Go Back   FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
Thread Tools Display Modes
Old 02-04-2008, 11:13 PM   #1
orko
Bronco Info: 92 5.8 xlt
Tone ring replacment procedure
I looked at it and my tone ring is missing some teeth! I want to go in there and replace it but I am not familiar with the internals of the rear axle. I can drain it and get the cover off.. then what? Anyone know of any good write ups on this subject? Also what tolerances should I check to make sure the problem will not recreate itself?
Thanks!
orko
orko is offline   Reply With Quote
Old 02-04-2008, 11:41 PM   #2
waltman
Lick my balls
waltman's Avatar
Bronco Info: 1989 bronco, 3" suspension lift, rebuilt 302 with cam, 33' big-os
You could just leave it.
But if you do decide to replace it, just make sure you put the shims and the bearings along with the races where they came from.
there is no such thing as stupid questions, just stupid people.
Only that in you which is me can hear what I'm saying
No matter where you go or what you do, you live your entire life within the confines of your head
I don't suffer from insanity; I enjoy every minute of it
waltman is offline   Reply With Quote
Old 02-05-2008, 12:29 AM   #3
orko
I would but My ABS is always going off. If i disconnect the Rear sensor my transmission shifts super hard and it does'nt down shift right.
Old 02-05-2008, 03:34 AM   #4
Dave's Bronc 90
Some assembly required!
Dave's Bronc 90's Avatar
Bronco Info: 90 EB, 351W, E40D, D60 SAS, 10.25 rear, ARB's front & back, indellible Cheerwine stain in carpet
1- Remove carrier cross pin.
2- Push in each axle to expose the c-clip, then remove the c-clip and pull the axle out of the carrier.
3- Mark the orientation of the bearing caps so that they can be reinstalled not only on the correct side, but also facing the right direction. Remove bearing caps.
4- Pull out the carrier, taking extreme caution to not mix up the bearing races and shim packs. They must go back in exactly as they are in right now, or you'll have to do a full gear set up when you put it back in.
5- Remove all of the ring gear bolts and tap off the ring gear with a rubber mallet.
6- Tap off the damaged tone ring and replace it with the new one.
7- Reinstall the ring gear. Many say you should replace the ring gear bolts, it's a subject of some debate. Use a lot of red LocTite and torque them to spec.
8- Put the carrier back in taking care to put the bearing races and shim packs back in their original positions.
9- Reinstall the bearing caps in their original positions, use a lot of red LocTite and torque to spec.
10- Slide the axles back in and reinstall the c-clips.
11- Reinstall the cross pin.
That's pretty much it. It's not hard to do at all, you can do it in less than an hour.
Dave's Bronc 90 is offline   Reply With Quote
Old 02-05-2008, 11:29 AM   #5
Ogeechee 4x4
Ogeechee 4x4's Avatar
Bronco Info: '95 Bronco, 351W, NP435/205, Solid D44 front, 4.56 gears, Front TrueTrac, Rear E-Locker, 35" MTR's
Dave's the man at regearing!
My SuperFord
'95 Eddie Bauer-- 351W, NP435, D44 SAS
Ogeechee 4x4 is online now   Reply With Quote
Old 02-05-2008, 11:55 AM   #6
johnski
...so hardcore, it hurts
johnski's Avatar
Bronco Info: 95 XL, 5.0, 302, D44 SAS w/lockright & chromos, spooled D60FF, 4.56's, 37" MTR's, Warn 12K
I've been Dave's lackey during 3 axle builds and can totally back that statement up.
Originally Posted by Bronco Rob View Post
And just so you know Johnski is like Chuck Norris, he'd just roundhouse kick your bumper and your vehicle would explode.
CarolinaBroncos
johnski is online now   Reply With Quote
Old 02-13-2008, 12:11 AM   #7
Steve83
Steve83's Avatar
Bronco Info: '83 Custom w/'95 4.9L & EB paint
Originally Posted by Dave's Bronc 90 View Post
1- Remove carrier cross pin bolt, and then the pin.
3- Mark the orientation of the bearing caps... The bearing caps are marked for direction when they're cast. Remove bearing caps.
5- Don't remove anything from the carrier that doesn't fall off.
6- Find the internal locating tooth on the tone ring, then spin the carrier 180° & pry the damaged tone ring away from the ring gear. When it comes off the carrier, push it to disengage the locating tooth.
7- Hook the tooth of the new tone ring into the pocket on the lip of the carrier behind the ring gear, and tap it on.
11- Reinstall the cross pin & a NEW bolt, torquing to spec.
