89 Bronco running rich - FSB Forums
Thread Tools Display Modes
Old 10-04-2008, 12:22 PM   #1
bronco boy 12
Bronco Info: 1989 Bronco 351w C6 32's
Angry 89 Bronco running rich
Hi i have an 89 bronco with a 351 and a c6. it is sped density and runs great while driving. it just idles rough and blows black smoke out when it shifts gears or at initial startup. every time you start it 2 clouds of black smoke appear out the sides, and all the time it runs it smells very very rich. lately it gets crap for gas mileage used to get 14 now gets 7. i ran 93 octane in it and no difference.
bronco boy 12 is offline   Reply With Quote
Old 10-04-2008, 12:30 PM   #2
Bilzhorse
Big feet, big hands & a
Bilzhorse's Avatar
Bronco Info: 89 XLT, 5.8, C-6, BW1356, factory LSDs, 33s
If you haven't checked for codes do it now. There are many threads on how to do this. Faulty O2 sensor, bad EGR are a couple of things that could be wrong. But def. check the codes first.
Bilzhorse is offline   Reply With Quote
Old 10-04-2008, 12:44 PM   #3
sackman9975
"living life"
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Or ECT (engine coolant temp) sensor........... But yes pull codes first.
~ Scott ~ My Tech write ups:
How to properly set the timing on a 302 or 351
Harmonic Balancer Crankshaft bolt removal
How to press rotors without taking them to a machine shop
~E303 w/Flowmaster 40 & 3inch exhaust rumble ~ 214k & counting. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 23 years ~
sackman9975 is offline   Reply With Quote
Old 10-04-2008, 01:07 PM   #4
seawalkersee
seawalkersee's Avatar
Bronco Info: 84 FSB with a 6.9 diesel/zf 5, supercharger, and 33s.
Or BAP sensor. Or bad PCM. Or a bad fuel pressure regulator. I could go on and on. Also, you are wasting your lute if you are running anything over 87 octane and there is no ping. The function of octane is to slow down the burn of the gas (thus losing power if you do not need it). Ping is gasoline exploding in the combustion chamber prematurily. So if you do not have that, you will be good ta go with 87.
The problem with the older systems is that the ECT, BAP, FPR, and a few other problems may not trip a code (including the PCM AND at times the 02s). So try the codes first and then you will have to start with a wiring diagram and a break out box.
Chris
After Midnight Project music. Subscribe and see how good they are, and how good you will feel.
http://www.youtube.com/watch?v=1HPBejDwWVI
seawalkersee is offline   Reply With Quote
You may not post replies
Forum Jump
