Go Back   FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
View Poll Results: Hubs
Keep Stock Hubs 25 34.25%
Change to Superwinch lockouts 7 9.59%
Keep Stock hubs and save up for better hubs 32 43.84%
Switch to SW hubs and eventually save up for better 9 12.33%
Voters: 73. You may not vote on this poll
Thread Tools Display Modes
Old 10-31-2009, 02:32 PM   #1
Macmillan1
Macmillan1's Avatar
Bronco Info: 1996 eddie bauer, 351w, 6 inch lift 36" tsl's/78 bronco custom 400/4spd, all kinds of fun
Locking hubs opinions
As of now i have the Stock set of locking hubs on my truck, BUT i have a set of Superwinch lockouts sitting in a box on a shelf, which do you guys think are better? or should i just save up my money for something like Warn Premiums?
Mark
Macmillan1 is offline   Reply With Quote
Old 10-31-2009, 02:39 PM   #2
Need4racin
I See Georgia
Bronco Info: 96 XLT 302/E4OD & 90 EB 302/AOD
The stock manual hubs will be fine.
Need4racin is offline   Reply With Quote
Old 10-31-2009, 05:39 PM   #3
Blasterway
Blasterway's Avatar
Bronco Info: 1978 Bronco Ranger XLT 400 NP435 4 speed, NP205 "T"case. 2001 Ford Expedition XLT 5.4l stock
Keep the stock, if they go bad you already have a backup set.
Blasterway is offline   Reply With Quote
Old 10-31-2009, 08:55 PM   #4
Mudhound
Location: Eastern Kentucky, in the Red River Gorge area
Bronco Info: 84 BII, 87 Ranger STX, 89 FSB
I agree. Run the installed ones UNTIL you blow one of them, THEN switch out the busted one. If the question had been " I have the Auto hubs on my FSB, and a set of Brand X manuals setting in a box, should I switch them?", the answer would have "Yes, switch them BEFORE they blow.".
Mudhound is offline   Reply With Quote
Old 11-01-2009, 12:29 AM   #5
jklaw13
jklaw13's Avatar
Bronco Info: 1978 Bronco 400M, edelbrock intake and carb, crane RV cam and roller rockers, 6" James Duffy lift
Warn or Mile Markers are sooo much easier to work with. They come out in one piece vs stock, a big when you need to repack bearings or change your rotor. I have no experience with Superwinch hubs but they are probably the same. Good Luck
jklaw13 is offline   Reply With Quote
Old 11-01-2009, 03:20 AM   #6
drinkbrew
drinkbrew's Avatar
Bronco Info: 96 XLT, 5.8
I switched to warn premiums right away since my stockers were already trashed, but I have heard way to many stories of the stock ones failing when they needed them. if you are going to keep you stock hub just make sure you carry your replacements and the tools you need to change them with you for when they do go out so you are not stranded.
http://www.supermotors.org/users/drinkbrew
96 bronco xlt 5.8, pro-comp stage II 6" lift, M/T classic lock wheels, 35" BFG all terrains, k&n stage II FIPK, FlowTech headers, electric fan, MSD coil with mods, ford racing 9mm wires, MSD cap and rotor, warn premium manual hubs and more to come .
drinkbrew is offline   Reply With Quote
Old 11-01-2009, 07:43 AM   #7
SSgtTEX
Broncoless
SSgtTEX's Avatar
Bronco Info: None :(
They are the same.
I ran Superwinch hubs in my bronco. Never once had an issue with them. Always ease to lock and unlock, but not so easy that they unlocked on their own. I was very happy with them.
If I were you, I would run the stock ones until you have a free hour or two. I wouldn't leave them in there until one blew up on you. Basically what I am saying is, when you get the time change, otherwise don't worry about it. Unless, you are getting ready to go on a wheeling trip, then make the time.
BrandNewMistake.com
SSgtTEX is offline   Reply With Quote
Old 11-01-2009, 08:17 AM   #8
Hefty
Need a Bumper?
Hefty's Avatar
Bronco Info: 93 Bronco 7in SAS 38's 4.56 and rear detroit front e-locker, 72 bronco under construction
The stock spicer (Ford) locking huds are extremely strong. Don't swap until you break. I have blown up milemarker and warn hubs both in the past year. I'm on set #3 in a year. The Warns are much better than the MM's
HeftyFabworks.com
HeftyFabworks.com ---------ColoradoFullsize.com
Hefty is offline   Reply With Quote
Old 11-01-2009, 12:54 PM   #9
Shadofax
Stuck in the 70's & 80's
Shadofax's Avatar
Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
Hefty, the old stockers used in 70's trucks is what you're thinking of. Lots of cast steel as I recall, before they started looking for lighter materials.
I can post a pic of my ford manuals, and they are basically a warn standard, short turn dial, with some white plastic around the inside. I never broke them, but they aren't very strong I'd think with that plastic in the hub body (not just the dial).
