Help! Wheel bearing exploded and HUb Stuck on - FSB Forums
Thread Tools Display Modes
Old 02-20-2009, 08:03 PM   #1
diuguid
diuguid's Avatar
Bronco Info: 1991 XLT. 351 w/ K&N, 6" procomp lift w GY Wrangler AT's. Sixlitre Tune Up
The passanger side wheel bearings went outon my 91. I have taken the hub retaining nuts, retaining rings and everything out. I can not get the hub and rotor off. I used a puller and it will not budge (I even used a cheater bar and nothing) I think I basically got it so hot it welded the bearing to the spindle. Can I get the spindle off somehow.
Any ideas?
Torche?
1991 XLT 6" Lift w/35" GY Wranglers
K & N, Six Litre Tune Up
8,000 Lb Mile Marker hydro winch
diuguid is offline   Reply With Quote
Old 02-20-2009, 08:05 PM   #2
Redwagon
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
you will most likely have to take the whole knuckle off with the shaft and try to remove the spindle nuts from the back side.
Tim
Newest token Jeep owner....
Redwagon is offline   Reply With Quote
Old 02-20-2009, 08:07 PM   #3
diuguid
diuguid's Avatar
How do I get the shaft out? Will I have to open up the differential or should I be able to knock out a u joint?
Old 02-20-2009, 08:08 PM   #4
Redwagon
the passenger side shaft if made up of two parts...follow the shaft from the spindle to the center chunk you will see a rubber boot, remove the retaining rings on the boot and you should be able to slide the axle shafts apart.
Tim
Old 02-20-2009, 08:09 PM   #5
diuguid
diuguid's Avatar
Thanks
We will see
Old 02-20-2009, 08:11 PM   #6
Redwagon
heres a pic of the ttb axle shafts
the first shaft on the left is the inner pass. side...you can see how short the one side is...thats where the boot attaches.
Tim
Old 02-20-2009, 08:37 PM   #7
davepthomas
davepthomas's Avatar
Bronco Info: '96 Bronco 351w,E4OD,4" sus lift,3" bodylift,poly body bushng,4.56gears,36x15.5r15,tracloc frnt&rear
hmmm....sounds like it requires a little shock therapy with a 2-4 lb sledge. better get a new rotor on order.....
Building a new Bronco, 1 part at a time.
davepthomas is offline   Reply With Quote
Old 02-20-2009, 09:26 PM   #8
diuguid
diuguid's Avatar
this is going to require new rotor, hub and probably spindles. I cut off the front part of the hib with a sawsal trying to get to the bearings with no luck yet. I can not get to the botton nut for the knuckle. I am thinking I might be able to heat the inner race of the bearings and get it to slide off
Old 02-21-2009, 12:00 PM   #9
Steve83
Steve83's Avatar
I'd use a Snap-On PH3050 air hammer with the PHG84A chisel to go inside the hub & knock the outer bearing loose, or crack its inner race. Then the hub will slide off. If that doesn't work, I'd torch the outer bearing's inner race to try to swell it & release it. My last choice would be to knock the lug studs in to release the rotor, & then sawzall or torch-cut the hub in half.
Old 02-23-2009, 01:25 AM   #10
cupcake
cupcake's Avatar
Remove the nuts from the back side? I dont follow. If you did weld the race to the spindle you will need the spindle and hub and bearings at the very least. How far is hemet from LA I can torch it off if not too far away
cupcake is offline   Reply With Quote
Old 12-04-2012, 09:58 PM   #11
youngkidoldbronco
Bronco Info: 1993 eddie bauer
I have the same problem going on. I have removed the locking hub, the spindle nut, the piece behind it with the holes in it the other nut, the outer bearing but i can't get the hub/rotor off. I did my other side a while a go and the whole thing came off with a simple tug but this one is stuck does anyone have any ideas? i dont really wanna start taking too much a part like the picture showed. The bronco is a 1993 eddie with auto locking 4wd
youngkidoldbronco is offline   Reply With Quote
Old 12-05-2012, 12:59 PM   #12
helirich
helirich's Avatar
I have a hard time understanding. I have had the bearings go on mine and weld the races to the hub and the races weld the the spindle. But I have never heard of the hub welding to the spindle. I cant even imagine that. I mean the bearings (and cages) can disintagrate, but you still can get the hub off. Are you saying the hub doesnt turn? You do have the caliber off? Are you saying the hub/rotor wobbles all over, but doesnt come off? You sure you got everything off the spindle? (some got double nuts with keyed washers.)
