labor time for a brake job? - FSB Forums
Thread Tools Display Modes
Old 09-06-2007, 07:18 PM   #1
jackhart
search, you #$%@! noob
jackhart's Avatar
Bronco Info: broncoless!
anyone work at a dealership or repair shop have access to this kind of info?
just wondering what the book time is for a remove and replace rotors and brake pads...disc brakes all around.
it's actually for my 05 rubicon. i have my replacement rotors and pads, and was going to do the job myself, but i am missing a few things to do the job.
i was quoted 2.8 hours of labor (at $95 per) by my local gas station, which i just cannot figure. take wheel off - 5 lug nuts. take off aluminum wheel spacer - again 5 nuts. remove caliper - two bolts. slide off old rotor and replace with new rotor. remove brake pads from caliper, c-clamp piston, insert new pads. replace caliper, lube bolts with caliper grease. replace wheel spacer. replace wheel. bleed.
repeat 3 more times.
i was figuring no more than an hour? an hour and a half tops? am i off base here? they swear this is what the alldata book says and actually how much time it takes.
Dave
- Karma is a boomerang -
jackhart is offline   Reply With Quote
Old 09-06-2007, 07:21 PM   #2
Mudd_Slinger92
Mudd_Slinger92's Avatar
Bronco Info: 1992 Ford Bronco XLT
I would say a little under 2 hours tops. I think they quoted you 2.8 because their charging you to shave your old rotors which you arent having done. When i go in to work tommorow I'll look up what we'd tell you on labor. But I say 2 hours.
When in doubt...FLOOR IT!! // 92' Bronco XLT 5.0 *GT-40 Heads, ALL Roller, ALL new, summit headers!* 6" RC lift 36" TSL Radials // -Joey
Click my supermotors
http://www.supermotors.net/getfile/592685/fullsize/dscf0029.jpg
Mudd_Slinger92 is offline   Reply With Quote
Old 09-06-2007, 08:20 PM   #3
bronco1
Bronco Info: 90 Bronco
In our shop the time for replacing the brake pads,servicing the caliper slides and deglazing(power sanding) the rotors is 2.7hrs.Extra .8hrs to replace the 4 rotors.
bronco1 is offline   Reply With Quote
Old 09-06-2007, 09:09 PM   #4
bnkrtstk
No avatar required
Bronco Info: Mods don't have Broncos silly
2.8 sounds reasonable. I't's porbably 1.4 for each to R&R rotors, which includes pad labor. They might try to hit you up for extra time because of your wheel spacers. $95/hr is not bad for your area either.
If you shoot me an email at work I will check the labor guide in the morning.
Bring it down, I'll do it for a Sterling
95 XLT Stock
bnkrtstk is offline   Reply With Quote
Old 09-06-2007, 09:09 PM   #5
bnkrtstk
No avatar required
For slip on rotors? Do you point a gun at them or tell them you have one?
95 XLT Stock
Old 09-06-2007, 09:42 PM   #6
rightofway
has no skidplate
rightofway's Avatar
Bronco Info: 1990 5.8l on 33" BFG A/T, warn hubs
DIY
rightofway is offline   Reply With Quote
Old 09-06-2007, 10:36 PM   #7
FordBroncoLover
Bronco Info: 1989 Eddie Bauer
I think 2.8 sounds reasonable. Tell em you only have like 250 to spend on the labor and I'm sure that they will help you out if you are cool about it.
I know my limitations, I just don't know when to quit.
- HED P.E.
FordBroncoLover is offline   Reply With Quote
Old 09-06-2007, 10:46 PM   #8
jackhart
jackhart's Avatar
trust me, i want to do it myself.
i got as far as taking the first wheel off, then i ran into issues getting my wheel spacers off, the nuts are on the threads with some loctite, they are being a bitch. i have a nice torquey 1/2" impact gun for that, but my regular 1/2" sockets will not fit on said gun. i even purchased a nice one-person bleeder in anticipation of doing the job, too...
i am also quite pressed for time lately, been doing the mr. mom thing with a 4 month old while my wife is working. so i don't have too much time to dick around with this.
