Easy to build tube bumper & CHEAP - FSB Forums
Thread Tools Display Modes
Old 11-19-2007, 01:04 AM   #1
The Bucking Bronco
I wanted to see if I could make a functional tube bumper cheap and with tools that a lot of us have or have access to:
Tubing I had left over from roll cage 1 3/4 X .120 DOM
welder
Harbor freight bender (the 1 1/4 pipe die worked great )
harbor freight tube notcher (I only notched a couple of pieces so a grinder would have worked just fine)
4in grinder
I started by bending the main bar 18in from the ends
I wanted to keep it simple so I re-used the original mounting brackets
I cut and notched two 3in pieces of tube and welded them to to brackets and then attached the main tube
next I cut two 8in tubes to connect the bottom and cut two tubes to complete the outer ends
then I took a winch mounting plate and another piece of tube for the center and welded it all together.
Its not bolted on tight so its sitting about a inch low
here is what it looks like off and painted
A few extra things to add. I capped the frame for looks and I probalby will plate the crumple zones for strength.
I kept the original mounting brackets to keep it simple but when I plate the crumple zones I plan to gusset the back of the piece that is welded to the frame.
The harbor freight bender work great for just these light bends, if you had to do anything more then a few degrees I would have used a different bender.
I hope to get this completed tomorrow so I will hopefully have more pictures to come.
The Bucking Bronco is offline   Reply With Quote
Old 11-19-2007, 01:10 AM   #2
ToddACimer
Engineer
ToddACimer's Avatar
Bronco Info: 95 Eddie Bauer
some side pics would be nice
Recipient of multiple driving awards from State and Local officials.
ToddACimer is offline   Reply With Quote
Old 11-19-2007, 01:14 AM   #3
The Bucking Bronco
I will get some up tomorrow
Old 11-19-2007, 11:05 AM   #4
rightofway
has no skidplate
rightofway's Avatar
Bronco Info: 1990 5.8l on 33" BFG A/T, warn hubs
kewl
you gonna put a winch on it?
rightofway is offline   Reply With Quote
Old 11-19-2007, 11:12 AM   #5
fartman
F.O.T.M. - MAY 2014!!!
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs Daystar leveling kit
I like it.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options. 4.10 gears LSD 33" MTs First ever Stock Fullsize of the Month...
J A S N http://www.supermotors.net/registry/19528
fartman is offline   Reply With Quote
Old 11-19-2007, 11:59 AM   #6
elmo_4_vt
elmo_4_vt's Avatar
Bronco Info: '96 Bronco - 5.8ltr, 55k miles, 6" SAS
Can you show what the HF bender and notcher look like? What was the lift looking thing on the garage floor?
elmo_4_vt is offline   Reply With Quote
Old 11-19-2007, 12:47 PM   #7
Dustin
Diesel Gynachologist
Dustin's Avatar
Bronco Info: 2001 F350
not really a write up so moving here
Ford Senior Master Technician
http://www.superford.org/registry/ve...x.php?vID=1309
"The existence of flamethrowers is proof that someone, somewhere, said to himself, "I want to set those people over there on fire, but I don't feel like walking over there to do it."
Dustin is offline   Reply With Quote
Old 11-19-2007, 12:54 PM   #8
dan76
Bronco Info: Stock, low mileage, 5.0, 1989 with manual trans
Check out the Harbor Freight site...they have good pics on most of their tools. The lift lying on the floor is either a motorcycle or a RV lift. Great item to have if you're when you're fabbing steel. A neighbor built his T-bucket frame on one in his garage.
Lest we forget:
SSgt Ray Rangel, USAF
SrA Elizabeth Loncki, USAF
PFC Adam Harris, USA
dan76 is offline   Reply With Quote
Old 11-19-2007, 01:05 PM   #9
jmorriss
Enjoy my
jmorriss's Avatar
Bronco Info: '01 F150
What'd you use to bend the cage?
