Electrical troubleshooting - FSB Forums
Thread Tools Display Modes
Old 05-28-2008, 08:12 PM   #1
RD's Bronco
Bronco Info: 1986 EB
I have 86 Full-size Bronco EB and the radio works when the ignition is on but not when I turn it to accessory. I checked the fuses (ok)
RD's Bronco is offline   Reply With Quote
Old 05-28-2008, 08:46 PM   #2
daverbmxer
One Cold North Dakotan
daverbmxer's Avatar
Bronco Info: Suzuki Samurai!
The previous owner probably hooked it up incorrectly. I would assume that the radio draws power from the "on" and "acc" position. When I installed my stereo I didn't have to trace the wires back that far since I just used the stock red power wire.
I'll take a look at some schematics and see if I can help you out.
daverbmxer is offline   Reply With Quote
Old 05-28-2008, 08:53 PM   #3
daverbmxer
daverbmxer's Avatar
Well.. no I really can't.
All it shows is that the wipers, power windows, and radio are connected to the ignition switch by a black/green wire.
I'm sure someone else will know what to do.
Old 05-28-2008, 09:26 PM   #4
Peppy
Bronco Info: 1988 currently 4.9/5-speed 9"rear to come 7.3 powerstroke 10.25 rear
the contacts in your ignition switch are probably toast on and acc are two different contacts
Peppy is offline   Reply With Quote
Old 05-28-2008, 10:32 PM   #5
Steve83
Steve83's Avatar
Go to the Tech Writeups forum & read the thread about "ignition actuators". Read the TSB about the ignition switch recall. Find an old Haynes manual with a red cover (eBay?) & use the logic table in the last chapter to test your ignition switch.
Old 05-29-2008, 02:56 PM   #6
RD's Bronco
Thumbs up Thank Guys
I will check these things out and get back
Old 12-05-2012, 11:26 PM   #7
bigbertha
Bronco Info: 89' bronco eddie baeur.
I have a similar problem but when I hook up the green/black cable to a power source and have my interior light nob on the interior lights turn on. And my stereo doesn't save any settings I do to it. Any ideas.?
bigbertha is offline   Reply With Quote
Old 12-06-2012, 10:47 AM   #8
Steve83
Steve83's Avatar
That's not similar, so don't hijack this thread. Read threads about headlight switch terminals being burned, and about the courtesy light wiring & fuse.
Old 12-06-2012, 08:59 PM   #9
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Yeah don't be hijacking RD's thread. :/
...we're waiting for 'im to get back with an update. :)
In the meantime sign up on Autozone's website, put your
Bronco in the data base then search for -wiring diagram-.
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 12-07-2012, 09:26 AM   #10
miesk5
I used to know this stuff
miesk5's Avatar
yo,
Lock Cylinder Adjustment & Switch Pin-Out Diagram & Continuity Testing (Logic Tables) in an 83; "...The following proceedure is from the 1983 Ford Service manual, with a few minor wording changes, but should work for any year. Also included are a couple of illustrations from the same proceedure to help you visualize it..."
Source: by Seabronc (Rosie, Fred W) at Ford Bronco Zone Forums http://broncozone.com/topic/7243-ign...nt-proceedure/
Similar to;
Switch Pin-Out Diagram & Continuity Testing (Logic Tables in 87-91 (from Factory Manual and the Ford Electrical & Vacuum Troubleshooting Manual (EVTM)
Source: by Broncobill78 (Dave) at Ford Bronco Zone Forums
see attachmt. below
See note- the 37 & 297 Pairs are connected together internally in sw.
USN (Ret) & MIL/DoD Contingency Planner (ret)
THANKS to ALL WHO SERVE!
my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php
You may not post replies
Forum Jump
