vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > 1980-'96 Bronco Tech
Thread Tools Display Modes
Old 11-03-2009, 12:48 PM   #1
chicho
chicho's Avatar
Bronco Info: 95 XLT 351w E4OD completely stock
No power in the bronco Please Help!!
ok. this morning fired up the bronco to go to school. no problems got to school fine. at school i parked and turned off the motor, then i tried to turn on the alarm... nothing, now there is no power nothing electrical turns on neither does the bronco. all i have tried as of now is jump the battery, also tried someone elses battery and nothing... Any suggestions? Ideas? Probable causes? anything?
chicho is offline   Reply With Quote
Old 11-03-2009, 12:53 PM   #2
sackman9975
~*~*~ Til I Die ~*~*~
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Try cleaning your battery posts and cables. Sounds like you have a bad ground.
I collect U.S. coins and currency and have been doing this since I was 8. If you have something that may be of value and you need to know, PM me and I'll be glad to help you out.
__________________________________________________
~ Scott ~ ~ Ford's, please bring back the Bronco!! ~
~ How my truck sounds ~ Parts for sale from a 93 ~
~ Bronco owner/driver/mechanic/enthusiast for 18 years ~
sackman9975 is offline   Reply With Quote
Old 11-03-2009, 01:35 PM   #3
chicho
chicho's Avatar
just finished cleaning the posts and the cables... still nothing, anyways thanks for the suggestion. damm this sucks anyone else???
Old 11-03-2009, 01:44 PM   #4
sackman9975
Try cleaning the ground connected to the block.
Old 11-03-2009, 01:48 PM   #5
chicho
chicho's Avatar
will try. where is this located more or less?
Old 11-03-2009, 02:08 PM   #6
sackman9975
Ust follow your negative cable down to the block. Should be a 9/16 bolt holding it to the front of the block right behind the smog pump.
Old 11-03-2009, 02:26 PM   #7
chicho
chicho's Avatar
found it. cleaned it.... nothing still. looks like ima have to get a professional to come look at this. anything else?? by the way thanks sackman.
Old 11-03-2009, 02:37 PM   #8
SigEpBlue
Satyr of the Midwest
SigEpBlue's Avatar
Location: Ida & Grand Rapids, Michigan, a.k.a The Unemployment Capital of America
Bronco Info: 1993 EB, 5.8L, BIO0 MAF, GT40Ps, Mustang cam, GT40 Intake, Custom Headers, Moates QuarterHorse
If everything's dead, you probably burned a fusible link or two. Grab a test light or a voltmeter, start probing, starting at the battery, then moving away.
SigEpBlue
Wheelin' across Michigan from Ida to Grand Rapids, baby!
Originally Posted by Nicola Tesla
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
Originally Posted by Adlai Stevenson
Isn't it conceivable to you that an intelligent person could harbor two opposing ideas in his mind?
SigEpBlue is offline   Reply With Quote
Old 11-03-2009, 05:34 PM   #9
X JBM X
Bronco Info: '96 Bronco XLT / '06 WRX STi
Start going through the fuse boxes and make sure nothing's blown. Unlikely, but possibly the problem here.
X JBM X is offline   Reply With Quote
Old 11-03-2009, 07:39 PM   #10
Alvin in AZ
Bronco Info: '91 that I've never driven LOL :)
Unlike Sig, I don't have any idea what the problem is. :/
But I do know that his idea of the meter or a test light is the way to go.
Any idiot with a meter and time to mess with it can find an electrical problem.
I know that to be true! Because this idiot has BTDT uh hunnerd times. LOL :)
You can do it, just get a meter or get someone with a meter.
It's easier and easier the more times you find trouble with a meter.
The first time is the best and most fun! LOL :)
Chico, you can do it. :)
Don't freak, take time to think.
Alvin en el Venta de la Mesilla
Alvin in AZ is online now   Reply With Quote
Old 11-03-2009, 07:47 PM   #11
justin
justin's Avatar
Bronco Info: 96 XLT/5.0/E4OD
Test for continuity on the battery cables....the cables can go bad in between the terminals.
Don't throw in the towel just yet.
Life isn't fair
Originally Posted by HardyHar View Post
I shook it and a tiny bit of the white crap came out with a few more droplets.
justin is offline   Reply With Quote
Old 11-04-2009, 02:39 AM   #12
chicho
chicho's Avatar
thanks to all who responded
found the problem. my ground wire was bad, started stripping it and found all the copper, well what remained was pretty burned. so i replaced it $6 from autozone. now another question what the hell caused that to happen? will it happen again? Soon?
Old 11-04-2009, 03:20 AM   #13
SigEpBlue
SigEpBlue's Avatar
Natural corrosion, and probably not for a very long time.
Old 11-04-2009, 12:53 PM   #14
Alvin in AZ
Originally Posted by chicho View Post
found the problem.
Cool. :) Thanks for getting back to us on it, many don't.
Was the bad spot near the battery end where the acid got to it? :)
I use motor oil to protect the battery terminals and wire.
Especially if the wires are exposed I oil those so the oil will go inside.
I also use the red/green felt washers but soak motor oil into them.
It's kind of messy looking but beats having dry corrosion. ;)
Alvin in AZ
Old 11-04-2009, 07:51 PM   #15
sackman9975
found the problem. my ground wire was bad.......
Glad you found the issue.
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
