42 IROKS vs 44 ROCKERS - FSB Forums
Thread Tools Display Modes
Old 03-17-2009, 07:20 PM   #1
OX1
OX1's Avatar
Wasn't planning on new tires, but a guy off the classicbronco
list sent me a gift cert he was not using for 25% off for any
set if pitbull tires. I got the 44 X 19 X 16.5 rockers.
Currently I have 42 IROKS.
I was worried the 44's would be way too wide, but it turns
out they are less than 2" wider at the widest point over the 42 IROKS.
Not sure if the mog 404 axles will hold up to 44's or not, but I
might soon be finding out.
Current 42
44 Rocker
Right now I have 2" front springs, combined with approx 5" from
the portal lift, means about 7" lift total. Measuring, I found out I had
2" more lift in the back than the front. This is what the front would
look like if I swap to 4" springs with the 44's (will also let me put
in the big block with less worrying about oil pan interference).
True height of the 42 (unmounted to truck W/10 PSI air)
True height of the 44 (unmounted to truck W/10 PSI air)
width of 44
width of 42
True width of 44 bogger (about 18 inches)
True width of 12.5 wide 33" BFG AT
79 XLT, 400/C6/mog 404's/42 IROKS, 8.5" lift.
79 XLT, 400/C6/D60-D44 8 lug, 2" lift, 35 BFG AT
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
OX1 is offline   Reply With Quote
Old 03-17-2009, 07:34 PM   #2
Swat
Swat's Avatar
Bronco Info: 1993 F150 Flare Side
Saaaweeeet! I tried a set of 42 Rockers and hated the ride, but I daily drive my rig. The Iroks ride better as they have two steel belts, my 40's didn't flat spot and ran truer. No matter if your rig is primarily for trails. What do you think of the Rocker ride?
01, Ranger Edge 4X4, 4.10's, 265/70R16, lowered, lightened, and with a Supercharged 4.0
Swat is offline   Reply With Quote
Old 03-17-2009, 07:37 PM   #3
spaustin889
ladies enjoy his
spaustin889's Avatar
Bronco Info: 96, 6'' lift, rebuilt axles, stereo, lots of other stuff
go with the rockers, i have always thought it was an awesome tire (granted i have no experience here)
plus (although it will be more work), it sounds like the 4'' springs and giving enough clearance for your big block would be beneficial
btw, your rig is one of my favorites
SOLD THE BRONCO, but still sticking around
Supermotors for my Bronco
Originally Posted by Gillamonster View Post
dancing is something i should not compete in
spaustin889 is offline   Reply With Quote
Old 03-17-2009, 09:27 PM   #4
Kalashnikov
Kalashnikov's Avatar
Bronco Info: 95 F150 EB 351-E4OD 4x4, 89 F350 CC 7.3-E4OD, 93 F350 CC 7.3IDI Turbo ZF5 4x4
Hard to see with your width measurements. I measured 33x12.5x15 BFG ATs and got about 12.5". With 35x15x15 TSLs I got around 14.5".
Anyway, let use know how they do. I've heard good things. They look pretty good to. I'd like a set, but I don't like dropping the money for brand new tires.
If you've had regular TSLs, let us know how they compare; ride, mud, rocks, etc.
93 F350 4x4 Crew Cab 7.3 Turbo IDI ZF5 3" DP, BB injectors
89 F350 CC-7.3-E4OD 40x18 Ground Hawgs, winch bumper, 12klb winch, 5" stacks, turbo pump, BB injectors
95 F150 EB 5.8-E4OD Aussie locker, leveling coils, 94 F150 XLT I6-E4OD 90 F350 XLT 7.5 C6
Kalashnikov is offline   Reply With Quote
Old 03-17-2009, 09:56 PM   #5
AcePaul
Bronco Info: '95 XLT 351 and the E4OD 60 front with custom long arm kit 10.25 rear 4.56's ARB's 38.5 SX's etc
I think you'll like the rockers. I have a couple friends on them, tho not 44's.
Too bad you run a 16.5 rim, I'd make you an offer on the 42's.
Eastern 4 Wheelers www.eastern4wheelers.org
the thing:
'95 XLT Frame, 351, E4OD, Firewall, Floor, Seats.
Everything else GONE.
One tons, 4.56's ARB's 38.5 SX's. No Body. Full Cage. Etc.Superford Pics
AcePaul is offline   Reply With Quote
Old 03-18-2009, 07:40 AM   #6
OX1
OX1's Avatar
I only had one tire and only drove 4 feet. So far, they ride great.......
I own both already.
I really bought the 44's for a 74 early bronc I'm building. It is just very tempting to slap them on this 79 for now.
