Go Back   FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
Thread Tools Display Modes
Old 08-31-2007, 11:25 PM   #21
Steve83
Steve83's Avatar
Bronco Info: '83 Custom w/'95 4.9L & EB paint
Did you have BOTH of them jumpered at the same time? You have to complete the circuit thru the ABS sensor (VSS in the diagram) for the PSOM to get a signal.
If you DID, and the speedo didn't work, then it's not the 4WABS module - it's the sensor, the PSOM, or the wiring between them.
But I'll send it if you want - it's your property.
Old 08-31-2007, 11:49 PM   #22
kemicalburns
Never Done
kemicalburns's Avatar
no i did not jumper them all at the same time. i will try that tomorrow then.
94 XLT 5.8/E4OD Trans-go stage II
6" Stage II ProComp,35x12.50BFG/MT
4.88 f (aussie) / r (open) / Custom Sliders
JBA headers,Custom Y pipe hi flow cat & Full 3"
http://www.supermotors.net/vehicles/registry/17069
kemicalburns is offline   Reply With Quote
Old 09-01-2007, 12:15 AM   #23
Steve83
Steve83's Avatar
Don't jumper them ALL together. Jumper both pairs at the same time, but keep the 2 jumper wires separate from each other.
Originally Posted by kemicalburns View Post
pins 22 & 21 are for the vehicle speed sensor... the psom comes in on pins 14 & 39 looks like. which of these should i connect up.
You can jumper 14 to EITHER 21 or 22, and jumper 39 to the other (doesn't matter which way). You're trying to get the ABS (VSS) signal from the sensor directly to the PSOM. Look at that diagram again.
Just for clarity: jumper 14 to 21, & 39 to 22 (low numbers, high numbers).
Old 09-02-2007, 02:39 PM   #24
kemicalburns
Never Done
awesome, steve we are in business. jumping those like you said worked and the speedo was working properly. so the anti lock brake module is bad, so if you would please send that i would sure appreciate it.
thanks alot for your help.
Travis
Old 09-02-2007, 07:04 PM   #25
Steve83
Steve83's Avatar
It'll go in the mail Tuesday.
Old 09-03-2007, 01:51 AM   #26
kemicalburns
Never Done
can i drive with the module out and just those pins jumped or would it be dangerous? my abs light was on before the module was pulled so i wonder if my abs worked properly to begin with?
thanks
Travis
Old 09-03-2007, 01:59 AM   #27
Steve83
Steve83's Avatar
Yes, you can drive. The ABS doesn't normally do anything anyway.
Old 09-03-2007, 10:38 AM   #28
kemicalburns
Never Done
very good,thank ya sir
Old 09-08-2007, 11:45 AM   #29
kemicalburns
Never Done
Well thanks to steve83 for all his troubleshooting guidance and the anti lock brake module i was able to purchase from him. this has fixed both my speedo issue and now the abs light is off as well.
Thanks steve
Travis
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
