R134a Red or Blue Orifice Tube - FSB Forums
Thread Tools Display Modes
Old 09-01-2007, 07:44 PM   #1
Redmonaz
I did a quick conversion on my AC system last year. Just grabbed a conversion kit from Autozone and put it in. I did not change the receiver dryer, orifice tube or draw a vacuum on the system. It worked OK, but the charge leaked out by this year. At the begining of the summer I refilled but it has leaked down and I had to top it off already. We've got another month or so of 100 plus, so I'm going to go ahead and do it right.
The compressor was changed over a few years back (6-7) and is rated for
R12 or 134A. I picked up a cheap venturi vacuum pump ($9) and gauge set ($39) from Harbor Freight. I know they are not the best, but will work for me. I am going to do it right and put in a new Receiver Dryer, change the O-Rings and Orifice Tube. My question is this (and yes I searched) which color of Orifice Tube do I use? Red, Blue, or the cheap variable one from Checker? I know a smaller size is recomended for a conversion. For GM conversions they recomend using a Ford blue Orifice Tube, but the red is slightly smaller. Right now I plan on using the red. Does anyone have any experience, or does it matter? My Bronc is an '89 with a 302.
Thanks in advance!
Redmonaz is offline   Reply With Quote
Old 09-01-2007, 09:11 PM   #2
tonythetiger57
tonythetiger57's Avatar
Bronco Info: 1984 Ford Bronco XLT 408 W
Mine in my 84 is blue...
1984 FSB XLT, 408 Stroker ,8 inch lift, SAS, powdercoated frame, ram air hood, c6 tranny, shiftkit w/deep pan, 4:11 gears, detroit locker in rear. New pics in about a year when its all together.
TONY
tonythetiger57 is offline   Reply With Quote
Old 09-01-2007, 09:27 PM   #3
92builtbronco
F*ck 'em all
92builtbronco's Avatar
Bronco Info: 1992 Bronco XLT 351, E40D, York OBA, 3G Alt, 3" body lift, 4" susp lift, 4:56s, 36"x15.5 Dick Cepeks
I just rebuilt my a/c system last week. Iirc, according to the Ford parts catalog 90-96 are red. That being said, I pulled what was left of a blue one out of mine and replaced it with a red one. It works great now.
It had been converted to 134 by the PO.
92builtbronco is offline   Reply With Quote
Old 09-01-2007, 10:09 PM   #4
SigEpBlue
Satyr of the Midwest
SigEpBlue's Avatar
Location: Ida & Grand Rapids, Michigan, a.k.a The Unemployment Capital of America
Bronco Info: 1993 EB, 5.8L, BIO0 MAF, GT40Ps, Mustang cam, GT40 Intake, Custom Headers, Moates QuarterHorse
Go red. Blue is too large and will perform badly, i.e. not cool down the evaporator. R134a needs a larger pressure differential, and using a smaller orifice tube is how you do it. Don't bother with the variable orifice; it's overpriced and just another thing to fail, IMHO.
SigEpBlue
Wheelin' across Michigan from Ida to Grand Rapids, baby!
Nemo nisi per amicitiam cognoscitur -- No one learns except by friendship.
Originally Posted by Adlai Stevenson
Isn't it conceivable to you that an intelligent person could harbor two opposing ideas in his mind?
SigEpBlue is offline   Reply With Quote
Old 09-04-2007, 10:28 PM   #5
scott2007
Bronco Info: 1989 bronco eddie bauer edition 4x4,
i have an 89/302 also and just swapped my AC about 2 months ago; the book called for the blue oriface. Just make sure you vac it down good and be sure you dont charge it on an extremely hot day or it will not fully charge. you may get a vapor lock in the system also. as i said though make sure you vac it down good. if you use the venturi vac let it vac for about an hour to remove all of the oil and moisture.
scott2007 is offline   Reply With Quote
Old 09-20-2007, 03:34 PM   #6
Redmonaz
I wanted to add an update so if anyone finds this with a search they will know the final outcome.
I finaly got the system properly swaped to 134 and it works great. You can't have it blow directly on you, after a couple of minutes its too cold!
I used the red orifice tube. From my research the red or blue would have done the job, but the red is what was used in newer trucks designed for the 134A. I had to buy a large kit of O-Rings ($20) to make sure I had all the ones I needed (it costs $7 in gas to run back to the parts store). It turned out I needed 2 large ones for the compressor that were not in the kit, another $2. I put in four 12 oz cans of R134A (2.50 ea. On sale + rebate) and 1 can of oil ($10). A new receiver dryer ($40) and a red orifice tube
($5).
I also bought a set of gauges ($40) a venturi vacuum pump ($10) and the tool for the orifice spring clamp ($5) from Harbor Freight.
I opened all of the connections, removed the orifice tube, and blew out all the lines with a compressor. Then I changed out the receiver dryer, orifice tube, and replaced all the O-Rings. Using the new gauges and vacuum pump I drew a vacuum on the system for about 10 minutes and closed the gauges and went in to dinner. 30 min late it was still holding a vacuum so I hooked up the vacuum pump and drew another 20 min of vacuum. It sucked in almost one can of R134A on its own. I then cranked it over and added one more can of R134 then the can of oil and then the remaining 2 cans of R134.
Total cost $85 in parts and $55 in tools. That includes enough O-rings for 10 cars! Would I do it again? YES! It was very straight forward and simple! What I wish I would have known before: 1) The harbor freight scissor type tool for the spring clamp is a piece of junk and does not work. I had to grind the edge so it would get under the spring. Pay the money to get a good one, even if it is only one size. 2) You can get the orifice tube out by blowing air into the condensor opening, but put a towel over the opening so you don't launch it into your neighbors house!
The system is not showing any signs of leaks and I'm sure it will work great next year. I may not own it to make sure though. I'm picking up another proect car and we don't need 5 cars for 2 drivers.
Old 09-20-2007, 03:47 PM   #7
ScorpionBoy
crank trigger
Bronco Info: 94 XL M5OD, 5.0, Ghetto K&N, 130A G3
i thought you were supposed to add oil to the different parts then pull the vacuum.
ScorpionBoy is offline   Reply With Quote
Old 09-20-2007, 04:16 PM   #8
Redmonaz
I think the Ford compressors take the oil directly. My compressor was replaced a few years back and looks different than what I've seen pictured on here. I assumed it was a standard after market compressor. I could not see where to add the oil directly and I thought if I put it in the hose openings I would vacuum it out. I could be wrong, but it seems to run smoothly.
You may not post replies
Forum Jump
