| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Sea-Foam
#1 |
banned
iTrader: (0) Bronco Info: 89 XLT, 5.0, E4OD, 6" lift, 35's, headers, magnaflow, optima; 90 EB 5.8, E4OD, 4" lift, 35's, optima
Sea-Foam
I while ago, I posted that i thought I might have a stuck lifter or rocker out of adjustment at start up. It made noise for about 5 minutes or so on start up, even after an oil change.
A couple of guys here suggested I get a can of Sea Foam from NAPA. Well, I did, and it worked like a charm. Within 2 days, the noise was almost gone... within 5 days, completely gone. Six bucks, and I was good to go. ![]()
"DUTY... HONOR... COUNTRY." Remember Maj Alan Rowe, USMC (4byford) 9/3/04 Semper Fi, Alan. Remember Sgt Pat Tillman, USA (Airborne Rangers) 4/20/04 Airborne, Pat. 90 Bronco EB 89 Bronco XLT
| Sponsored Links | |
Advertisement |
#2 |
iTrader: (0) Bronco Info: 1989 bronco 302, M5od, np208, 9" lift, extended radius arms, SAS, d44 dual battery,shorty headers
Sounds awesome what is sea foam I have never heard of it.
![]() 89 EFI 302 M5OD-np208 8" lift long tube headers and dual exhaust 35x12.50 wrangler MTRs Stone Crusher steering Warn Brushguard w/8000 lb warn winch coil sprung SAS 4.09 gears w/traclock extended radius arms superwinch supreme hublocks 8.8 rear 4.10 gears w/guick lock shackle flip, Dual optima blue tops. My sfo page |
#4 |
banned
It's an additive... I put 3/4's (about 8 ounces) into my oil, and the rest in the gas.
Details here: http://www.seafoamsales.com/motorTuneUp.htm |
#5 |
I use seafoam too,it works very well,I use it in the oil,gas,run it through the vacume line,also use the trans formula in my e4od.
Fire Red Pearl 90,5.8 EB,NEW E4OD,3" body lift,pro comp 6",custom bumper,WARN 8274,G3 alt.bronco air onboard air,35" BFG MT KM.4.56 front trac lock rear 4.56 detroit locker. |
#6 | |
#7 |
Master of the Estate
iTrader: (2) Bronco Info: 1991, 5.0L, Eddie Bauer, Superlift leveling kit, Black Diamond Shocks, K&N, 33"Procomp MTs
I tried out Sea Foam also after reading this post.
Truck runs much better now. Smoother, better off the line. One of my Ex's decided to try it also in her Explorer Sport, she had the same results....and I got a little for doing it ![]() |
#8 | |
banned
HHHHmmmm..... better'n KY foam, eh? ![]() |
#9 |
I saw some this morning at discount auto parts.
1984 Bronco xlt,351w,mallory distributor and coil,K&N filter.....It's a work in progress... http://www.superford.org/registry/ve...d=4604&s=16214 |
#10 |
Advance auto also carries sea foam .I put some in the HONDA 125 and it runs much smoother.
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
