vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Wheeling > Mountain States Chapter
Thread Tools Display Modes
Old 02-12-2004, 05:15 PM   #1
k1w1t1m
k1w1t1m's Avatar
Bronco Info: 2000 Nissan Xterra
Welder near Aurora?
I don't know that this is the right place to post this but does anyone know of a good place to get my front shock mount rewelded? I am pretty new to the area and live in Aurora and work in the Tech center.
Thanks in advance.
Tim
2000 Nissan Xterra 4x4
Sold91 351 e4od on 32" BFG ATs, Warn freewheel hubs, otherwise out of the box
http://www.geocaching.com
k1w1t1m is offline   Reply With Quote
Old 02-12-2004, 06:21 PM   #2
Dangling_Dave
Support our troops!
Dangling_Dave's Avatar
Bronco Info: 1996 Bronco, D-60 5.13 gears Detroit Locked front, Sterling 10.25, 5.13 gears, Detroit locked rear
?? Front shock mount rewelded? Upper/lower front or back?
dc
Dangling_Dave
Only WE can prevent Illegal Aliens!
Round them up and send them home
Dangling_Dave is offline   Reply With Quote
Old 02-12-2004, 06:29 PM   #3
k1w1t1m
k1w1t1m's Avatar
Sorry.
Front, front LHS lower.
Tim
Old 02-12-2004, 06:34 PM   #4
Dangling_Dave
Support our troops!
Sorry I went brain damaged, do you need the part that bolts to the back of the radius arm or do you have a dual shock setup and need the part on the front of the radius arm? My bronco is out in the parking lot and I just can't think of what you need welded. If it is the front peice on the front side of the spring I might be able to pull mine off, as I only use the shock on the back side of the spring. Geeze I can visualise it but I cannot describe it.
dc
Old 02-12-2004, 06:40 PM   #5
k1w1t1m
k1w1t1m's Avatar
It is the bolt shaped piece that goes through the lower eye on the front (quad shock). It has broken away from where it is factory welded to the front of the TTB.
I am going to do a search as I have seen a picture of it on here somewhere.
Tim
Old 02-12-2004, 06:41 PM   #6
TTBlows
TTB Hater of course
Totally Twisted and Broke makes me a saaaad Panda
"You can almost see the dismay on Phil, Paul & Bob's faces when Trautwig is talking....and the pause in their voices after he stops....after which they pick-up the pieces of his non-sensical commentary and continue with their telling of the story that is the Tour de France! "
TTBlows is offline   Reply With Quote
Old 02-12-2004, 06:44 PM   #7
k1w1t1m
k1w1t1m's Avatar
In Keith's picture it is broken too. You just can't quite see where it attaches.
Tim.
P.S I was trying to copy a pic but it didn't work
Old 02-12-2004, 06:51 PM   #8
k1w1t1m
k1w1t1m's Avatar
http://fullsizebronco.com/forum/show...ht=shock+mount
The bottom pic in this thread shows the mount.
Thanks
Tim
Old 02-12-2004, 06:52 PM   #9
Dangling_Dave
Support our troops!
Yes to put a picture up you have to put it somewhere else like superford and link to it...
I went out and looked at my Bronco, this is the peice that is held on the top and bottom by the BAB (big ass bolts) that connect the radius arm to the TTB beam, and has two about 12mm bolts through the front to the TTB beam. I am not using mine but it would be a total pita to pull them off. The bitch is I threw away two sets of them along with a huge pile of other parts before christmas to make room in my storage unit.
dc
Old 02-12-2004, 06:58 PM   #10
Dangling_Dave
Support our troops!
By the way you can just run the two back shocks untill you get the piece replaced or welded. Most of us just run the two back shocks.
dc
Old 02-12-2004, 07:04 PM   #11
k1w1t1m
k1w1t1m's Avatar
Yeah I was thinking of ignoring it and removing the shock from the other side
Old 02-12-2004, 07:15 PM   #12
WD40
WD40's Avatar
Bronco Info: 85 XLT: 69 351W - 425hp/440 lbs-ft: C6-Shift Kit/Custom T.C.: 9" Detroit Locker/Dana44 TrueTrac: 2"
Ah Ha!
Looks very familiar.
Anything like, this pic?
There are a couple good suggestions in the thread for how to fix it.
Plus, you'll see my "temp" repair, which I don't give a snowball's chance in he*l for holding up on the trail.
WD40 Reverend GripShift
My SuperMotors Site
WD40 is offline   Reply With Quote
Old 02-12-2004, 07:20 PM   #13
Dangling_Dave
Support our troops!
Man this post has been up for an hour and Keith has not suggested that he do a leaf sprung SAS yet. He must be slipping.
Old 02-12-2004, 07:30 PM   #14
k1w1t1m
k1w1t1m's Avatar
WD40. That's exactly it. I am thinking of a more permanent repair than the one shown. I have been reading the posts and have seen that guys run with only the 2 rear (front) shocks but am not quite sure which way to go.
Thanks
Tim
Old 02-12-2004, 07:33 PM   #15
k1w1t1m
k1w1t1m's Avatar
[/quote]Man this post has been up for an hour and Keith has not suggested that he do a leaf sprung SAS yet. He must be slipping.[quote]
Leaf spring SAS no way!!!.
I have owned too many Land Rovers and know the only way to go is all coils.
I miss my Defender 110 and Range Rover that I had in NZ
Tim
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
