Clutch Pedal on the Floor - FSB Forums
Thread Tools Display Modes
Old 01-07-2008, 12:06 AM   #1
willjones4
willjones4's Avatar
Bronco Info: 92 Ford F150 Supercab XLT 4.9L Straight 6 5 Speed Man Trans
driving my f150 tonight when suddenly the clutch limply dropped all the way to the floor. I searched around and found that it could be slave/master cylinder, broken clutch cable or retaining clip. has this happened to anyone else? what caused it?
willjones4 is offline   Reply With Quote
Old 01-07-2008, 12:09 AM   #2
ToddACimer
Engineer
ToddACimer's Avatar
Bronco Info: 11 F150 CC 4x4
It should be a hydraulic clutch so did you check the fluid? Did you check the linkage off the master cylinder to the pedal? Does the trans have fluid all over it?
Recipient of multiple driving awards from State and Local officials.
ToddACimer is offline   Reply With Quote
Old 01-07-2008, 12:15 AM   #3
MikE2
MikE2's Avatar
If it was working fine one minute and went to the floor the next I'd suspect you probably broke the plastic line or the linkage on the pedel shaft. Allthough it could be possible, usually when a slave or master cylinder goes out it will leak the fluid out and gradually quit working.
MikE2 is offline   Reply With Quote
Old 01-07-2008, 12:32 AM   #4
willjones4
willjones4's Avatar
Not yet, its too dark-I will look it over in the morning.
Im hoping this is what happened. According to the former owner the clutch and related parts were replaced about 1.5 years ago.
Old 01-07-2008, 01:28 AM   #5
GTRider245
It's BTW Not AKA!
GTRider245's Avatar
Bronco Info: 92 F-150 4x4, 302, BBK Shorties, Flowmaster Duals, M5OD, 2" Rancho Coils, 33x12.50 M/Ts
Breaking the pieces of the pedal assembly is not a fun process.
1992 F-150 4x4
East Coast Firefighting- Only the Best
http://www.supermotors.org/vehicles/...il.php?id=4768
Originally Posted by dogonmut View Post
NTB stole my baby's momma away from me when she was on her way down to the check cashin' store to pay my beeper bill.
Originally Posted by stan the man View Post
I spent $330 for 4 BJs.
GTRider245 is offline   Reply With Quote
Old 01-07-2008, 02:01 AM   #6
willjones4
willjones4's Avatar
do tell. I'd love a tutorial...
Old 01-07-2008, 11:35 AM   #7
ScorpionBoy
crank trigger
Bronco Info: 94 XL M5OD, 5.0, Ghetto K&N, 130A G3
that happened to me. i bet your cylinder pushrod either came off the pedal lever or the eye broke off of your cylinder pushrod.
ScorpionBoy is offline   Reply With Quote
Old 01-07-2008, 12:10 PM   #8
ThetaTauMan
ThetaTauMan's Avatar
Bronco Info: 96, 351W, E4OD True Dual Exhaust, 6" D44 SAS, 38.5" tires. Sold =(
Originally Posted by willjones4 View Post
...be slave/master cylinder...
My Dad was working at this plant that made some reman part for some Ford line. Anyways they had to change all the tags and plates and anything that had the word 'slave' in it. Its now called 'leader/follower'
I would have hated to be that guy that got stuck doing that all day.
Stupid UAW, i thought that was about the stupidest thing i've ever heard!
Sorry to gank your thread, cont.
I need a truck...
I boycott things/people/places that boycott the great state of AZ!
ThetaTauMan is offline   Reply With Quote
Old 01-07-2008, 04:10 PM   #9
amw_drizz
amw_drizz's Avatar
Bronco Info: 93 XLT 302 E4OD, 87 f350 custom
Had that issue before. First for me the slave on the side of the trans (well for me) fell off. then it started going through those 60$ hard to find plastic lines. and from my searching most auto stores dont have them and they have to be obtained right from ford.
I got a steel line now and you wont find many of those, kind of like 1 of a kind. as i been told that they dont make them in steel brake lines. just hard plastic.
All those above situtations the pedal went straight to the floor. took me a month to get the damn thing fixed right.
Originally Posted by ToddACimmer
I'd stick it back in there, no sense in having it flop all around.
My Supermotors Site
1997 Jeep Cherokee 4.0l Auto, DD | 1964 Chevy Impala Convertible SS
1993 Bronco 5.0l | 1932 Ford Model A
1987 F350 Custom Car Carrier
1993 F350 7.3l Diesel
amw_drizz is offline   Reply With Quote
Old 01-08-2008, 03:15 PM   #10
willjones4
willjones4's Avatar
This was it. The retainer deal that holds the pushrod on the pedal lever disintegrated and the push rod popped off. 10 seconds and a .99 cent bag of rod nuts solved the problem. 199,150 miles and still goin' strong. I love my truck. Thanks guys...
Old 01-08-2008, 03:54 PM   #11
arkansawer
Wanna see my
arkansawer's Avatar
Bronco Info: broncoless at the moment
Where is ImlikeOJ? He should be screaming that this should be in the tech section.
Glad you got it fixed though.
The quickest way from point A to point B, is through the mud.
arkansawer is offline   Reply With Quote
Old 01-08-2008, 04:16 PM   #12
ScorpionBoy
crank trigger
fyi, i used washers and a pin to hold the pushrod on the pedal lever after my retainer disintegrated. I don't know if it was my setup or inevitable age, but soon after the plastic eye on the pushrod broke. i had to get towed on that one.
  FSB Forums > Other Forums > Anything Else
You may not post replies
Forum Jump
