OK to remove smog pump? - FSB Forums
Thread Tools Display Modes
Old 06-19-2009, 01:39 PM   #1
oregonian
oregonian's Avatar
Bronco Info: 1987 Ford Bronco XLT, 351 H.O. C6, 4" Lift, 33" tires, Rockford Fosgate sound, STC soft top
My smog/air pump on my '87 has started getting very noisy, I believe a bearing is giving up internally. The truck runs fine and is old enough to no longer require emmisions testing. My question is, could I remove the pump without effecting driveability?
Reality is an illusion caused by lack of alcohol.
oregonian is offline   Reply With Quote
Old 06-19-2009, 01:49 PM   #2
RickyB
RickyB's Avatar
Bronco Info: '87 XLT, new crate 5.0, rebuilt AOD, new 31"s, new Warn Premiums, all stock w/125K original miles
I have the same truck as yours. I 'rebuilt' my smog pump cause it was getting noisy. A month later it froze up-----very badly. Luckily I had another belt with me that fit when I by-passed the pump pulley. Drove it like that for about 3 week and noticed a difference for the worse in fuel and performance. Bought a used one at PYP for $15.00 and all is well again.......................
I support gay marriage. As long as both the chicks are hot............
RickyB is offline   Reply With Quote
Old 06-20-2009, 03:03 PM   #3
Cucamongan
Cucamongan's Avatar
Bronco Info: '89 XLT Bronco 5.8 C6 35"
I did this on my '89 when the smog pump froze up
and used that belt, but it was too long. you need a 060825 sized belt
AND I routed the belt a different way as well ( see, see?)
for everyone else, its a temp fix for me, cuz I need the smog crap to appease the Smog Nazi's here in CA.
I've also been told that if you run with out the smog pump on the stock Cat, it will clog it
'89 Ford Bronco, Red & White, 5.8L C6, 35"s 186K Still Going Strong!
Contributor to the Skunk Workings of Stinky Le Pew (Project PePè)
Cucamongan is offline   Reply With Quote
Old 06-20-2009, 04:09 PM   #4
broncoflorida
Bronco Info: 87FSB, 302 020 over ,3g alt, GT40 heads, Exp intake , Bassani Exhaust and 24" Magnaflow muffler
I removed my smog pump and it didn't effect driveability or mileage. I had to use a 2" shorter belt due to the pump being removed and my 3g alternator.
broncoflorida is offline   Reply With Quote
Old 06-20-2009, 04:21 PM   #5
spikedzombies
IM FAT, YOUR UGLY!
spikedzombies's Avatar
Bronco Info: '85 FS - 5.8 351 (Edelbrock 1406 4brl) - C6+NP208 - Shorties - Flowmaster 40 - Stock Height
I removed my pump and all attaching equipment when mine gave way, no effect in mileage, a little performance increase since it was actually having decent exhaust flow again.. oh and the backfire was gone... go figure
'85 Bronco Custom... RIP 01/24/2011 - Totaled By A Honda
'84 XLT - 302 - Stock - Flowmaster 44 - C6+208 - 32" Tires
spikedzombies is offline   Reply With Quote
Old 06-20-2009, 08:08 PM   #6
MrWP819300
MrWP819300's Avatar
Bronco Info: 1993 EB, 5.0 Carb'd, E4OD
You should route that belt from the alt. around the crank & then back up to the water pump. There belt is too far around the alt.
MrWP819300 is offline   Reply With Quote
Old 11-11-2011, 11:23 PM   #7
Daves 88'
Daves 88''s Avatar
Bronco Info: 1988 Bronco XLT,302, Tow package w/ limited slip, cat back exhaust, on 31's
My old smog pump blew up on me. After taking it apart, I noticed that the carbon fiber plates inside were broken up. I went to the JY and pulled one for $20.00, brought it home, and it was slow to spin. So I sprayed inside the holes with liquid wrench penetrating oil and got it freed up after letting all of the gunk run out of it several times. Now when I drive it, the smog pump makes noise like a bearing is going to seize. Is the noise normal for some smog pumps? I am pissed because the 30 day JY warranty has passed . I keep wanting to put oil, or grease in there to shut up the pump. The search function had 6 posts, and I read all of them.
