| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
TSM Disc brake kit for D60
#1 |
scrounger extrordinaire
iTrader: (0) Bronco Info: 79 460 6" coming soon...39.5s, D60/D60 ARB/Detroit w/ 4.88s
ok i bought it used, painted it up and bolted it on. it was just that easy. remove axle shafts, lock nuts and drum. then 4 bolts on the backing plate and undo the brake line. it all bolts right up and lines up great. on caliper did have a casting that i had to grind off. minimal effort. i would rather grind the caliper than bracket. i wanted to get pics, but i didnt go get film and my cousin was asleep so i couldnt borrow his. its really easy and well made. but if you can find the brackets elswhere, you could save money or get just the brackets and braided lines from TSM. i will get some after the fact pics.
take a look at TRUCK my 79 custom. 6" front, 4" rear, 460, 37s, 8 lug conversion. F&R discs. this season, i will have the D60/D60 installed, rear detroit and front ARB with 4.88s and 39.5 IROKs on hummer double bealocks, hydro assist and crossover steering a wise man once said " better to keep your mouth closed and appear foolish than to open it and remove all doubt" if you sit by the river long enough, you will see the bodies of your enemy float by.... |
| Sponsored Links | |
Advertisement |
#2 |
press ALT+F4
![]() Join Date: Mar 2003
iTrader: (1) Bronco Info: '78 Bronco with motor, axles and stuff
I made my brackets, but the install was that easy. I used the F350 mc and booster, GM K20 calipers and Wilwood proportioning valve. Now I have brakes.
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
