My Bronco won't turn off - FSB Forums
Thread Tools Display Modes
Old 10-18-2009, 12:16 PM   #1
alexthetrainer
alexthetrainer's Avatar
Bronco Info: 1995 Ford Bronco XLT 5.8L 4x4
So I'm on my way home from work yesterday, and when I get home my truck won't turn off. I turned the ignition off, pulled the key out, and it was still running. I disconnected the negative pattery cable, and it was still running. Finally, I took it to my mechanic and he disconnected something in the engine bay to turn off the engine, but when he did that the radio and AC were still on. I had to disconnect the battery to get those to turn off. When I reconnect everhything, the radio, dash lights, etc. come back on, even with the ignition off and the key out. Anybody got any ideas as to how to fix this?
AlexTheTrainer
1995 Ford Bronco XLT 5.8L - 4x4 - 3" Body Lift - 33" BF Goodrich All Terrains
alexthetrainer is offline   Reply With Quote
Old 10-18-2009, 01:03 PM   #2
Rebelracer_NC
Rebelracer_NC's Avatar
Bronco Info: 1990 EB 351w E4OD
Sounds like the ignition switch has come apart or is broken. I don't own a 92-96 but I believe it used the same key cylinder/rod that operates the switch mounted on the steering column; access it by taking off fuse panel. Could also be a problem with the actual rod i suppose.
Rebelracer_NC is offline   Reply With Quote
Old 10-18-2009, 01:29 PM   #3
The Ric
MORTAL KOMBAAAAAAATTT!!!!
The Ric's Avatar
Bronco Info: 88 EB custom dents, and rust.
this is probably your problem, if your ignition switch is fine.
http://www.fullsizebronco.com/forum/...ad.php?t=70454
Not to sure what to put in my signature anymore.
1988 Ford Bronco EB - 2010 Chevy Malibu - 2009 Cannondale Six5 - 2013 FELT F75X
The Ric is offline   Reply With Quote
Old 10-18-2009, 07:38 PM   #4
KYBOSH
KYBOSH's Avatar
That was probably the greatest walk-thru I have ever seen.
Originally Posted by Bronco Rob View Post
The day any Bronco gets above 30 MPG running a fossil fuel as it's mainstay of combustion, i will gladly chew off my own testicles.
KYBOSH is offline   Reply With Quote
Old 10-18-2009, 09:14 PM   #5
buckingbronco351
buckingbronco351's Avatar
Bronco Info: 90 bronco xlt 351w magnaflow converter, and muffler full 3 inch all the way
ya mine had the same problem about 6months ago. if you dont want to mess with anything for now you can still drive it. go underneath with a socket and remove the ignition switch from the rod. then put in the key and turn it to the run position so it unloclocks the wheel. then go back underneath with a small screwdriver or key or something and slide the piece on the switch inside where the rod connects. then to shut it off go back under and slide it back. its super easy. i drove mine like this for a week or two and when you go to do it just put in another switch it was like 8$ at orileys. good luck.
90 bronco 351w
full 3in exhaust with shorties and glasspacks.
2.5in rough country suspension lift.
still on 31s though but 33s in the mix soon
buckingbronco351 is offline   Reply With Quote
Old 10-19-2009, 03:34 PM   #6
FearTheSwamp
FearTheSwamp's Avatar
Bronco Info: 351 Windsor
The dog wants to run! She doesn't want to go home yet, take her to the mud!!
1990 Eddie Bauer Edition
351 Windsor
working on odds and ends - hope to get to exhaust system soon..
FearTheSwamp is offline   Reply With Quote
Old 10-19-2009, 11:07 PM   #7
djsguns
djsguns's Avatar
Bronco Info: 1994 Bronco XLT 5.8L & 1992 F-250
The ignition switch is alot easier to remove on a 92-96 bronco then the older ones. you just have to remove the top cover on the steering column and you can see it and you don't have to remove the steering wheel. If it is the key lock it removes by using the key in the lock and depressing a button and it comes right out. I had to replace my key lock and it took all of 5 min to change on my 94 bronco
djsguns is offline   Reply With Quote
Old 10-20-2009, 07:09 PM   #8
alexthetrainer
I looked at it further, and it's not the ignition switch. There are 2 pieces that make up the ignition switch actuator. I haven't taken the steering column apart to see exactly how they work together, but they are in the pic below. The guy at Ford said the teeth on the one actuator break all the time. I don't have the time to change them myself (working 15-hour shifts all week), so I'm having my buddy do it for me. I'll be posting pics of the old parts later.
AlexTheTrainer
Old 10-20-2009, 08:14 PM   #9
Late Model Man
Late Model Man's Avatar
Bronco Info: '95 351, ZF5, Dana 60s
Same thing happened to me and it was the ignition switch.
SuperFord 95 8-lug Bronco with some stuff...
Late Model Man is offline   Reply With Quote
You may not post replies
Forum Jump