Originally Posted by Thomas Jefferson View Post
Those who hammer their guns into plows will plow for those who do not.
Please note that we have added a consequence for failure. Any contact with the chamber floor will result in an "unsatisfactory" mark on your official testing record, followed by death. Good luck!
jmorriss is offline   Reply With Quote
Old 11-19-2007, 01:49 PM   #10
96GreenMonster
Back in Action
96GreenMonster's Avatar
Bronco Info: Puke Green Lot's of lift and 38s with Dana 60 SAS and 10.25 Rear
thats friggen sweet
CHECK OUT MY RIDES
Originally Posted by amtarsha View Post
You're annoying me. Shut your manpleaser.
96GreenMonster is offline   Reply With Quote
Old 11-19-2007, 03:49 PM   #11
monkey4life
ford freak
monkey4life's Avatar
Bronco Info: 1990 f150 5.0 m5od
thats awesome!
monkey4life is offline   Reply With Quote
Old 11-19-2007, 04:41 PM   #12
The Bucking Bronco
Answers:
Yes I am putting a warn winch on it (hopefully today)
The lift is a bendpak scizzor lift capable of lifting 6000 LB It lifts the bronco with no problems
I have a jd2 bender for the cage
I will post some more pics along with the bender, notcher and winch later when I get it all mounted up
Here is a pic of the bronco on the lift it actually goes about a foot higher but with the garage door open i cant lift it that high
Old 11-19-2007, 04:56 PM   #13
chexmix
chexmix's Avatar
Bronco Info: '89 Bronco XLT w/ I6, 5spd, 4" D44 SAS 4.09 and 10.25 4.10 ARBs
That is pimp, man I wish I had one of those@!
Lifted '89 Ford Bronco w/ 5spd & doubler - Representing Ford's I6 Stump Pullers!
UC4x4.com * http://www.supermotors.net/9090 * Follow my SAS buildup!
Originally Posted by Hoxviii View Post
The goal here is to fix the problem, not treat the symptoms.
chexmix is offline   Reply With Quote
Old 11-19-2007, 04:57 PM   #14
The Bucking Bronco
I just noticed the bender is in that pic on the bottom right
and that lift is one of the best purchases i have made
Old 11-19-2007, 05:49 PM   #15
rightofway
has no skidplate
rightofway's Avatar
with that lift would you be able to pull a tranny or oil pan or would you end up using the lift to set the truck on high stands?
also:
hmmm, seperated at the drawing board?
Old 11-19-2007, 06:25 PM   #16
The Bucking Bronco
not the tranny but easily the oil pan
Old 11-19-2007, 07:08 PM   #17
bigbroncojeff
RIP Spring Creek Off Road
bigbroncojeff's Avatar
Bronco Info: '93 351 bronco thing
holy crap i want your lift... kudos on the cheap simple bumper... i probably wouldn't bust out the jd2 to do those minor bends either
........springcreekoffroad.com........
bigbroncojeff is offline   Reply With Quote
Old 11-19-2007, 11:10 PM   #18
The Bucking Bronco
just got everything completed
Here is a couple pics that were requested
Old 11-19-2007, 11:48 PM   #19
rightofway
has no skidplate
rightofway's Avatar
nice, looks awesome
anymore details on how you mounted the winch?
i saw the hitch mount in the first pic did you integrate that somehow or is the winch plate welded directly to the bumper?
Old 11-20-2007, 12:33 AM   #20
Revenant
Revenant's Avatar
Bronco Info: 1995 F150 5.0L 4x4, 4.88s, Detroit, 6" Lift, Deaver 5.5" Coils, Bilstein 5150, 35" BFG KM2
Dad gum brilliant!
Very well done, so suprisingly simple.
My 1995 F150 Build Thread
Revenant is offline   Reply With Quote
  FSB Forums > Bronco Discussions > Fabrication, Tools, Equipment
You may not post replies
Forum Jump
