Could a Bad Starter solenoid drain the battery ? - FSB Forums
Thread Tools Display Modes
Old 10-08-2007, 11:16 PM   #1
allcruisen
FSB Pimpster & Recruiter
allcruisen's Avatar
Bronco Info: '95 302 XLT
Could a Bad Starter solenoid drain the battery ? I have two Batteries in Jrs. Bronco, a red top and a deep cycle blue top...
Yesterday, The Bronco was completely dead...
I was wonderin if a Bad Starter solenoid or a bad ignition switch could cause this?
Thanx in advance,
Allcruisen
Vote for FOTM
VOTE for TOP 4X4 SITE
"DEATH BEFORE DISHONOR"
allcruisen is offline   Reply With Quote
Old 10-08-2007, 11:19 PM   #2
chebbykiller
Convicted Drunk Dialer
chebbykiller's Avatar
Bronco Info: '78 Bronco Custom - 305 L6, ZF 5-speed, NP205, D44, 9"
I dont see how either could be drawing anything from the battery while you didnt know about it...
Supahmotahs
"Whatís more chickenshit than ****ing with a manís automobile? I mean, donít **** with another manís vehicle." - Vincent Vega
Originally Posted by SigEpBlue View Post
Take your skirt off, get some jeans on, and chop that shit off with a saw.
chebbykiller is offline   Reply With Quote
Old 10-08-2007, 11:23 PM   #3
allcruisen
allcruisen's Avatar
I am just trying to get and Idea of watt could be draining the Batteries...
I saw a post {While searching} that mentioned a bad ignition switch coulddrain the Battery...
PS New Alt. Also putting out 14 Amps. Batteries are less the a Month old...
Allcruisen
Vote for FOTM
Old 10-08-2007, 11:28 PM   #4
Ranger429
Moderator
Bronco Info: 79 Bronco, 47 Binder
Put a test light in between the POS post on the battery and the POS cable going to the solenoid. Make sure the doors are closed and the hood light is off. If the test light light's up you have a short somewhere. Start pulling fuses till the test light goes out. More than likely it won't be the solenoid. A bad set of diodes in the alternator will drain a battery down.
Originally Posted by 351w500 View Post
My sister in law is 3 months pregnant and next week I'm gonna shove a loaded .357 up her coochie just to familiarize the kid with weapons !
Ranger429 is online now   Reply With Quote
Old 10-08-2007, 11:28 PM   #5
chebbykiller
Did the draining coincide with the new alt?
Supahmotahs
Old 10-08-2007, 11:32 PM   #6
allcruisen
allcruisen's Avatar
Yes as a matter of fact it did start when I installed the new alternator...
Thanx Guys, I will test it tomorrow and Ranger I fogot that a bad diode in the alternator can drain the battery...
Allcruisen
Vote for FOTM
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
