been painted and corroded real bad)
crawler is online now   Reply With Quote
Old 03-23-2009, 02:06 PM   #82
Black93Bronco
Black93Bronco's Avatar
Bronco Info: 89 F350, 460, ZF5, Project Street/Mud Truck
Looks good
2000 Saab 9-5 Aero: Daily Driver.
1989 F350 Lariat: 96 Front End, 460, ZF-5 Speed, 4:10's, Comp Cam, Valve Job, K&N Intake, Heddman Headers; soon to be lifted on 38.5's
1978 Bronco Custom: 460, Bored .040 Over, L&L Mounts, Edelbrock Carb, Performer Intake, Cam, Noisy Gears, C6 w/ E4OD Internals, 4 Pt. Roll Bar, 4" Lift, 36's, Soft Top.
Black93Bronco is offline   Reply With Quote
Old 03-23-2009, 04:03 PM   #83
Hopper
Hopper's Avatar
Bronco Info: Stockish 93 5.8L, E4OD, BW1356; 79, 400/T-18/NP205, D44/9"
bling bling!
Looking sharp as hell
Hopper is offline   Reply With Quote
Old 04-19-2009, 10:35 PM   #84
crawler
Custom Fabricator
crawler's Avatar
Got the frame plating all finished up. Its getting down to doing just a bunch of welding
And got the plates cut out for the back. And welded up the 'caps' on the end of the frame tubes
Old 05-02-2009, 07:42 PM   #85
Rigman
Rigman's Avatar
Bronco Info: 85 FS Bronco 351w,C6,Atlas 4, D60 35 spline outers Ried knuckles , 14 bolt,5.38, Detroits,42"TSL
If I had your talent at your age I wouldn't be working were I am today.
If I can just get it out of here I can fix it.
Rigman is offline   Reply With Quote
Old 08-02-2009, 01:53 AM   #86
crawler
Custom Fabricator
crawler's Avatar
double post
Old 08-02-2009, 01:54 AM   #87
crawler
Custom Fabricator
crawler's Avatar
Been awhile since Ive updated this. The frame is all painted and assembled. Everything is coming togather.
Axles done painted and bolted up, shocks are on, springs cleaned and painted.
Also tore apart the C4 tonight. Big thanks to my dads friend John who builds Spirit racings transmissions. He taught me more than I could remember on how automatics work and who invented the gearset concept of the 3 speed.
Gonna put in the shorter shaft, instal a shift kit and some stronger thrust washers to help it hold up. The trans was rebuilt 4 years ago
Also tore the dana 18 apart and started to clean it. Took a trip to Border Parts and bought some new parts for it. Left with a little less money
Ran the brake lines and fuel line
Transfer case all rebuilt.
Transmission all rebuilt with a street strip shift kit and some other stuff
Then put the trans and engine in tonight
And the best part is that it runs. Crappy video but you can here it
MOV03386.flv video by 4wheelinbro - Photobucket
Old 08-26-2009, 03:52 AM   #88
crawler
Custom Fabricator
crawler's Avatar
Been working hard on this thing trying to get body work done. Haven't really had internet for a little bit due to remoldeling. heres a bunch of updated pics of all the work thats been done to the body.
welded up all the holes and made pieces to fill in around the tranny tunnel
RUST!
Welded up the trans tunnel
Starting on the back
The firewall as of tonight. pretty much done
Pass side is getting there
Front fender done
Hoping to have it painted in the next few weeks
Old 08-26-2009, 04:02 AM   #89
stan the man
Mentally in Cancun.
stan the man's Avatar
Bronco Info: 1996 Ford Blazer. Lifted, locked, and loaded. Where's the Zombies?
Amazing work.
California Bay Area off road UC4x4.com
stan the man is offline   Reply With Quote
Old 08-26-2009, 06:36 PM   #90
Hopper
Hopper's Avatar
Love that thing.
Old 08-27-2009, 02:18 AM   #91
crawler
Custom Fabricator
crawler's Avatar
Thanks guys. Todays progress
Hood all wet sanded ready for prime and paint
Old 08-28-2009, 09:47 PM   #92
Dustin
Diesel Gynachologist
Dustin's Avatar
Bronco Info: Yes I drive a Toyota
nice work kid...cant wait to see it finished
Ford Senior Master Technician
http://www.superford.org/registry/ve...x.php?vID=1309
"The existence of flamethrowers is proof that someone, somewhere, said to himself, "I want to set those people over there on fire, but I don't feel like walking over there to do it."
Dustin is offline   Reply With Quote
Old 10-05-2009, 12:00 PM   #93
crawler
Custom Fabricator
crawler's Avatar
I drooped out my front end and the driveshaft needs 4 1/2" of plunge to go through 12" of travel. My stock shaft only has 2 1/2". Wasn't going to work but I had two front shafts, so I cut them up and made my own.
I had to turn down one of the yokes to fit inside the tube
The splined shaft cut off. Mine was teflon coated(bonus! lol)
Had to grind down the edge of the yoke to fit
Sleeved the 2 yokes together with a piece of 1 3/4 .120 wall with 4 7/16" plug weld holes
Ground the two spline portions of the shaft to a point and put them in angle with plenty of clamps
Welding it up
Time to turn the weld down in the lathe
Welded up
Splines all lined up
All finished with the slip yoke
Plenty of travel
Old 10-05-2009, 12:00 PM   #94
crawler
Custom Fabricator
crawler's Avatar
Heres a little teaser.
Old 10-05-2009, 01:44 PM   #95
Ole Nasty
Ole Nasty's Avatar
Bronco Info: 1994 XLT 5.8, 37" Nittto MGs
Just see the red x. I read through the rest of the thread though and you do amazing work. That rig is gonna be tons'a'fun when done. Awesome.
Ole Nasty is offline   Reply With Quote
Old 10-05-2009, 10:29 PM   #96
crawler
Custom Fabricator
crawler's Avatar
Pic should work now.
thanks
Old 10-05-2009, 10:41 PM   #97
fordfreak93
Bronco Info: 1979 bronco frame with an 83 ranger body
i would love to know how to do driveshafts, i can build hellashish engines buts thats it you gotta lota talent bro
fordfreak93 is offline   Reply With Quote
Old 10-05-2009, 10:43 PM   #98
Hefty
Need a Bumper?
Hefty's Avatar
Bronco Info: 93 Bronco 7in SAS 38's 4.56 and rear detroit front e-locker, 72 bronco under construction
I painted my old 86 cj7 that color. Beautiful job man
HeftyFabworks.com
HeftyFabworks.com ---------ColoradoFullsize.com
Hefty is offline   Reply With Quote
Old 10-06-2009, 11:40 AM   #99
stangmata
WTF,O
stangmata's Avatar
Bronco Info: 1995 Bronco 302 E4OD XLT
Looks awesome!
stangmata is offline   Reply With Quote
Old 10-06-2009, 04:18 PM   #100
jam0o0
jam0o0's Avatar
Bronco Info: 95, 5.8, E4OD, D60, ford10.25
wow. the hot rod build quality shines through in everything. very nice.
95: 351w, E4OD, BW1356, D60, 10.25, ARB, detroit, 5.13, 38" boggers
http://www.supermotors.org/vehicles/...il.php?id=9014
'93 F250 7.3 turbo, ZF5, 2wd, excab, long bed.
jam0o0 is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
