| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Tranny cooler W/fan install
#1 |
Official FSB beer drinker
iTrader: (6) Bronco Info: 91 FSB, 5.0, auto, 4" Rancho lift on 35's, warn hubs, 130 amp 3G, Electric fan, Half Doors, roll bar
So I ordered das cooler from summit (Part number DER-13950) which is a large sized stacked plate cooler with a fan mounted to it for better cooling.
![]() ![]() It comes with all sorts of goodies for pluming and mounting but I don't really like the supplied mounting materials so i'm scratching that stuff. They also offer 3 different types of hose hook ups which I'll be using the barbed fittings for rubber hoses. It also comes with an electronic thermostat for automatic use. Here's how i'm going to plum it un using the supplied fittings and thermostat ![]() ![]() And for those not electronically inclined, Here's how the wiring is going to go. There are many ways to do this but this is the way I like it. ![]() This is what I started with. The bracket on the left is one I made when I first installed my HF "off road" lights. ![]() ![]() ![]() It was in the way so it had to go. After that, I tried several times to get the tranny cooler in but the space wasn't there. I could either mount in somewhere else in the engine compartment or I had to "make" room. My AC hasn't worked since 2002 so I really didn't hesitate to much to pull out the condensor. ![]() ![]() ![]() ![]() Now that there was a good amount of space, I needed to mount the cooler. I looked around to see what others had done and didn't like any of them. Luckily Iv'e been to Sims one too many times so I had plenty to work with. ![]() Pulled out the welder and welded this 3/16 plate to the center support. ![]() ![]() ![]() Now some Z shaped brackets for the other side. ![]() ![]() And BAM! ![]() ![]() ![]() Ran the wiring through some split shielding and heat shrunk the butt-splices together. ![]() The wife was nice enough to come out and take pics of me for me. ![]() Ran the lines. The in-rad now hooks up to itself using the previous line. The order goes Tranny, cooler, filter and back to the tranny. ![]() All that's left is the wiring. In starting that I realized that what I had been doing worked but wasn't clean. I found a nice power distribution block which should help make it all look nice and more uniform. The trans is way happier than it ever was and now it never gets any hotter than 195*. I strongly recommend this to anyone running an E4OD or running offroad a lot. It's peice of mind at a decent price.
I was perfectly happy with my stock bronco until found this site. Now it'll never be done! My super motors page
| Sponsored Links | |
Advertisement |
#2 |
User that is Registered
Good call on skipping those ties that go through the radiator. Was there any reason why you didn't keep your stock cooler in addition to the new one?
♪They see me trollin, they hatin... Moderatin and tryna catch me postin dirtay♪ |
#3 |
Just like to report that my Transmission took a serious beating this weekend draggin an abandoned vehicle out of the forest and several hours of slow-trail wheeling and it never once got "hot". I couldn't recommend anything stronger than a transmission cooler with a fan on it.
#4 |
Mentally in Cancun.
iTrader: (10) Bronco Info: 1996 Ford Blazer. Lifted, locked, and loaded. Where's the Zombies?
Pulling an old Toyota out doesnt count
Seriously though, glad to hear and see that the fan was doing the E4OD good.
![]() ![]() California Bay Area off road UC4x4.com
#5 |
iTrader: (0) Bronco Info: 1986 Bronco XLT 5.0 EFI 4x4
I plan to do this soon (Great writeup by the way
) but am going to keep the stock cooler as well. With that said how much more fluid does it need over the stock amount? |
#6 |
I'm not sure. I bypassed the stock cooler and the in-rad tranny fluid cooler/heater so there's no way for me to accuratly say the difference. I'd guess about a quart.
#7 |
Stuck in the 70's & 80's
![]() Join Date: Jun 2003
iTrader: (11) Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
what are the dimensions of the one you bought vs. your stock E4OD?
Would be cool to add a small fan to the stock cooler and just put it to a relay and switch in the cab. Hot summer wheeling, towing, going up long grades, just flip it on, turn it off once the load is gone. What amp draw does that little fan supposed to draw?
