tailgate removal? - FSB Forums
Thread Tools Display Modes
Old 01-26-2004, 07:17 AM   #1
RustyOlRanger4x4
Bronco Info: 1980 Bronco
tailgate removal?
how do i get the tailgate off my 80 bronco? i need to do some body work to it and it dosent look to easy to take off is there a trick to it or something i dont know? thanks,sean
RustyOlRanger4x4 is offline   Reply With Quote
Old 01-26-2004, 07:52 AM   #2
Ironclad
Yeeeeehaw Y'all!
Ironclad's Avatar
Bronco Info: 1988 XLT
Try this....
http://www1.autozone.com/servlet/UiB...3d800ac9c0.jsp
Portsmouth, Virginia
1988 XLT- 302 HO - Dual Exhaust - 6-inch Suspension lift - Sitting on 35's
....onward through the fog.
Ironclad is offline   Reply With Quote
Old 01-26-2004, 08:28 AM   #3
jmms
jmms's Avatar
Bronco Info: 1996 & 1976 Bronco's
That's a great web link!!
jmms is offline   Reply With Quote
Old 01-27-2004, 12:40 AM   #4
Sixlitre
Practicing Infidel
Sixlitre's Avatar
Bronco Info: 86 Eddie Bauer; EFI 5.0 liter, AOD, optimized ignition system, external tranny filter, urethane bush
I put a brand new tailgate shell on last summer (all by myself) and I totally disagree with removing the hinges from the body. I just slacked all 6 bolts that go into the bottom of the tailgate first as well as slacking off the torsion bar retaining bolts on the body too.
Next get the wiring disconnected and slack the retaining cables almost off. Then all you do is put some foam rubber or bunched up blankets between the bumper and gate and take out the 6 gate bolts, undo the cable bolts and the torsion bar will usually slide out as you lift the gate off the bumper.
Do you really want your fingers between the gate trying to put the bolts back into the body with your friend wheezing away with the weight of the gate ? My way you just sit the weight of the gate onto the hinges, start the cable bolts in to take the rest of the weight and slip the 6 bolts in at your leisure.
Worked for me
Sixlitre
Sixlitre is offline   Reply With Quote
Old 01-27-2004, 09:45 AM   #5
WhoaDammit
All this mud, no trucks?!
WhoaDammit's Avatar
Bronco Info: No Bko anymore, 99 Cougar
Originally Posted by Ironclad
interesting. My version of IE doesn't like that link..... what's the gist of it?
~Critter
Dammit's Superford
Originally Posted by willjones4
ever since I quit smokin pot a few years back I cant get into stupid chit like that
WhoaDammit is offline   Reply With Quote
Old 01-27-2004, 08:18 PM   #6
Sixlitre
Practicing Infidel
Sixlitre's Avatar
~Critter
Couldn't tell ya Whoadammit
I'm running Netscrap 7.1 because I'm a sucker for punishment. That and country dial up DSL.
Sixlitre
You may not post replies
Forum Jump
