3G Alternator wiring for 1980-1986 - FSB Forums
Thread Tools Display Modes
Old 10-03-2008, 10:41 AM   #1
Nickelplate
Nickelplate's Avatar
Bronco Info: 1986 XLT 302, AOD, 4.56 gears. 33" Tires
First off, let me say that this might work for an '87 and above, but I don't know for sure. I did this on my 86 EFI. all the stock harnesses I've seen for this style are like this, but I have not seen them all!
Things you'll need:
  1. Wire cutters, wire strippers.
  2. original bronco alternator harness.
  3. 3g alternator harness. Part Number M-14305-A351.
  4. Soldering equipment and heatshrink, or butt splices.
  5. Eyelet ends.
  6. Tape or conduit is optional for some, not for me.
Start by unplugging and untaping your stock harness and laying it out to get familiar with all the wires.
Cut off the big alternator plug after the big round junction (it might be a diode or resistor, I'm not sure).
Put on an eyelet end on the wire you just cut. Make sure that it will fit on the back of your 3G alternator.
Cut off the small alternator plug and splice the GREEN wire from your 3G plug onto the green one you just cut from the stock harness.
Cut the yellow one short and cap it with some heat-shrink tubing or some liquid-tape. This can be wrapped up in the harness when you tape or conduit it.
Tape everything up how you like it, and you're finished.
Where the wires go:
  • A: On the back of the 3G alternator. This goes the same place as the large power wire that goes to your maxi fuse.
  • B: Stator plug in the side/back of the 3G alternator.
  • C: To your chassis harness.
  • D: Battery side of starter solenoid.
  • E: Battery side of starter solenoid.
  • F: 3G Alternator.
I hope this helps you guys. I never had a battery problem after this alternator swap.
I tried sniffing coke, but the ice cubes kept getting stuck in my nose.
Nickelplate is offline   Reply With Quote
Old 10-03-2008, 11:02 AM   #2
Steve83
Banned
Steve83's Avatar
Originally Posted by Nickelplate View Post
...the big round junction (it might be a diode or resistor, I'm not sure).
It's a splice. Diodes & resistors have those symbols molded into the rubber. Cut it open & see.
Old 10-03-2008, 11:33 AM   #3
Nickelplate
Oh yeaaaaaah. Thanks m8.
Old 10-03-2008, 03:25 PM   #4
Fireguy50
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
that charge cable setup is going to burn with that fuseable link there.
Should go from this:
To this
Ryan McCormick
Fuel Injection Technical Library
Parts replacement is not auto repair, if you canít diagnose, donít open the hood!
Fireguy50 is offline   Reply With Quote
Old 10-03-2008, 03:58 PM   #5
Steve83
Banned
Steve83's Avatar
Note that in Ryan's top diagram, the horizontal Bk/O wire from the fusible link to the splice is a calibrated resistor wire, and the tiny voltage drop it develops is what drives the low-current ammeter across it. If you keep it wired in properly, the stock ammeter will continue to (NOT) work, but it's better to add a voltmeter on an ignition-switched circuit, like R/Y in the cluster connectors.
Old 10-03-2008, 04:59 PM   #6
Nickelplate
Dang, mine worked.. maybe I don't have the wires where I said they go? I dunno. You've got me worried now! So which of my leads in the A-F list are wrong? let me know and I will change them. I looked at those exact diagrams from Fordfuelinjection.com when I built this, but it was almost a year ago.
Old 10-03-2008, 10:28 PM   #7
Fireguy50
Fireguy50's Avatar
Bronco Info: rusty
cut D & E back further into the harness so all thats have left is the YEL and GRN/RED wires
Completely remove the BLK/ORG and RED/ORG wires
Ryan McCormick
Old 10-04-2008, 12:59 AM   #8
Nickelplate
I swear mine worked for a long time, and still does AFAIK. But the truck is in a state of disrepair ATM because of the shop fire (NOT caused by my wiring. it was a welding incident at the paint shop i sent it to.)
Old 09-18-2014, 09:12 AM   #9
Nickelplate
The pictures were hosted on a site that went away, so I have rehosted them here.
http://imgur.com/a/3heRC
Old 11-02-2014, 05:58 PM   #10
OhNoBronco85
OhNoBronco85's Avatar
Bronco Info: 85, c6, 351w, headers, 3G, Hellas, HIDs, odyssey, soft top, STRIPPED DOWN
Talking
Bump! This one helped me a good bit on my 84, 1g >>>3G swap
OhNoBronco85 is offline   Reply With Quote
  FSB Forums > Bronco Discussions > Technical Write Ups
You may not post replies
Forum Jump
