| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
CEL, OBD II Won't Scan, Already Tried Searching
#1 |
iTrader: (0) Bronco Info: '96 Bronco XLT / '06 WRX STi
PROBLEM SOLVED.
Hey guys, I'm new to the Bronco world, but by no means new to forums. I just picked up a Green '96 XLT with 142xxx on the clock and a 302 under the hood!! I've always liked Broncos, and figured since I've owned Dodge and Chevy trucks, it was time to try a Ford. I basically got it as a winter beater, but it's going to be my dd as I put my STi in the garage My problem is this - I've got a CEL on, and I can't get my OBD II scanner to work. I looked in the fuse box, low and behold I'm missing the fuse for the cigarette lighter and OBD, so I threw one in from another port. Well, the problem didn't go away. I'm not getting power to the scanner, and I'm pretty sure I'm doing everything right. I need to pass inspection in NJ in a couple weeks, and really need to fix the CEL first. The guy I bought it from told me it was an o2 sensor, but I don't really trust his word, I'd rather find out what it needs myself. Anybody know the least expensive way I can go about diagnosing these problems or anyone live in the Boston area that's willing to give me a hand? Thanks for the help. I look forward to enjoying my new Bronco and have a new forum to play on. |
| Sponsored Links | |
Advertisement |
#3 |
Are you sure the fuse you threw in didn't pop upon insertion? Was it the right amperage also?
I collect U.S. coins and currency and have been doing this since I was 8. If you have something that may be of value and you need to know, PM me and I'll be glad to help you out. __________________________________________________ ~ Scott ~ ~ Ford's, please bring back the Bronco!! ~ ~ My Exhaust clip on YouTube ~ 180K on the odometer ~ ~ Bronco owner/Driver/Mechanic/Enthusiast for 18 years ~ |
#4 |
I used to know this stuff
![]() Join Date: Oct 2003
Location: USE FORD PARTS, let da ZONE handle ice scrapers
iTrader: (1) Bronco Info: 96 XL 5.0 E4OD, Man Xfer/Hubs
X man,
I found that my cig lighter's 12v vehicle power (VPWR) Lt Blue/White wire chaffed & shorted on ashtray frame. It caused Fuse 16 to blow itself...out & this also caused the OBD II Diagnostic Link Connector (DLC) not to "power up" @ pin 16 So get in there & ck that fuse again; if blown, pull ashtray or just trace Lt Blue/White wire back and see if it is shorting out on da frame. if so, tape it If Fuse is ok, pull out a multi meter or get a cheap one or 12 v test lamp and ck for 12v at the DLC connector pin 16 Diagnostic Link Connector (DLC) Pin-Out Diagram in a 96 Source: by Steve83 ![]() If no 12v, trace same wire from DLC connector pin 16 back and see if it is shorted on frame. to power the DLC con up, run a jumper from 12v always on Source (fuse box, etc.) and tap into that pin 16 wire If power is @ 16; then ck other pics for Ground (chassis) @ pin 4
See our Big Bronco Technical, Parts Sources & Technical Service Bulletins Links site 96 XL 5.0 E4OD, Man Xfer/Hubs Our SF Site THANKS to ALL WHO SERVE!
#5 |
Thanks guys.
I got it. apparently somebody spliced the cigarette lighter before i got it and the wires were taped. the tape wore off and the wires were touching each other and shorting out. all fixed. Mods, please close this thread. |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