I'd put the superwinch ones in there and keep these as a backup.
______________________
http://www.supermotors.net/registry/628
"TheJuice...yes, that was my name. I come back to you now at the turn of the second decade...my name is Shadofax"
Shadofax is offline   Reply With Quote
Old 11-01-2009, 02:35 PM   #10
Macmillan1
Macmillan1's Avatar
I have the same hubs, basically warn standards, they work fine but theyre a little hard to turn compared to the superwinch, the superwinch comes out as one piece also
Old 11-02-2009, 10:59 AM   #11
Shane C.
Shane C.'s Avatar
Bronco Info: 1995 XL, E4OD, 4 inch lift, 35s, 350Z Seats...
X2
I'm half man, half dog. I'm my own best friend.
Shane C. is offline   Reply With Quote
Old 11-02-2009, 12:51 PM   #12
bigblueford
bigblueford's Avatar
Bronco Info: 1989 FSB 351/C6 (mine) 1990 FSB 302/AOD (hers)
I just replaced my blown stock auto hubs with the Warn Premium Manuals. $89 isn't a bad price to pay to have 4 wheel drive back.
The first side took me an hour (wrestling with that !@#$ C-clip). The other side took me 2 1/2 minutes.
My wife is sticking with her factory manuals on her Bronco til they blow. They work even after 20 years.
bigblueford is offline   Reply With Quote
Old 11-02-2009, 06:08 PM   #13
Kalashnikov
Kalashnikov's Avatar
Bronco Info: 94 F150 I6-E4OD 88 F350 7.5-ZF5 89 F350 7.5-C6 90 F350 7.5 95 F150 EB 5.8-E4OD 71 Kaiser M35A2
Stock ones are warn ones. Only difference is the on epiece deal. They aren't THAT strong. I broke one before breaking anything else.
I have an old MM, one of the ones that turns 90*, and it seems better than the warns.
Similar to these (same turn dial):
http://store.4wheelingplus.com/image...eep-cj-hub.jpg
OFFROAD RECOVERY Light-Medium Duty Trucks Servicing New England
95 F150 EB 5.8-E4OD 94 F150 XLT I6-E4OD 90 F350 XLT 7.5 89 F350 XLT 7.5-C6 88 F350 Custom 7.5-ZF5 88 Bronco EB 5.0-C6 RIP 71 Kaiser M35A2
Kalashnikov is offline   Reply With Quote
Old 11-02-2009, 06:26 PM   #14
Shadofax
Shadofax's Avatar
That's an external locking hub though.
They did make an internal locking hub that was all steel. There was a site on line still selling them and then about 2-3 yrs ago, they just stopped selling them. They were from MM as I recall and all steel, about as strong as you're going to get (in a dial vs. a plug that keeps the whole front end moving all the time). Wonder why they stopped selling them?
Old 11-02-2009, 07:08 PM   #15
f1fiddy
YANK MY
f1fiddy's Avatar
Bronco Info: 89 Bronco EB 5.0L AOD, 33" Mud Country's, 2" budget lift,Ford 9" w/Aussie locker
x3
I have been running warn premiums for 4 years with no issues, but I still have the old stockers for back up just in case.
You will be much happier swapping hubs in your garage or driveway than on the trail imo.
Custom front and rear bumpers
12K Tabor winch
Custom T-case skid plate
2 Pro Comp 130watt Lights
f1fiddy is offline   Reply With Quote
Old 11-02-2009, 07:43 PM   #16
Kalashnikov
Yea, that was just an example of the styling cosmetics. Mine (figures I only have one) is the normal internal.
Old 11-02-2009, 08:09 PM   #17
Shadofax
Shadofax's Avatar
Originally Posted by f1fiddy View Post
x3
yes, especially if you are pulling them on the trail because they are broke, maybe wedged in, maybe they scored other stuff up or ?? I look at it as putting your best foot forward, your "starters". Leave the lesser hubs on the bench as just in case backups.
Old 11-07-2009, 10:10 PM   #18
BroncoRN
BroncoRN's Avatar
Bronco Info: 1991 F250 4x4, 351W, ZF5, 1356 tcase, 4.10 LS rear, Hooker headers
i switched to MM supreme hubs. Never had a problem with them...highly recommend.
Sold the bronco, got something close!
BroncoRN is offline   Reply With Quote
Old 11-07-2009, 10:22 PM   #19
Kalashnikov
I just looked at my hubs the other day and they are both arms, not the one MM and Warn. Could've sworn one was a MM.
Old 11-08-2009, 01:28 AM   #20
XXLBRONCO
XXLBRONCO's Avatar
Bronco Info: 90 bronco 302, 6''with 3'' body, custom bumpers, t18 4spd, sitn on 42's sas in progress
just run the stock, until they break then switch to the other set, then get a set of warn premium for the next backup set.
XXLBRONCO is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