And he saw that the horse was good: Former Fire Bronco
Originally Posted by wcm413 View Post
I can see the nuts now , the rod was in the way before . Thanks ,Bill
Daves 88' is offline   Reply With Quote
Old 11-12-2011, 02:11 AM   #8
mr7confused
mr7confused's Avatar
Bronco Info: 1992 f150
Should your radiator hose be doing that?? hahaha
are these pumps always choppy to spin by hand? Mine doesnt free wheel for more than a quarter turn or so
mr7confused is offline   Reply With Quote
Old 11-12-2011, 02:34 AM   #9
Daves 88'
Daves 88''s Avatar
steve 83 did a write up on cleaning out a seized pump I followed. It freed mine so it spun alot more than that, but the bearing noise on mine is scaring me.
Old 11-12-2011, 06:29 PM   #10
Americandan
Americandan's Avatar
Bronco Info: 95 5.0 XLT
I bought one from Autozone. Can't remember how much but it wasn't bad. I did a non-illustrated write up on how i changed mine out.
I'm not racist, I'm just culturally insensitive...
Americandan is offline   Reply With Quote
Old 11-13-2011, 12:52 AM   #11
ddec74
anyone know the belt size for a 302 to bypass the smog pump??
ddec74 is offline   Reply With Quote
Old 11-13-2011, 10:30 PM   #12
Daves 88'
Daves 88''s Avatar
Nevermind all. I got a smog pump today.
Old 11-14-2011, 11:41 PM   #13
ddec74
hey Mr7 where did you get the belt on the pic? is it for a 302 or 351?
Old 11-15-2011, 12:15 AM   #14
TheUnforgiven
Huh Huh vanzercool
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture, 1997 Acura TL
reading, try it sometime.
2005 Chevy Venture. 1997 Acura TL. $500 beater.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 11-15-2011, 01:21 AM   #15
offroadkarter
U jelly of my
offroadkarter's Avatar
You guys realize that 96's had no smog pump, so you could just get a smog pump delete pulley off of a 96 and keep the stock sized belt?
just a thought....
1996 Ford Bronco Eddie Bauer
12 yards long, 2 lanes wide, 65 tons of American pride!
>>>super slow build thread<<<
2004 Mercury Marauder 1985 BMW 745i
offroadkarter is offline   Reply With Quote
Old 11-15-2011, 01:29 AM   #16
Daves 88'
Daves 88''s Avatar
I don't know scratch about a 96'. But now that you mentioned it, if I ever need to upgrade my motor, I might make it a 96'.
Old 11-15-2011, 10:16 AM   #17
ddec74
it cheaper to by a shorter belt than a buying a pump plus mines making noise and we don't need it in this state...Thanks Mr7....
Old 11-18-2011, 12:39 PM   #18
Daves 88'
Daves 88''s Avatar
I've got my old smog pump here if anybody local wants to try to repair the bearing noise in it. It works, but I don't know how long it will work because it makes noise.
Old 11-19-2011, 11:19 AM   #19
doublebarrell96
doublebarrell96's Avatar
Bronco Info: '96 XL 5.0
"anyone know the belt size for a 302 to bypass the smog pump??" ddec74: I have a 96 5.0 w/ac. I used this smog delete pulley:http://www.summitracing.com/parts/PRO-68110/. This required a
2" shorter belt I scourced from NAPA. The actual belt length I used is 97 5/8" instead of the factory 99 5/8". I chose the delete pulley to keep the correct belt travel/angle and have had no problems with it thus far. Hope this helps.
There are other threads on this subject. Read them, check State and U.S. laws, and whatever you do, keep all emissions parts you remove stored away somewhere in case laws change or you wanna sell your rig. Even the smog pump can be reused as a core for a new one if ya ever wanna go back with it.
doublebarrell96 is offline   Reply With Quote
Old 11-21-2011, 11:52 AM   #20
Shovel
Shovel's Avatar
Bronco Info: 1990 BRONCO Custom | 347 | M5OD
just a thought....
I was hoping to roll to the junk yard and grab a delete pulley from a 96 but there appears to be conflicting data.
Would Cali Broncos still have a smog pump? Or maybe 5.0 were the only ones to have them, anyone?
Shovel is offline   Reply With Quote
You may not post replies
Forum Jump
