vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
Thread Tools Display Modes
Old 08-20-2009, 09:15 PM   #1
jhjones84
Bronco Info: 1992 f150 6'' lift 35" tires k&n open air cleaner bumpers sliders winch warn hubs racing seats
cranking over in on position
I have a 77 f250 with a 73 460 in it. When i got it the guy was running points and had the harness cut up. To shut the truck off you had to use a kill switch.
I found a 79 f150 with a 351 in it that I took the harness and dist. off of. Now that harness is in my truck and when you turn the key to the on position it turns over and the coil isn't getting spark. Does anybody know what could do this. I got a new ignition switch, ignition control module and coil and it is still doing it. Under the hooh there are a couple plugs that don't go to anything under the hood. can someone post picks of there engine bay on the right and left sides thanks.I'm to the point where im ready to scrap it.
jhjones84 is online now   Reply With Quote
Old 08-21-2009, 12:59 AM   #2
vreference
Bronco Info: 1978 Custom, 4 Speed, 6" Deavers, James Duff Radius Arms, Shackle flip, DetroitLocker 9", Aussie D44
So you put in the breakerless igntion module too? You've pretty much got the entire '79 harness from ignition computer all the way to the igntion switch? Assuming you have the ignition module in and the truck runs if you jumper something; you are just missing one wire. R-BLU (all the way from switch to computer) on both the 77 and 79 is the momentary power for the start position that runs both the starter solenoid and the ignition module. The computer actually has two power wires the R-Blu wire for starting and then the wire that is either white or blue depending on year for the run position.
If you are trying to use a breakerless igntion distributor with no module, of course you won't get spark no matter what.
vreference is offline   Reply With Quote
Old 08-21-2009, 08:28 PM   #3
jhjones84
Breakerless ignition module? If your talking about the icm I have that and its good. Ill try tracing those wires tonight thanks alot.
Old 08-21-2009, 10:30 PM   #4
jhjones84
I traced some more wires tonight and I cant figure anything out. I still have the points distributor coil plug wires and everything so I think thats the route im gonna go. My plan is to use a push button for the starter and a toggle to cut power to the coil. What all would I need to do to get this thing running.
Old 08-22-2009, 12:08 AM   #5
InfoFord
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
if you going to do this why did you bother to swap the harness?
Trent
NORTH COUNTRY SPECIALTIES
Picador (1979 4door Bronco)
79 Ford CrewCab 4X4(My Dually Project)
79 Ford Bronco and My Boat
InfoFord is offline   Reply With Quote
Old 08-22-2009, 03:39 PM   #6
jhjones84
Because I wanted to use the electronic ignition and before everything was cut up in the harness. It ran good but I had no gauges or anything.
Old 08-23-2009, 03:31 PM   #7
InfoFord
InfoFord's Avatar
you simply hooked up a wire wrong thus causing you this grief is it best to figure out the problem and fix it rather then butcher up yet another harness and undoing what you have done so far
Old 08-23-2009, 03:46 PM   #8
jhjones84
Alright I've got someone whos coming over to look at it tuesday. Just a thought though is there a difference between 77 and 79 harnesses. In the back of the haynes manual there seperate sections. Oh and can someone post pics of there starter sylonoid. Thanks
Old 08-23-2009, 04:00 PM   #9
jopes
balls deep with my
jopes's Avatar
Bronco Info: pile of parts
http://www.metropartsmarket.com/cata...oid_Fomoco.jpg
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd.
Originally Posted by Ranger429 View Post
Nothing better than a piece of dark meat with some sauce on it.
Originally Posted by 95thebroncoman351 View Post
played with one of my buddies... its sick
jopes is offline   Reply With Quote
Old 08-24-2009, 09:39 PM   #10
jhjones84
Thanks for the pic but i was looking for one in a truck to see what wires went were.
Old 11-03-2009, 09:24 PM   #11
79FordF250
check the two wires that go to the solenoid. Chances are you have them switched and it will do exactly what you are describing, trust me, i know from experience.
79FordF250 is offline   Reply With Quote
Old 11-04-2009, 01:23 AM   #12
7LBRONCO
7LBRONCO's Avatar
Bronco Info: 78 XLT, 429 Thunderjet, C6, shackle flip in rear, 4" springs in front,
I pulled the harness from a 77 F150, and plugged it into my 78 F250. No cuts or splices, from the pigtail on the ICM, to the other side of the engine.
Unplug the 2 small wires on the soledoid, the ones with the 90* boots. Now turn the key to the run position. Find which of the 2 wires is hot. That wire goes on the small stud towards the front of the truck, I believe. The other wire goes on the other small stud. There's only 2 combinations, so if one doesn't work, try the other.
7LBRONCO is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
