"Death Wobble" Front End Rebuild - FSB Forums
Thread Tools Display Modes
Old 05-23-2009, 08:29 PM   #1
musky1011
Death wobble was so bad--- undrivable
Ok
Here we go
I live in the rust belt "oh what fun"
This is a street truck--winter snow
Replacing
ball joints,axle pivot bushings,radius arms,radius arm bushings,bearings
super runner steering,shocks,u-joints
Tear apart time
More jack stands for safety
Front end out
musky1011 is offline   Reply With Quote
Old 05-23-2009, 08:36 PM   #2
musky1011
Axle pivot bushing
Axle pivot bushing removal
Drill out rubber by drillling lots of hole in the rubber on factory bushing and push out
Take a cold chisel and bend over side of bushing into center of bushing
Then press out bushing, I pounded them out
They came out EASY
I put bushing back in for photo
I know it is crooked
Bushing out
This is how it looks after it is out
Old 05-23-2009, 08:38 PM   #3
tripleh87
Slow Noob
tripleh87's Avatar
Bronco Info: 1987 Ford Bronco XLT, 5.0L v8, 31" tires, stock rims, pioneer speakers, jvc stereo, etc, etc.
poor bronco. death wabble isn't fun. i like the ford letters on the hood
rebuilt 302 v8, c6 transmission, b-w 1356 t-case
dana 44 ttb front axle with 3.55 stock gear ratio
8.8 rear with 3.55 stock gear ratio
heddman headers, dual exhaust
31x10.5x15 bfg all-terrain t/a tires on stock rims,
etc, etc, etc
http://www.superford.org/registry/ve...x.php?vID=2947
tripleh87 is offline   Reply With Quote
Old 05-23-2009, 08:39 PM   #4
musky1011
Axle pivot bushing installation
Make sure you get Poly bushings
Make sure they are going in straight
Make sure the new one goes in the same way that the old ones were in the arm
Ball joint press is the EASY way
Old 05-23-2009, 08:51 PM   #5
musky1011
Install of TTB arms
I took off old factory radius arms
Quite the rust under the old poly bushings
Old 05-23-2009, 08:53 PM   #6
tripleh87
Slow Noob
tripleh87's Avatar
looks a little warped
etc, etc, etc
Old 05-23-2009, 08:59 PM   #7
musky1011
New Radius arms
I put in new radius arms and poly bushings. Arms are factory ford
$99 each from Jeff's Bronco Graveyard
I bought NEW top bolts that hold radius arms to TTB arm
The bolts are available from Ford ($12.50 each)
I cut the old bolts shorter so I could get a short 6 sided impact socket on
Have new bolts in hand BEFORE cutting old ones
3/4 inch breaker bar with 6 foot pipe and they finally broke loose
I took the Dana 44 carrier out to lighten the arm
drivers side
I know the bolts are loose
Passenger side
Old 05-23-2009, 09:03 PM   #8
musky1011
DO NOT CROSS THREAD BOLTS
put oil the threads
DO NOT use anti-sieze on threads as they will come loose
Old 05-23-2009, 09:12 PM   #9
musky1011
spring install
Tightened the bolts that hold radius arms to TTB arm
Bought a 3/4" torque wrench at harbor freight that goes to 300 ft/lbs ($80)
cranked the bottom bolt a little more to get the 320-340 torque spec for lower bolts
Put springs in
Tighten radius arm to frame bracket nuts to torque spec
drivers side
Passenger side
That's all for today
Old 05-24-2009, 01:20 AM   #10
metal1313
Bronco Info: 94 xlt, 3in bl, 33's, new trans, rebuilt 302. 2kwatt stero system
i need to do this bad, really bad. i just need a job first. any tips for doing the pivot bushings under the truck, i'd rather not do a complete tare down.
metal1313 is offline   Reply With Quote
Old 05-24-2009, 01:51 AM   #11
yoomooman
my bko ate my money
yoomooman's Avatar
Bronco Info: 92 Eddie Bauer Bronco 5.0, E4OD,MAF Conv, sixltre tune-up, OBA, on 31x10.50x15s
good luck, those are a bastard to R&R while out of the truck let alone leaving it in the truck, and there isnt really a way to leave it in the truck because its the main thing holding up the TTB
i could be way wrong on this but i have personaly tried doin it in the truck and it was almost impossible
92 Eddie Bauer bronco 5.0--Travis
Originally Posted by jopes
11:47 pm: hand pack it on the shaft. it's something you should be good at
Originally Posted by yoomooman
some bucks is better than no bucks!
yoomooman is offline   Reply With Quote
Old 05-24-2009, 07:48 AM   #12
TheNorm
I did mine... you have to really, really think it through. It's not only hard but dangerous, if that TTB gets away from you it'll break stuff in its way.
I used a couple of floor jacks, several jack stands, and backed up everything with stacks of bricks and 2x4s. I used an air hammer to punch out the bushings, and had to modify the press a little to get clearance to put things back in.
It was several years ago, wish I had taken pics... I remember pulling a bolt and having one TTB arm slam into a stack of 2x4s. If they hadn't been there, it would have been a real mess. The movement was not what I expected. Proceed with caution if you go this route.
Also, all that work didn't cure my Death Wobble. It was the TTB bracket. One hole got wallowed out. Re-welded and drilled it, then got a new one ordered. Been good for 3 yrs now.
"Specialization is for insects..."
94 351 stock with Bug Out options
87 302 4"
TheNorm is offline   Reply With Quote
Old 05-24-2009, 12:59 PM   #13
musky1011
When I installed my lift kit a long time ago
I had the drop brackets welded to the frame
Old 05-25-2009, 10:40 PM   #14
tripleh87
Slow Noob
tripleh87's Avatar
i need to replace the pivot bushings in my bronco and f150, thought about using a floor jack to lower and raise the axle arm
etc, etc, etc
Old 05-26-2009, 12:37 AM   #15
InDaRed2
InDaRed2's Avatar
Bronco Info: 1995 F-150...no bronco
Whenever my truck would get death wobble I knew it was time to tighten the bolts holding the ttb drop brackets on.
They're welded now.
1995 F-150 5.8 E4OD, 6in lift, 35" MTZ's, 4.56 gears, Detroit Truetrac out back
InDaRed2 is offline   Reply With Quote
Old 05-26-2009, 12:32 PM   #16
Dave's Bronc 90
Some assembly required!
Dave's Bronc 90's Avatar
Bronco Info: 90 EB, 351W, E40D, D60 SAS, 10.25 rear, ARB's front & back, indellible Cheerwine stain in carpet
Why? There is no need to remove the rubber. On the one I just did all that was needed was to bend in the slight chamfer on the back side of the bushing and punch it out.
Dave's Bronc 90 is offline   Reply With Quote
Old 05-26-2009, 05:54 PM   #17
musky1011
that is just how I did it
Old 05-26-2009, 09:06 PM   #18
ad5mb
which bracket is the TTB bracket>
got pics?
ad5mb is offline   Reply With Quote
Old 05-26-2009, 10:59 PM   #19
Dave's Bronc 90
Yeah, so why go to the trouble to drill out the rubber? Seems like a wasted effort for no gain.
Old 06-06-2009, 06:47 PM   #20
musky1011
June 6 2009
Put ball joints in knuckles
put knuckles on ttb arms
New dust shields as the old one were too rusty
You may not post replies
Forum Jump