That's pretty much it. It's not hard to do at all, you can do it in less than a half hour.
Fixed it fer ya!
Old 02-13-2008, 12:25 AM   #8
jopes
balls deep with my
jopes's Avatar
Bronco Info: pile of parts
If you heat the tone ring with torches or a oven, there is no need to tap it on. you can set it on with ease. Those tone rings are so thin you can break them if you look at them funny.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd.
Originally Posted by gillamonster
i like ranch flavored shit
Originally Posted by 95thebroncoman351 View Post
played with one of my buddies... its sick
jopes is offline   Reply With Quote
Old 12-04-2008, 08:21 PM   #9
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
I thought I'd bring up an old thread as I'm reading about many people with this possible problem, including myself. This is the directions I'm gathering:
I redid my spider gears, clutches, axle shaft & axle bearings last year, and I know I have a chipped tone ring so I need to replace it. I didn't replace it then because I wasn't thrilled about removing the carrier. I'm tired of my bouncing speedo and my lack of being able to use my cruise control. I already have the new tone ring, just waiting for the right time to tackle it. I have never taken a carrier out completely except for a ford 9" and those are simple enough. I'm a little nervous about the setup of my gears and don't want to disturb them. This procedure sounds simple enough. So the ring gear does not have to be seperated from the carrier? And the spiders can stay in place also, right? Now what do these shim packs look like, will they show themselves when taking the bearing caps off, and since there is 2 bearing caps this means only two shim packs? What about the carrier bearings that are in there, I did not replace those last year and thought that if I'm about to change the tone ring, then maybe I should change the bearings too. Would changing the carrier bearings screw with the setup of my ring and pinion? What are the torque specs for the bearing caps? I'm sure I can find out by searching but maybe we can just add it to this thread since already alot of info on how to do this. Now I know I put a new bolt in for the cross pin last year at this same time, should I still replace this bolt again? And lastly, WOW.....can be done in less than a half hour so Steve says?
I collect U.S. coins and currency and have been doing this since I was 8. If you have something that may be of value and you need to know, PM me and I'll be glad to help you out.
__________________________________________________
~ Scott ~ ~ Ford's, please bring back the Bronco!! ~
~ My Exhaust clip on YouTube ~ 179K on the odometer ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 18 years ~
sackman9975 is offline   Reply With Quote
Old 12-04-2008, 08:28 PM   #10
Steve83
Steve83's Avatar
Pulling the 8.8" carrier is easier than the 9" because the axleshafts are easier to pull, and there's no 3rd member to heft out.
Old 12-06-2008, 09:41 PM   #11
sackman9975
TTT Still waiting for some answers for questions I posted. I did look at steve83 diagram so I believe that I know what the shim packs look like, just need answers for carrier bearing change and torque specs for the caps.
Old 12-06-2008, 10:37 PM   #12
Steve83
Steve83's Avatar
If your bearings aren't pitted or discolored, leave them alone. Torque specs are in the caption of one of the diagrams.
Old 12-06-2008, 10:46 PM   #13
sackman9975
Thanks Steve! Your diagrams and knowledge are great!! And if the bearings are pitted? As when I went in there last year, my axle shafts were pitted so I replaced them. Chances are..........lets just hope not!
Old 12-09-2008, 07:25 PM   #14
Smokingunz351
Smokingunz351's Avatar
Bronco Info: 96' 33/12.50 BFGoodrich Allterrains, SIXLITRE tune-up,E-Fans and a kick ass stereo.
Not to hi-jack this thread but,dont they make wheel bearing re-locater kits for these things(i guess thats what they are called). What they do is move the bearings on a differant section on the axle shaft. this would be used on a set of shafts that are worn and cant be fixed unless you move the bearings, also poor bastards like me would use this as i cant afford new axle shafts right now.
I DONT GET STUCK JUS TEMPORARILY DELAYED!!!
[IMG]http://img340.imageshack.us/img340/1535/mybanner492634d84095ato4.jpg[/MG]
please edit the size of your sig picture down. max is 600x150 pixels
Smokingunz351 is offline   Reply With Quote
Old 12-09-2008, 08:50 PM   #15
sackman9975
Yes I've seen them shown on here once before, but I'm not exactly sure what they are called. Maybe they are called axle bearing repair kit. The axle bearing is actually wider so most of the rollers roll on a good portion of the axle shaft.
Old 12-10-2008, 01:31 AM   #16
Steve83
Steve83's Avatar
Originally Posted by sackman9975 View Post
Yes I've seen them shown on here once before...
Perhaps it was in my 8.8" Axle album.
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
