vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
Thread Tools Display Modes
Old 11-02-2009, 02:56 PM   #1
etvalentin
etvalentin's Avatar
Bronco Info: 1984 Bronco xlt 351 4bbl ford 9 rear ttb dana44 front NP208 transfer case
Will a heat blower motor just die or slowly go
took the bronco out the other night and it was a cold night...i put the heat on because the windows were fogging up and i was cold...i tried the heat through the vents first, then the defrost...the air comes out a little warm, not really hot, and it's blowing very lightly even when on high...i'm assuming my defrost won't work because the previous owner ripped out the A/C unit, and i'm assuming the defrost works with the A/C...but my question is, if the air is coming out, lightly, could it still be the blower motor going, or does the blower motor just die all together...thanks for your responses....
etvalentin is offline   Reply With Quote
Old 11-02-2009, 04:14 PM   #2
jopes
balls deep with my
jopes's Avatar
Bronco Info: pile of parts
it can happen both ways.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd.
Originally Posted by Ranger429 View Post
Nothing better than a piece of dark meat with some sauce on it.
Originally Posted by 95thebroncoman351 View Post
played with one of my buddies... its sick
jopes is offline   Reply With Quote
Old 11-02-2009, 04:20 PM   #3
Blasterway
Blasterway's Avatar
Bronco Info: 1978 Bronco Ranger XLT 400 NP435 4 speed, NP205 "T"case. 2001 Ford Expedition XLT 5.4l stock
Electrical stuff can go kaput in many ways.
Blasterway is offline   Reply With Quote
Old 11-03-2009, 06:41 PM   #4
etvalentin
etvalentin's Avatar
I took another look at the heat situation, and it seems like the low to high for the heat works fine, it's more switching from defrost to floor, to vent...it's not switching at all...when i switch it, i hear no change...how does the vent system work...would it be a switch that has gone bad if it doesn't switch from vent to floor and so on?
Old 11-03-2009, 06:52 PM   #5
Blasterway
Blasterway's Avatar
I believe switching from one function to another is vacuum operated. I could be wrong.
Old 11-03-2009, 07:10 PM   #6
etvalentin
etvalentin's Avatar
I searched the Haynes book, but i can't find any information about the switch indicator and how it works, but found nothing...when i check LMC catalogue, it shows a picture of the switch indicator and it has a little mechanism attached to it...i'm assuming this switches the doors in some way...but i'm not sure....
Old 11-03-2009, 07:40 PM   #7
Blasterway
Blasterway's Avatar
Check this out, it may help.
http://www.thedieselstop.com/faq/949...les/961307.pdf
Old 11-04-2009, 02:44 PM   #8
miesk5
miesk5's Avatar
Location: USE FORD PARTS, let da ZONE handle ice scrapers
Yo!
I can't open SM right now so look at this when you can;
Ventilation Duct, Under Dash Diagram for 80-86; "...Pull the glove box &/or radio &/or HVAC control panel so you can look inside the dash & observe the vacuum motor & diverter door lever...If you have an 87-early 88, it's all cable (except the recirculate motor under the hood..."
http://www.supermotors.net/clubs/sup...ry/media/72422
See our Big Bronco Technical, Parts Sources & Technical Service Bulletins Links site
Our SF Site
THANKS to ALL WHO SERVE!
Old 11-04-2009, 07:26 PM   #9
etvalentin
etvalentin's Avatar
Originally Posted by miesk5 View Post
Yo!
This is perfect man...thanks a lot.....
Old 11-04-2009, 08:55 PM   #10
miesk5
miesk5's Avatar
yw and GL!
Also to help others in da future, can you take pics or state what went bad?
Old 11-06-2009, 06:31 PM   #11
etvalentin
etvalentin's Avatar
SOMETHINGS MISSING
somethings missing...i pulled out the radio and the temp control panal...well i pulled that panal out as much as i could, but what i can see is that for the top slide switch, which switches it from cold to hot, there's a cable connected to a tab so when you slide from cold to hot, it pulls the the cable and changes the temp...the bottom slide controls the vent to floor to defrost, but that tab doesn't have a cable connected, it looks like it's missing...the cable just doesn't seem to be back there, but if i could find out where that cable originally went to, i could locate that end and maybe come up with something to fix it...anyone have any ideas where this cable goes to?
