Gear indicator question - FSB Forums
Thread Tools Display Modes
Old 03-08-2004, 04:09 AM   #1
my86projectbronco
Bronco Info: 86 Bronco, 302 EFI, T-18, BW 1345
My sister just bought an 85 bronco, with a 351 and an automatic transmission. My question is, the little pointer that moves across the dash to indicate what gear you're in, doesn't move. The transmission shifts fine, you just can't tell what gear it's in. I'm not sure which tranny it is, I think a C6. My dad's 91 s10 blazer does the same thing. I'd like to get them both fixed. If anyone know how to fix them I'd appreciate it. Thanks
If it jams, force it. If it breaks, it needed to be replaced anyway.
Originally Posted by Moose
A good friend will bail you out of jail, but your best friend will be sitting next to you saying " that was #*$#ing awsome!"
86 5.0 EFI, T-18, Borg Warner 1345, D44 TTB, Ford 9 Inch. 31X10.50 (For Now)
http://www.superford.org/members/profile.php?id=9390 (under Construction)
my86projectbronco is offline   Reply With Quote
Old 03-08-2004, 04:23 AM   #2
NDIXIE
NDIXIE's Avatar
Bronco Info: '95 Bronco
If you take the lower part of the dash off (under the steering colum) you will see a wire looking think that is connected to the pointer. Real simple set up I will try to take some pics and post them for you.
NDIXIE is offline   Reply With Quote
Old 03-08-2004, 04:24 AM   #3
93bigbronco
there is a small cable inside the steering column that moves the indicator. It is attached to the linkage that runs down along side the steering shaft in the column......just take off the trim pieces and try to locate it....probably either the cable is busted or disconected
93 XLT, 351w, 8 lug solid D44, 10.25 rear, 5.13s, detroit in rear, 14in lift, 39.5 boggers on 16.5x12 MT classic II
93bigbronco is offline   Reply With Quote
You may not post replies
Forum Jump