______________________ http://www.supermotors.net/registry/628 "TheJuice...yes, that was my name. I come back to you now at the turn of the second decade...my name is Shadofax" |
#8 |
The stock one was about 1/2 the size and about 1/2 the thickness. As far as the amp draw, it's mininmal. I'm not 100% on how much it really is but it barely knocks the volt meter when kicked on.
The E4OD was overheating anytime I was doing anything but easy cruising. Not that the stocker with a fan wouldn't be ok but I know i'm way happier with the set-up I have now. I strongly recommend the better cooler with fan as well as the filter kit. The E4OD is rediculously expensive and the two parts I put on are less than $200. Money well spent. |
#9 | |
you must not have had the tow package: ![]() your cooler looks no bigger than the stock one I have. You really don't need much more than the stock one like what is on mine. I've never had any of the issues you described. I once had to tow a 78 bronco with 460 and large tires for miles on some forest service roads, up/down inclines etc. never a worry. Have hauled a lot of stuff with the bronco, as long as it's got the tow package cooler it should not need anything more unless you really plan to tow heavy loads regularly (where I might add the little fan). Just for comparison, to the drivers side you can see in this pic a crappy little AOD cooler I picked up from an '89 bronco that is now used as my power steering cooler: ![]() |
#10 |
The stocker I had was a little bigger than the AOD cooler. My bronco didn't even really come with that. I put it on once I started modifying the truck. The previous owner did nothing but tow with the bronco and Iv'e towed almost nothing with it since Iv'e had it. The biggest thing is that I probably never needed it until I lifted it and put bigger tires on without changing my gears. That alone adds a good amount of heat to the pig. If you don't have a gauge, get one. It's the difference between thinking and knowing.
#13 |
iTrader: (2) Bronco Info: 1990 Ford F-150 XLT Lariat Supercab, 4x4, 351W
You have any info on your power distro block? I'm trying to fab one up and looking for ideas.
My Supermotor |
#14 |
keep it family friendly
![]() Join Date: Mar 2009
iTrader: (2) Bronco Info: 1994 Ford Bronco Eddie Bauer
I have an Eddie Bauer 94 FSB and mine goes into the radiator as well. Guess that 180 degree thermostat did more for my tranny as well as my engine.
F8.8 ELocker 4.56 D44 HP ECTED 4.56 Welded Tubes 1Ton Steering 35/12.50R15 BFG MUD 15x10 Eagle Alloy 15" Travel - 77 Bronco Suspension 44x2x3" Boxed/Powdercoated Radius Arms My Saginaw Pump Install|My Gear/Elocker Writeup| My SAS Install |
#15 |
You're in texas, which is generally pretty flat. 35's and no gear change, and mountain terrian or towing and see how your E4OD likes that. I always advise the seperate tow package cooler for the E4OD. they are way too expensive not to have this simple upgrade. Makes a big difference in fluid temps.
#16 |
the easiest way to find out what's really going on with your trans is to put a temp gauge on it. I saw mine climb high even when going through country mountain roads. I also am running 35's with no gear change.
Better to be safe then sorry. Also, on the power distribution block, I found it at an electrical supply place near a jobsite. It's meant for mounting inside electrical panels for distributing grounds. |
#17 | |
#18 |
iTrader: (2) Bronco Info: 1996 Silver and Blue Superlift 6" on 33's
I've also got the stock "tow package" cooler on my '96. I see temps around 220-260 when floggin on it out in the sand (lots of slipping, lots of go pedal... yes I stopped when I saw it hit 260 and did a flush/fill when I got home) ARound town I see 150-180, as per the Autometer guage I have installed... but it's in the service port on the side of that E4OD, so I'm guessing the fluid is 20* hotter.
FWIW, I also run an aux spin on filter that holds a quart of fluid. (I'll never own another ford automatic without one) I'm also on 33's with stock gears and a 6" lift.
1996 XLT 351 E4OD Superlift 6" Extended radius arms 35" Cepek MountainCat's (Cooper STT's) |
#19 | |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
