Dana 60 carrier removal - FSB Forums
Thread Tools Display Modes
Old 07-22-2008, 01:45 AM   #1
green monster
green monster's Avatar
Bronco Info: 1994 Bronco XLT, BDS 4 inch lift, 33 Good Year DuraTracs,
Maybe someone can inlighten me on a little problem I have. I know this is a solid axle, however I would think it would be the same for any axle/carrier.
I cannot remove the carrier from the axle. I removed the bearing caps, held onto the carrier, lifted the dang axle in the air and gave her hell. Nothing.
Any other axle it just popped out. So any ideas, suggestions or reasons?
Thanks!
http://www.supermotors.org/vehicles/registry/detail.php?id=9887
green monster is offline   Reply With Quote
Old 07-22-2008, 08:31 AM   #2
flourman
flourman's Avatar
Case spreader.
I WHEEL BY BRAILLE
flourman is offline   Reply With Quote
Old 07-22-2008, 08:34 AM   #3
chebbykiller
Convicted Drunk Dialer
chebbykiller's Avatar
Bronco Info: '78 Bronco Custom - 305 L6, ZF 5-speed, NP205, D44, 9"
Get a good size crowbar behind the carrier and pry it out. Might take a little hammering on the other end.
Supahmotahs
"Whatís more chickenshit than ****ing with a manís automobile? I mean, donít **** with another manís vehicle." - Vincent Vega
Originally Posted by SigEpBlue View Post
Take your skirt off, get some jeans on, and chop that shit off with a saw.
chebbykiller is offline   Reply With Quote
Old 07-22-2008, 09:38 AM   #4
johnski
is FSB'd out
johnski's Avatar
Bronco Info: 03 Tacoma with a MTB in the back
Originally Posted by flourman View Post
Case spreader.
Best option right there.
Dave (Dave's Bronco 90) and I used a pair of pry bars on opposite sides at the same time on my 8.8, 60 rear, and 44.
Originally Posted by Bronco Rob View Post
And just so you know Johnski is like Chuck Norris, he'd just roundhouse kick your bumper and your vehicle would explode.
CarolinaBroncos
johnski is offline   Reply With Quote
Old 07-22-2008, 09:47 AM   #5
KyleQ
KyleQ's Avatar
Bronco Info: 74' 1 Ton / 74' Street Rod / 96' XL
Could one use some heat to help? I sure hope I don't have too much trouble...
74' Bronco - EFI 5.8/NP435/AtlasII - 5.5" lift - 4340 D60 - PSC Full Hydro - Cage arms - D70U Powr-Lok & Disks - 43" TSX SX on H1 beadlocks
74' Bronco - EFI 5.8/ZF5/NP205 - 450HP + Spray - Tru-Track D44/Nodular trac-lok 9"
95' F-150 - 5.0/4R70W/BW1356 - 4.56 gears - D50 powr-lok - 8.8 trac-lok
96' Bronco - 5.0/E4OD/BW1356 33's & trac-lok
KyleQ is offline   Reply With Quote
Old 07-22-2008, 09:49 AM   #6
chebbykiller
Probably not a great idea, and shouldnt be necessary.
Supahmotahs
Old 07-22-2008, 10:06 AM   #7
hav24wheel
is hazardous to others
hav24wheel's Avatar
Bronco Info: Wagoneer, 351M, C6, upside down 205
i've always got them out with a prybar...
hav24wheel is offline   Reply With Quote
Old 07-22-2008, 01:20 PM   #8
Green Meanie
Green Meanie's Avatar
Bronco Info: 1986 Bronco. 35 inch Boggers, Comp Cams Extreme 4x4 Cam, Weiand Stealth intake, 4.10 spooled rear.
Heat, bad idea. Case spreader, good idea. You have to be careful that you don't spread the case more than .020 because it can cause damage to the case itself.
Green Meanie is offline   Reply With Quote
Old 07-22-2008, 04:12 PM   #9
jagular7
Bronco Info: 1992 Custom
You could also try to rotate the pinion to help it walk off the teeth. Since there is nothing to hold it down on the pinion, it may help lift it off it. Do note any shims that come out with the bearings and what side. The shims push the carrier/ring gear side to side to mate the gear mesh correctly.
Jagular7
Lenexa, KS
jagular7 is offline   Reply With Quote
Old 07-24-2008, 02:30 AM   #10
green monster
Thanks everyone for the help...I got it! I used a couple pry bars and she came out. THere was silicon/RTV used underneath the bearing races. Everything looks god though.
Old 07-24-2008, 01:49 PM   #11
Larston
Larston's Avatar
Bronco Info: Broncoless, but I got a 1987 F250 to make up for it
Make sure that silicone is GONE when you put it back together. It won't allow the bearings to seat properly.
My Superford Site
Larston is offline   Reply With Quote
You may not post replies
Forum Jump
