| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
I need help with DTC 213 spout circuit open
#1 |
I just got an 86 bronco. Im not sure where to begin with it. When I pulled the codes it gave me DTC 213 spout circuit open. What should I do first?
| Sponsored Links | |
Advertisement |
#2 |
I used to know this stuff
![]() Join Date: Oct 2003
Location: USE FORD PARTS, let da ZONE handle ice scrapers
iTrader: (1) Bronco Info: 96 XL 5.0 E4OD, Man Xfer/Hubs
DTC 213 EZ check first;
Ck to see if the SPOUT (Spark Output) connector is missing. da connector is a little "jumper" that fits into two wire connector; located near da distributor (it is removed to adjust timing). Location pic @ distributor i by unknown via Jem270 Check to see if it is-place, if connector/wiring is damaged or corrosion is in conn or wiring.
See our Big Bronco Technical, Parts Sources & Technical Service Bulletins Links site 96 XL 5.0 E4OD, Man Xfer/Hubs Our SF Site THANKS to ALL WHO SERVE!
#3 |
My husband has a
![]() Join Date: May 2007
iTrader: (4) Bronco Info: 1986 XLT 302 90,000 original miles
You might have to dig a little down behind the bracket.
1986 FSB 1965 F100 2006 Fusion Ever "done it" in the back of a Bronco?
| Tags |
| spout circuit |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