I am very concerned that 404 mog axles may not hold up to those 44's in the rocks. That and the fact I'm not sure I have enough gear to use them right now.
The IROKs were way better in the rocks over the TSL's. I'm told the rockers are in the 62 durometer hardness range, making them close to reds. I'm hoping they stick that well too.....
This is a durometer chart someone posted on pirates.
Maxxis 762: 45
Maxxis 399: 51.5
Maxxis 356: 61
Red Label: 61
Blue Label: 70
Irok: 71
Comp Mickey: 58
Pitbull: 62
Keeping them for now. The rockers may just sit in a shed until the 74 is done, not sure I can afford to start breaking 404 axle parts. I have some spares, but I hope to never use them
Old 03-18-2009, 08:05 AM   #7
The Ric
MORTAL KOMBAAAAAAATTT!!!!
The Ric's Avatar
Bronco Info: 88 EB custom dents, and rust.
Hey OX, those look good! Just curious on how much back spacing your running?
Not to sure what to put in my signature anymore.
1988 Ford Bronco EB - 2010 Chevy Malibu - 2009 Cannondale Six5 - 2013 FELT F75X
The Ric is offline   Reply With Quote
Old 03-18-2009, 09:37 AM   #8
OX1
OX1's Avatar
Backspacing is whatever a stock hummer H1 rim has, something like 7 inches I think. Hard to compare since I'm running mog axles with custom hubs that add about 3" track per side for the disk brakes. I believe my WMS to WMS is somewhere near 76, or about 7 inch wider than a D60 front if that helps.
Old 03-18-2009, 11:02 AM   #9
reptillikus
ate lug
reptillikus's Avatar
Bronco Info: 88ish bronco(?)/96 F250; both with D60s
I say put em on, and lets go wheelin saturday
Not as wide as i thought theyd be, and im definitely curious to see how well they stick to the rocks. And you know you wanna find out just how sticky they are. What better to compare to than my 42 Iroks?? Cmon, you can have em all on by friday, just in time to load up and get ready for rausch on saturday. You know you wanna.......
reptillikus is offline   Reply With Quote
Old 03-18-2009, 12:32 PM   #10
OX1
OX1's Avatar
HMMMMMMMMMMM..............Your a dick!!!
Who's going???
PS, only problem I see, is I heard the rockers have real thick beads, so I may not be able to use my beadlocks.
Old 03-18-2009, 01:43 PM   #11
reptillikus
ate lug
I dunno, i left a message for paul to call me.
I heard the beads were pretty thick. Im sure that the fact the tire is like 10" wider than the wheel doesnt help either.
Old 03-18-2009, 01:58 PM   #12
plug ugly
Master Bater
plug ugly's Avatar
Bronco Info: 4 wheels, 4 sticks and 3 pedals
thanks, I was thinking about those for my next tire, also stepping up from 42's
Stupid is as Stupid does
mostly a 94 Bronco
wt4wheeling
plug ugly is offline   Reply With Quote
Old 03-18-2009, 04:44 PM   #13
hav24wheel
is hazardous to others
hav24wheel's Avatar
Bronco Info: Wagoneer, 351M, C6, upside down 205
yours are narrow... i just got some in a 15 inch wheel.. mine at the widest point are about 19.75 inches wide when on my wheels. here is a mounted and unmounted pic. 44x19.50/15
also the bead is just a tad shy of an inch thick
EDIT: What did you end up payin for them total with shipping after your 25% off?
Wagoneer, Ford powered.
Excursion, V10
hav24wheel is offline   Reply With Quote
Old 03-18-2009, 04:59 PM   #14
OX1
OX1's Avatar
I'll take it, I really did not want tires that wide, I just wanted the traction and the little extra height.
Old 03-18-2009, 05:04 PM   #15
hav24wheel
hav24wheel's Avatar
I Didn't get my edit in on time.. What did you pay total for yours? Im sure its the wheels is why yours are skinny..
Excursion, V10
Old 03-18-2009, 05:56 PM   #16
OX1
OX1's Avatar
$1496 delivered....... I'm sure it's mostly the wheels too, but the IROKS are actually wider than advertised width on the same rim, go figure....
Old 03-18-2009, 06:07 PM   #17
hav24wheel
hav24wheel's Avatar
wish i had a 25% off when i got mine, $1742 delivered.
Excursion, V10
Old 03-18-2009, 10:12 PM   #18
OX1
OX1's Avatar
Thats why I got em now, even though I won't really need them for a year or 2.
  FSB Forums > Other Forums > General Discussion/ Bronco and Wheeling related.
You may not post replies
HTML code is On
Forum Jump
