Replacing the Signal Switch on a Ford Bronco - FSB Forums
Thread Tools Display Modes
Old 04-12-2008, 05:46 PM   #1
bossind
Retired Staff
bossind's Avatar
Bronco Info: 1996 EB Bronco, 5.8, E40D, Dana 44 SAS, 4.88 gears. 35" SuperSwampers
My signal switch had developed some play in it resulting in my wipers not responding with out a wiggle of the lever and I lost the front signal lights and the signal in my mirrors.
Start by removing the tilt wheel lever, it unscrews.
Next removing the cover, there are 4 phillips type screws to remove, 3 of which are access on the bottom
The forth one is locked on the back right, you can see the screw hole better in this picture.
You'll need to remove the ignition tumbler, while pushing on the release bearing turn the key to the run position, this will release the tumbler and it will slide right out.
Slide the top cover up and over the gear selector.
Now remove the 2 torx screws that hold the switch in place and disconnect the 2 wire harness on the back of it.
New Switch on the left, and the old one on the right.
Now test your lights and wipers.
Install in reverse and your done.
bossind is offline   Reply With Quote
Old 04-12-2008, 08:08 PM   #2
Steve83
Banned
Steve83's Avatar
It's worth mentioning that, before replacing the MFS, you should test it.
Another worthwhile point is that MANY vehicles use a similar switch with a cosmetically different lever. Even the Nissan Quest (aka Mercury Villager) uses an electrically-identical MFS, but some of the luxury cars (like the Crown Vic/MGM/LTC) have a slightly different switch for the cornering lamps. So if you're junkyarding, there are plenty to choose from, or if you're buying new, there are several options.
Old 09-17-2008, 03:30 PM   #3
dirtydave
dirtydave's Avatar
Bronco Info: D44 SAS, 35's, 351W, E4OD, Locked Front & Rear, Full Cage, Custom Sliders and Bumpers
does the new switch come with e new lever as well? or do you have to swap that over?
dirtydave is offline   Reply With Quote
Old 09-17-2008, 04:33 PM   #4
bossind
Retired Staff
bossind's Avatar
Comes with a new lever.
Old 04-16-2011, 11:02 AM   #5
FordTruckMan
FordTruckMan's Avatar
Bronco Info: '79 Bronco, 14 bolt, dana 60, leaf sprung front, 5.13s, 44" boggers
Ok I figured I'd post in here just so I didn't make a new thread. I bought a 1997 F-350 and the column is the same. I got it torn apart because my key was jammed. It either got stuck in and would start the truck fine OR it wouldn't go in... I got a new cylinder and thought that would fix it but referring to picture number 5.... the turquoise piece behind the cylinder holds in a metal piece which is broken on mine and then behind that is a little gear. Next is what I think is causing the problem... The plastic gear that runs above the other gear seems to be stuck and won't allow the key to turn back all the way into the off position and defiantly won't let it turn into the acc position.
How can I get this to work, and on top of that... How can I get these parts? I have the cylinder and can find the switch, but I need these other parts I think. Is one called the tumbler? Any help would be great!
1979 Bronco, 2008 F-250
Bronco is FOR SALE!
misology (mi-SOL-uh-jee) noun: Hatred of logic or reason.
FordTruckMan is offline   Reply With Quote
Old 04-17-2011, 02:36 PM   #6
yanko 15
nice write up, came very handy last week
thanks!
yanko 15 is offline   Reply With Quote
Old 04-17-2011, 02:39 PM   #7
ProBronco
ProBronco's Avatar
Bronco Info: 80 Bronco XLT 302 4sp, 4"lift on 35" Factory LS F&R
SHOULD alays buy a NEW one, never know what used crap is been changed out due to the recall
ProBronco is offline   Reply With Quote
Old 04-18-2011, 11:27 PM   #8
Offroadbronco3388
Bronco Info: 94 bronco xlt rough country 6" lift 5.0 e4od trans
Lost front signals huh... Mine does that ill have to play with it to get them on... Maybe this is why
02Mustang GT 3.73's diablo prog. no cats cherrybomb extremes, K&N CAI TFS udp MGW short throw frpp lowering springs 13.4@101mph 1.8 60ft in 1/4 mile with minor wheel spin 94 bronco 4x4 xlt 6" rough country lift more coming
Offroadbronco3388 is offline   Reply With Quote
Old 05-01-2011, 08:22 PM   #9
Mail order cowboy
Is this process relatively the same for a '78?
78' Bronco 351M Ranger XLT
Mail order cowboy is offline   Reply With Quote
Old 05-01-2011, 08:32 PM   #10
Dan Theman
Banned
Bronco Info: '89 351 c-6 leaf sas kp d60wzip locker 14bolt 42x15x15 rockers 5.38s
no
Dan Theman is offline   Reply With Quote
Old 05-01-2011, 08:56 PM   #11
ProBronco
ProBronco's Avatar
Um no, the newer rig have a combo switch which has high beam, turn siganal and wipers all on one switch.
The 78 had a three seperate switches.
Make sense now ????
Old 05-04-2011, 12:23 PM   #12
Mail order cowboy
Guess I didnt think of that.
Old 05-04-2011, 03:05 PM   #13
ProBronco
ProBronco's Avatar
No problem, it was Ford's better idae to combine in one switch. A VERY expensive switch to change out.....................
Old 05-17-2011, 12:04 PM   #14
black & blue 78/9
Bronco Info: Black 78, 460, c6, 33 claws -- Blue 79 all stock w/10 factory white wagon wheels, factory push bar
Where (who) has the best price? OR quality?
black & blue 78/9 is offline   Reply With Quote
Old 05-17-2011, 12:28 PM   #15
black & blue 78/9
Thanks for the write up. That switch went bad in my sons 94 Grand Marquis and my daughters 94 F150 last night. Both within an hour of each other. Whoever did the search to revive this thread thankyou to you also. Made finding it much easier.
Old 05-18-2011, 12:28 AM   #16
ProBronco
ProBronco's Avatar
I went to the dealer, Motorcraft is the only one to buy..........
  FSB Forums > Bronco Discussions > Technical Write Ups
You may not post replies
Forum Jump