Old 11-06-2009, 07:06 PM   #12
etvalentin
etvalentin's Avatar
one last thing, is there anyway to manually change where you want the air to come out...i'd like to have it come from the defrost all the time since winter is coming, i'm sure i'll need it to defrost the window the most...thanks...
Old 11-07-2009, 11:06 AM   #13
miesk5
miesk5's Avatar
I don't have any more info on your year, but I know from the diagrm I posted above by Steve that there is a floor-defrost door vacuum motor; is the bottom lever using a vac hose?
such as show here again by Steve83
'80-86 A/C control panel
see da "Vacuum Harness" to the Left?
ok, figure out is the defrost door can be modded with an old-school throttle cable or even a bicycle hand brake cable; mount the end under da dash and other end.. ya get the pic?
Old 11-07-2009, 07:21 PM   #14
etvalentin
etvalentin's Avatar
i'm impressed with your diagrams...i've been searching like crazy for these...anyway, i see the vacuum harness on my switch, everything is plugged in as it should be...the i manually move the vacuum motor lever, but it doesn't stay in the position, it moves back by itself...i also noticed that there is a vacuum motor in the engine compartment too with a vacuum line going into it...there's also a vacuum line coming from the dash switch board into the engine compartment, but it's no hooked up to anything...not sure if it's supposed to be or not...where does the vacuum come from anyway?
Old 11-08-2009, 09:05 AM   #15
miesk5
miesk5's Avatar
thanks, but the Diagrams are from Ford via Steve .. and me...I am adding this to my site as I find them
The vac for the entire sys comes from the Intake Manifold, see diagram below
this should sum it all up I hope.
'92-96 HVAC Vacuum System
- '80-91 similar, except '87-early '88 which use a cable for Floor/Def/Panel. The '80-86 vacuum tank is a plastic ball on the R wheelwell.
Old 11-08-2009, 09:38 PM   #16
etvalentin
etvalentin's Avatar
i think this is my problem...there's no plastic ball on the R wheel well...i'm guessing that's what that vacum line coming out of my firewall was supposed to plug into...i'll have to search around for that ball...thanks again...
Old 11-09-2009, 07:51 AM   #17
miesk5
miesk5's Avatar
yw; try a yard...or ebay; new is about $30.00
Someone made their own tank once; think it was from a typical propane torch tank; the plumbing type
Old 11-09-2009, 12:20 PM   #18
etvalentin
etvalentin's Avatar
i did find one at LMC for about 30...i wouldn't mind ordering that, but does all it take is to hook up a vacuum line to the tank, from the carb, then run a vacuum line from the tank into the truck?...since the original owner pulled out all the A/C equipment, i'm wonderin if there are additional parts i'd need just to make this work...as for making my own tank, i'm just not that handy...
Old 11-10-2009, 10:15 AM   #19
miesk5
miesk5's Avatar
hmmm.. that is a good (or bad.. depending on what is missing and how much $ you want to spend on parts) Q!
One thAng to consider in that the missing AC and prob other stuff won't help much w/defrosting the windshield, as you well know.
So how about just experimenting with those doors and finding a good position for defrosting the ws and then going to a cable system? or adding a small duct and blower fan for defrosting the ws; say a 12 v DC computer fan?
Yes, get the vacuum off the carb or manifold or whatever a tee can be placed such as da brake booster
Old 11-10-2009, 11:50 AM   #20
etvalentin
etvalentin's Avatar
yeah, i think a cable system might be the best bet...i pulled one of the levers, but it doesn't seem to change the air flow, so i gotta lotta work to do...the electric fan idea sounds like it might work though...i'll look into that too...i've been searching the forum and the net to see if i could find a picture of what an 84 with a 351w engine compartment should look like, stock...that way i can better identify what parts i am missing, or how much has been changed on mine...any ideas?
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
