vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > For Sale/Where to Buy > Vendor Reviews
Thread Tools Display Modes
Old 01-07-2004, 10:14 PM   #1
BoulderBronco
FSB Vendor
BoulderBronco's Avatar
Bronco Info: 93 5.8L tons of stuff
best plugs
I have always used autolite. Now that I am building a performance engine and getting a Crane Ignition I figured I should get some better plugs. What should I get or is spending $$ in this area worthless? Oh, and wires. Should I just get a cheap $30 set or are the pricey sets worth the extra $$? I never thought they were.
Chris,
93 5.8L, 6" Superlift, Superrunner Steering kit, Warn hubs, BroncoAir front winch bumper, Warn M12000 winch, BroncoAir OBA System, AGR P/S Pump, K&N custom intakes, 4.88's, Front ARB, PIAA 90 Series fog/driving lights. Owner of Broncoair.com
BoulderBronco is offline   Reply With Quote
Old 01-08-2004, 01:15 AM   #2
78bronco460
press ALT+F4
78bronco460's Avatar
Bronco Info: '78 Bronco with motor, axles and stuff
I like AC plugs, but never had a problem with Autolites. I think the platinums, splitfires, etc are snake oil. Index the plugs when you install them. I bought a set of the 9mm MSD Heli-core wires. They are excellent wires and not too expensive.
78 Bronco - 460/ZF 5 SPEED/NP203 doubler/TwinStick205/Locked D60 on a 3 link in Front/Welded D70 in Back/44" TSL's on hummer wheels
78bronco460 is online now   Reply With Quote
Old 01-08-2004, 01:24 AM   #3
Max
Who's going to hell...?
Have you talked to any engine builders for what you're going to be doing and what brand plugs they recommend? Also have you talked to the fine folks at Crane Ignition on what they're recommendations are for your engine and future modifications? If you're going to be on the pedal hard with the new engine, then you may want to consider a colder plug so that the plugs don't fall victim to high speed glazing. I've talked to guys that have built and rebuilt the 5.0L and 5.8L for the old box body Crown Vics, and they will tell you that you don't need a fancy ignition setup if your engine is largely stock...you're just wasting your money. I don't see a problem with the Autolite brand, other than you may be switching heat ranges. Only thing is that the Autolites/Motorcrafts (basic no frill plugs) will rust where as the Bosch plugs and others won't because of what they're made of.
Max is offline   Reply With Quote
Old 01-10-2004, 11:51 PM   #4
axaviere
scrounger extrordinaire
axaviere's Avatar
Bronco Info: 79 460 6" coming soon...39.5s, D60/D60 ARB/Detroit w/ 4.88s
i just use all copper no matter the brand. there are bosch all copper in there now and i am putting autolite copper in there tomorrow. after the last time everybody talked about this, thats what the general feeling was. as for wires, your crane will most likely require the same as my MSD. i think cranes wires are the same as MSD, 8.5, but blue. low resistance, high dollar
take a look at TRUCK my 79 custom. 6" front, 4" rear, 460, 37s, 8 lug conversion. F&R discs. this season, i will have the D60/D60 installed, rear detroit and front ARB with 4.88s and 39.5 IROKs on hummer double bealocks, hydro assist and crossover steering
a wise man once said " better to keep your mouth closed and appear foolish than to open it and remove all doubt"
if you sit by the river long enough, you will see the bodies of your enemy float by....
axaviere is offline   Reply With Quote
Old 01-11-2004, 06:22 PM   #5
Euclid
Bronco Info: '82
You will never see an engine in my garage without NGK plugs.
'97 Firebird Formula (daily driver)
12.2 on motor. 10.9 on nitrous.
'86 Chevy Truck
10bolt/14 bolt
4.10's, 35" TSL SX's
Euclid is offline   Reply With Quote
Old 01-12-2004, 11:14 PM   #6
Davids78Bronco
Davids78Bronco's Avatar
Bronco Info: I may be slow, but I'm expensive!
I had always wanted to give the NGKs a shot... I think I'll get a set, next month sometime
Davids78Bronco is offline   Reply With Quote
Old 01-12-2004, 11:29 PM   #7
Tomh971
Are those REAL?!?!
Tomh971's Avatar
Bronco Info: 1993, 5.8, E4OD, BW 1356 (manual), 6" off-road lights, Kenwood stereo, more to come...
Autolite double platinums are the best plug I've ever used. Splitfires are probably the worst...
"You can have my guns when you pry them from my cold, dead hands" - Charlton Heston
Support Our Troops
Tomh971 is offline   Reply With Quote
Old 01-13-2004, 09:46 AM   #8
OldBlue
OldBlue's Avatar
NGK plugs are awesome/ specially for a mostly stock ignition system. most platinum plugs are designed for an arftermarket system.
MY NAME IS BRAD! DAMNIT!
Originally Posted by ToddACimer
Usually if you pull out and then stick it back in there you can keep pumping without problems.
OldBlue is offline   Reply With Quote
Old 01-13-2004, 02:26 PM   #9
NDIXIE
NDIXIE's Avatar
Bronco Info: '95 Bronco
I used to have a little Nissian pickup and NGK is what the suggested I use. Now I use NGK in everything. My wifes Mountaineer, my motorcycle, fourwheeler and my Bronco.
