roll cage any one - FSB Forums
Thread Tools Display Modes
Old 09-05-2008, 12:05 AM   #1
MY94BRONCO
MY94BRONCO's Avatar
Bronco Info: 1994 bronco 351 E4OD
roll cage any one
anyone in south eastern wi that would be interested in building a cage for my 94 bronco?
MY94BRONCO is offline   Reply With Quote
Old 09-06-2008, 02:54 PM   #2
MY94BRONCO
MY94BRONCO's Avatar
nobody willing to make a few bucks?
Old 09-07-2008, 08:08 AM   #3
natesbronco
natesbronco's Avatar
Bronco Info: 74 EB and 00 Excursion
you can drive it down to Kansas and I will build you one!!!
Rockworx 4x4
Andover Ks,
3162174380
natesbronco is offline   Reply With Quote
Old 09-07-2008, 04:20 PM   #4
MY94BRONCO
MY94BRONCO's Avatar
little too far but thanks for the offer !
Old 09-09-2008, 09:09 PM   #5
MY94BRONCO
MY94BRONCO's Avatar
nobody ?????? i'm willing to travel short distance!!!!!
Old 09-09-2008, 09:13 PM   #6
bronc_17113
bronc_17113's Avatar
Bronco Info: 77 f250 highboy, 77 f250 highboy crew, 78 f150,78 bronco, 69f100
I may be interested in a few months pm me a rough idea on a price
http://www.warriorsoutdoors.com
bronc_17113 is offline   Reply With Quote
Old 09-09-2008, 09:19 PM   #7
MY94BRONCO
MY94BRONCO's Avatar
whats your price and location?
Old 09-14-2008, 11:51 PM   #8
Wanna Bronco
the bruise
Wanna Bronco's Avatar
Bronco Info: 1994, 6 inch pro comp lift, 36" super swamper IROK's, 4.88's, Detroit locker, half doors, soft top
haha, Nates name should be Wormy, for all the worm welds he lays down! Naw, Nate can weld alright, for not being a welder, right Nate? (inside joke)
damn, I need to get a little set up going. I could make some money....
Wanna Bronco is offline   Reply With Quote
Old 09-14-2008, 11:56 PM   #9
Wanna Bronco
the bruise
its only about a seven or eight hour drive. you could send him a rough design for what you wanted, and he could have most of it layed out and tacked up. maybe i could come out, drink and few, and tell Nate he is welding like crap, and talk some sh*t!
Old 09-15-2008, 02:17 AM   #10
MUDDOG7375
MUDDOG7375's Avatar
Try here..He is the guy that originaly built my 79 Bronco for the TTC...Its pictured on his site..
http://www.fabcorr.com/
Or here...
http://performanceunlimited.com/
If they cant do it or find someone to do it no one can...LOL...
MUDDOG7375 is offline   Reply With Quote
Old 09-15-2008, 09:24 AM   #11
Green Meanie
Green Meanie's Avatar
Bronco Info: 1986 Bronco. 35 inch Boggers, Comp Cams Extreme 4x4 Cam, Weiand Stealth intake, 4.10 spooled rear.
http://www.alstonracing.com/
Green Meanie is offline   Reply With Quote
Old 09-19-2008, 06:40 PM   #12
MUDDOG7375
MUDDOG7375's Avatar
MY94BRONCO ,Did you find anyone??
Old 09-19-2008, 10:19 PM   #13
MY94BRONCO
MY94BRONCO's Avatar
no haven't found anything yet. been searching and and cant seem to find anything to fit a 94! would like to meet up with some of you guys ,have a few drinks and and put some money into FSB members pockets instead of paying some big company to build it!
Old 09-20-2008, 06:29 PM   #14
MUDDOG7375
MUDDOG7375's Avatar
Did you try the 2 I listed??..
& the owner of the 1st one works for the owner of the 2nd shop also...LOL..
They are both real stand up guys
Old 09-21-2008, 05:12 PM   #15
nsasanas
nsasanas's Avatar
Bronco Info: 1996 Ford Bronco
Where are you located exactly, and what price range are you in for a nice roll cage?
nsasanas is offline   Reply With Quote
Old 09-21-2008, 08:06 PM   #16
MY94BRONCO
MY94BRONCO's Avatar
located in waterford wi.
name your price?
Old 09-21-2008, 08:39 PM   #17
Bigski6
Bigski6's Avatar
Bronco Info: 1994 xlt mostly stock 5.8 rolling on 32x11.50x15's K&N Filter SixLitre Ignition upgrade
I've been looking at the ones in JBG, I'm looking for rear seat protection, I've had zero luck finding someone around here to do one.
1994 XLT 5.8 mostly stock rolling on 32x11.50x15's
2 1/2 IN. Rough Country Lift
Bigski6 is offline   Reply With Quote
Old 09-23-2008, 10:50 AM   #18
jagular7
Bronco Info: 1992 Custom
I've got mine still in the Bronco that I'd remove. It's a 1-off custom I had fabbed back in 2002/03 sometime. I wanted a family cage. Rather than have the halos connected, I designed it with 2 single side rails front to back. Most impacts are sideways when wheeling. So triangulating the side rails together was a little easier with the interior layout. It is mounted to the frame in 6 locations and to the rear wheelwells. The frame locations extend out from the frame to the cage floor mounts. The floor is between the the mounts. Only problem, and if you go with a custom you'll want to design a solution if you can, is the footwell for the rear passengers is deeper than the rear floor. The down tubes will be secured to the floor/frame and if you need to remove the cage from the Bronco, you'll need to cut the down tubes to be able to pull it out.
Here are some pics.
Frame mounts
For mine to be removed, I'd have to cut the down tubes and then have bolt plates welded on to reinstall. That's not hard to get done.
Jagular7
Lenexa, KS
jagular7 is offline   Reply With Quote
Old 09-23-2008, 05:05 PM   #19
bronc_17113
thats a nice lookin cage how much?
Old 09-29-2008, 12:18 AM   #20
jagular7
Edit:
I'm pm you.
  FSB Forums > Wheeling > Midwest Chapter
You may not post replies
Forum Jump