Dave
Old 09-06-2007, 11:05 PM   #9
rightofway
has no skidplate
rightofway's Avatar
strap the kid into the carseat and teach em how to do a thing or two, i don't get why your chrome sockets won't fit your imact, 1/2" is 1/2"
Old 09-06-2007, 11:10 PM   #10
DakotaBronco84
DakotaBronco84's Avatar
Bronco Info: 84 Bronco, 302, c6, np208, 9inch, ttb d44, 33x12.50's
Michell says 0.9 hrs for each front rotor and 1.0 hr for both rear rotors. So that makes 2.8 hrs. It's nice to have access to that program at home!
84 Bronco 302 fuel injected, C6 w/lower 1st and 2nd gears, np208, 33x12.50, 9 inch, D44, 4.10 gears, detroit true track front, air locker in rear, full MSD ignition w/revlimiter, fiberglass dash inserts for Autometer gauges, covered in bedliner.
DakotaBronco84 is offline   Reply With Quote
Old 09-06-2007, 11:35 PM   #11
jackhart
jackhart's Avatar
that's what i thought, too, 1/2" is 1/2". i'll try to grab some pix later and post em.
thanks for the info, at least what my guy was telling me sounds more credible now.
Dave
Old 09-06-2007, 11:55 PM   #12
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
use heat to loosen up the loktite. it works wonders.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 09-07-2007, 12:07 AM   #13
ScorpionBoy
crank trigger
Bronco Info: 94 XL M5OD, 5.0, Ghetto K&N, 130A G3
yep, heat that locktite out. sometimes a breakerbar is better than the impact gun so try that too.
ScorpionBoy is offline   Reply With Quote
Old 09-07-2007, 07:42 AM   #14
bnkrtstk
No avatar required
Put Addison in the Jeep and bring it down. I need some more dirt in my eye.
Old 09-07-2007, 08:43 AM   #15
scarface50
scarface50's Avatar
Bronco Info: No longer have a bronco, just hanging around
If bnkrstk is serious about lending a hand, Im not far from Landsdale and would be happy to lend a hand.
scarface50 is offline   Reply With Quote
Old 09-07-2007, 08:51 AM   #16
sewiv
i like monkeys
Bronco Info: 1994 XLT 5.0, MSD coil/cap/rotor, SpiroPro wires, Ford Racing tranny cooler, PermaCool filter, 3G
I'd have to say, 3 hours sounds pretty reasonable to me.
Sandy
sewiv is offline   Reply With Quote
Old 09-07-2007, 09:08 AM   #17
bnkrtstk
No avatar required
Dave knows I am serious, and he also knows how to get to my house. We lifted his Jeep in my driveway.
http://forums.bucknakedoffroad.com/i...p?topic=1037.0
95 XLT Stock
Old 09-11-2007, 08:40 AM   #18
scarface50
scarface50's Avatar
Well then let me know if you need some help. I finally have some weekends free.
Old 09-11-2007, 09:35 AM   #19
jackhart
jackhart's Avatar
thanks for the help offers. i got my new 1/2" sockets today.
as soon as it stops raining i'm gonna give this a go. again.
i'm a little nervous about bleeding the brakes, as i've never done it before. i know i can probably get away with not bleeding them, but i want to. i got this speed bleeder from griot's that is supposed to hook up to the compressor and make it easy for one person. i suppose if i F it up, the gas station is right down the street. downhill, that is.
Dave
Old 09-11-2007, 10:14 PM   #20
silent one
silent one's Avatar
We get 1.9 hrs an axle,meaning 1.9 for front 1.9 for rears total 3.8. I would def. heat the bolts alittle to loosen the loc-tight it does work.
silent one is offline   Reply With Quote
  FSB Forums > Other Forums > Anything Else
You may not post replies
Forum Jump