helirich is offline   Reply With Quote
Old 12-05-2012, 01:23 PM   #13
youngkidoldbronco
I have everything off of the spindle and the hub and rotor just wobble like crazy and can slide back and forth like half an inch but wont come off. The other tire had the cage disinigrate and turn into shrapnel but this one seems to be intact. The rotor and hub just wont slide off and i have both nuts and the washer off of the spindle and can actually see the inner wheel bearing when I look inside.
Old 12-05-2012, 03:06 PM   #14
Steve83
Steve83's Avatar
Then the inner bearing's inner race may have galled onto the spindle. Try to hold the hub perfectly centered & straight as you use it & the rotor as a slide hammer to knock the inner seal out. Then the hub/rotor will come off, and you can work on that bearing.
Old 12-05-2012, 04:48 PM   #15
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Originally Posted by Steve83 View Post
Then the inner bearing's inner race may have >{friction welded itself} onto
x2 :)
Only worked on one of those one time. 2wd Ford pickup. The dumb guy
(office worker;) heard a noise coming from the front wheel "this nut was
loose :/" and so he tightened it down -tight- (loose spindle nut) along side
the road. He drove it on home from there. LOL :) He needed new brake
pads was all.
I cut the outer bearing's inner race with a Dremel on each side and then
pried the two shells off the spindle. Didn't hear back what he did with it
from there. :)
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 12-05-2012, 08:25 PM   #16
youngkidoldbronco
Thanks guys. Steve83, how hard should I be pulling on it to pop that seal out? should I be slamming away or just tapping it or what?
Old 12-05-2012, 08:51 PM   #17
Kingfish999
Nothing beets a Fullsize
Kingfish999's Avatar
Bronco Info: 96 Bronco 5.8 DD, 88 Bronco motorless Mudder
did the inner or outter bearing blow? if the inner bearing blew then you can do as steve said. if the outter blew then that wont work. you have to break the wheelbearing rollers. if that doesnt work then you have to loosen the balljoints, break them free then use a sawzall and cut the balljoint studs and replace the knuckle. if you jsut undo the balljoint studs the axleshaft will prevent the knuckle from dropping enough. this is what i had to do on my 96. however my hub had enough play where i could usse a skinny wrench to get the spindle stud nuts loose and save my knuckle.
if the outter bearing blows and the inner race is welded to the spindle, you cant get the hub off. it happened and i fear it every time i have to fix someones wheel bearings. luckily the inner bearring seems to be the most common to blow
-----96 5.0 E4OD--------------88 5.8 C6--------------96 5.8 E4OD------
---------KIA-------------------Mud/Trail---------------Daily Driver------
Kingfish999 is offline   Reply With Quote
Old 12-05-2012, 08:57 PM   #18
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
sounds like your going to need a new spindle while you are in there. I have cut the ball joints off with a sawzall and you should be able to rig it up in a press to push the spindle out.
you can also torch the bearings out, it will be smokey and you should do it out side with fire extinguishers handy.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 12-06-2012, 11:44 AM   #19
Steve83
Steve83's Avatar
Start easy - work your way up to whatever it takes. You can't do any more damage.
Old 12-07-2012, 04:14 AM   #20
youngkidoldbronco
Thanks guys I got a lot of great advice from all of you. I was able to get the bearings off and replace them and get everything back on. Now I have a door to fix, a brush guard to put on and some off road lights and then to hit the trails. Again thanks for everyone who posted advice I really appreciate it and you are all great.
You may not post replies
Forum Jump