NDIXIE is offline   Reply With Quote
Old 01-13-2004, 03:36 PM   #10
Tomh971
Are those REAL?!?!
Tomh971's Avatar
The only thing I usually do is upgrade the coil... Mallory or Accel... both make a good upgrade from the stock one that looks stock but definitely makes a difference... for under $40 too... add that to the double plats... and yer good to GO...
Old 01-13-2004, 03:37 PM   #11
stangmata
The Stang-o-matic Baby
stangmata's Avatar
Bronco Info: 1995 Bronco 302 E4OD XLT
NGK makes a great plug! The other plug that I use a lot is the Bosch platinums. On my Mustang I run either the NGK or the Motocraft plugs.
In a nutshell I recommend, NGK, Bosch, Motocraft for your rig. As far as wires....why go cheap? It's only money, it's made to be spend. CHA-CHING!
stangmata is offline   Reply With Quote
Old 01-13-2004, 03:41 PM   #12
OldBlue
OldBlue's Avatar
a great wire to use are the Nascar type wires. we ran them on an ohmeter and they had from 52-55 ohms of resistance, wich was lower than any other "parts store" wire we could find.
Old 01-13-2004, 04:23 PM   #13
axaviere
axaviere's Avatar
$60 MSD says 40-50 ohms per foot. $110 Taylor thundervolt says 50. lowest seems to be Moroso @ 40 ohms per foot. they are $90 for a universal kit & a whopping $150 a specific set. MSD it is
Old 02-09-2004, 08:31 PM   #14
allcruisen
FSB Pimpster & Recruiter
allcruisen's Avatar
Bronco Info: Allcruisen
NGK-UR45's & Ford Motorsport 9MM wires for about 50 bux......Oh yeah and MSD Blaster Coil for roughly 49 Bux...
AC
Vote for FOTM
VOTE for TOP 4X4 SITE
"DEATH BEFORE DISHONOR"
allcruisen is offline   Reply With Quote
Old 02-09-2004, 11:24 PM   #15
Uriah
Uriah's Avatar
Bronco Info: 1978 Ford F150 shortbed stepside
I've always used NGK in my bikes and stuff, Motorcraft in all my Fords (and Autolites in everything else). I DID try the Splitfires when they first came out, I believe they are snake oil. Didn't seem to make any improvements, other then anything else that replaced worn out plugs. I exchanged them for my usual set of Motorcrafts, and milage/seat of the pants felt exactly the same.
BTW, I never bother to index the plugs in any of my street rides, but I do my bracket car (where every little bit helps).
Uriah is offline   Reply With Quote
Old 02-10-2004, 03:01 PM   #16
96Bronc
96Bronc's Avatar
Bronco Info: 96 XLT - 351W
Have to agree with the NGK fans. The only way to go. I run them and Taylor wires in the Bronco and my Impala SS. Taylor wires are a great way to go if you want a performance wire without the perfomance price.
96 XLT 145K
351W w/ 2nd E4OD
4.10 gears
Bassani headers,Y-pipe & catback; K&N FIPK; 4" BDS suspension w/ 15x10 589 eagle wheels and 33x12.5 F/S Destination M/Ts; TJM Bumper; TJM dual battery system
http://www.supermotors.org/registry/...il.php?id=4836
96Bronc is offline   Reply With Quote
Old 02-11-2004, 09:23 PM   #17
WD40
WD40's Avatar
Bronco Info: 85 XLT: 69 351W - 425hp/440 lbs-ft: C6-Shift Kit/Custom T.C.: 9" Detroit Locker/Dana44 TrueTrac: 2"
Another vote for NGK, specifically their V-Power plugs.
And, another vote for Taylor Spiro Pro wires.
I've used numerous brands of spark plug wires, and these have lasted the longest...by far.
IMHO, they also have the best boot fitting for the plug.
WD40 Reverend GripShift
My SuperMotors Site
WD40 is offline   Reply With Quote
Old 03-19-2004, 03:20 AM   #18
Bronco69
Bronco Info: 1993 XLT
best plugs.
Is there any other than NGK? NGK is the best I've used.
Bronco69 is offline   Reply With Quote
Old 03-23-2004, 12:11 AM   #19
The Yak
CheeseBurger Milkshake!!
The Yak's Avatar
I run NGK in my quad. I currently run Autolites in both of my Fords (Bronco, Mustang).
I'm not ready to live in a Socialist or Facist country, nor am I ready to live under a dictator that many perceive to be some kind of Messiah.
Boycott GM!!
The Yak is offline   Reply With Quote
Old 03-23-2004, 10:20 AM   #20
Bobby
Dixie Chapter
Bobby's Avatar
Bronco Info: 1993 XLT 351W
When I work at Pepboys the manager wanted to see the difference in plugs so we put splitfire in my bronco for 2 weeks then repeated for plat +4's then the ac/delco rapid fires, and then autolite it ran the best with the autolites. I have them in the both my 93 and my 74
93 BRONCO
03 F350 DUALLY 4X4
02 PRAIRIE 650 4X4
76 WIFE
Bobby is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
