vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > 1980-'96 Bronco Tech
Thread Tools Display Modes
Old 10-24-2009, 01:09 AM   #1
IslandBronco
Bronco Info: 1983 Ford Bronco 4.9 i6 - should be called old rusty entire floor needs to be replaced
Rear body, floor panels
Hey, I have looked around and cant find the info I need.
I want to take a F150 truck box floor and rear wheel tubs and cut them to fit into the rear of a similar year Bronco. Has anyone done this? Can it be done? Rough measurements it looks as if it will fit ok. Can pick up a truck box 150 CDN no rust minor dents. Cheeper than new wheel wells and fabricating new floor. Panels very hard to find in British Columbia
IslandBronco is offline   Reply With Quote
Old 10-24-2009, 01:11 AM   #2
scott 351 wins
scott 351 wins's Avatar
Bronco Info: 1985 xl 300/c6,1992 xlt 37" boggers, 1994 xlt 5.0/e4od 3"body lift, daily driver, 84 f250 tow rig
i have thought the same thing also, anything is possible if you have the skills.
Originally Posted by IronHorse! View Post
man somebody should be doing a product review on his mothers vagina hole it's popping out pure stupid
scott 351 wins is offline   Reply With Quote
Old 10-25-2009, 07:49 PM   #3
IslandBronco
Ok, either no one has undertaking this kind of restoration or they have all used new panels?
Cant find all the new panels I need in Canada and cross border shopping is way to expensive. I can buy a non running f150 for less than 500 with all panels intact so thought it would be easier to get the sheet metal I needed. BUT what I was looking for was someone else that may have been brave enough (stupid) enough to take this on!?!?!
ANYONE OUT THERE?
Old 10-25-2009, 08:08 PM   #4
bossind
Moderator
bossind's Avatar
Bronco Info: 1996 EB Bronco, 5.0, E40D, Dana 44 SAS, 4.88 gears. 35" SuperSwampers
Seems to be the f150 wheel wells weren't as deep - anyways there was something obvious when you looked at both back when I was considering it.
bossind is offline   Reply With Quote
Old 10-25-2009, 09:12 PM   #5
nineveh
nineveh's Avatar
Bronco Info: 86xlt, 5.8l/frt:d60, no-spin, 4.88/rear:d60 35sp shafts, spool, 4.88/susp:econoline van leafs f&r
I did something similar, and grafted about a foot or so of rear part a pickup bed into the rear part of the bronco, behind the fenderwells. If your bronco is like mine, the rear most support member underneath the floor will be rotted away and have to be repaired and /or replaced. Where the floor ties into the tailgate sill is different, but not too big a deal.
You should check the frame where the body mounts attach, and see if it's rotting out. Check the little wells behind the seats where the seatbelts attach. Also, check the pickup fenderwell panels, (there are caulked seams between the fenderwells panels and the inner corrugated panels), to see if there is an additional corrugated row. I know the pickup panels behind the fenderwells has them. I cut them out and spliced in 16 gauge sheetmetal, because the bronco's are flat there.
Does the pickup have a bump out behind the left fender well for the gas tank filler neck?
nineveh is offline   Reply With Quote
Old 11-03-2009, 08:47 PM   #6
IslandBronco
Cant do it without alot of extra cutting from wheel well depth width, overall box floor width, there is way too much cutting to make the price worth while. SOooooo, of to the metal shop to get some sheet. We will make our own. I have added some pictures of it to my garage for those interested in the rusty issues...
Old 11-04-2009, 12:11 AM   #7
XXLBRONCO
XXLBRONCO's Avatar
Bronco Info: 90 bronco 302, 6''with 3'' body warn enforcer front and rear bumpers, t18 4spd, sitn on 44's
You can get premade wheel wells that are universal and come in a lot of diff. sizes for under 100 bucks and they are preformed already just cut to fit and weld in.
XXLBRONCO is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
